Results 1 to 7 of 7
    Bike carrier for 2yr old that's quick to put on/take off?
    Wanted to be able to add a bike carrier to my Mojo HDR.. a little tricky given I have a dropper post, dual suspension frame etc. Any suggestions for something that can work on a mountain bike? I do no want to go the trailer route given we are in the city so feel that it's unsafe..
    Reputation: jonz's Avatar
    iBert, so long as you have at 1.125" dia steer tube least a 20mm spacer above your headset. Install/removal requires pulling off your stem, adjusting spacers, and popping on the T-bar. Takes under 5 minutes.
    Child Bike Seat | safe-T-seat by iBert | Family Biking
    I definitely recommend the Ibert too. I made it work with a 1.5" steerer tube also, just need some longer bolts. Not sure why you need to remove your stem though, as mine easily mounted onto the spacers around my steerer tube below my stem. Also, if you can, try to use an uncut fork. With mine, it perfectly interfaced to the Ibert, giving another point of contact besides just the t-bar. You'll have to play around with it to get it right, but we rode some decently technical singletrack with this, and the t-bar would not have been enough.
    Quote Originally Posted by BullSCit View Post
    Interesting, so you mounted over the spacers, I've always had mine mounted directly to the steerer tube, in a gap between the spacers. Doesn't it scratch up the spacers? No vertical slippage, or you mount it directly above the headset? It's obviously much easier to install/remove this way.
    hmmmm - i only have 10mm spacers between my stem and headset.. 10mm above, i guess I could just redo it every time..
    Yeah, over the spacers. I have my preload on my headset a little tighter than normal, and that makes it so the spacers don't spin around. Also helps having the top of the steerer tube contact the seat also. And it scratches up the spacers, but they are only a couple bucks, so not a big deal to replace if I ever wanted to.
    We probably did 2 or 3 rides a week this way, and I also rode a couple times a week without the kids, so being able to quickly swap back and forth was paramount.
    I do the same. Right over the spacers. It is quick and easy and as Bull stated I will replace them down the road as they only cost a few bucks.
  1. DH/FR Bike Carrier
    By nobrakes2007 in forum Downhill - Freeride
    Last Post: 03-19-2014, 11:47 AM
  2. Replies: 0
    Last Post: 01-27-2014, 01:50 PM
  3. What kind of bike carrier is best
    By Fargo1 in forum General Discussion
    Last Post: 01-21-2013, 11:40 AM
  4. Roof bike carrier for BMW E39 or E46
    By JoePAz in forum Cars and Bike Racks
    Last Post: 08-03-2012, 03:09 AM
  5. I love this bike carrier
    By SgtBaxter in forum General Discussion
    Last Post: 08-30-2011, 06:45 PM
