Page 5 of 5 FirstFirst 12345
Results 201 to 247 of 247
  1. #201
    Reputation: flipnidaho's Avatar
    The shop I go to (Bauerhaus Bikes in Boise, ID) put it on for me but you should be able to order it from Slikgraphics. Just make sure you specify Evil Calling Angry Dolphin as a custom color and they should be able to match it up.
  2. #202
    Jun 2015
    Thanks flippin
  3. #203
    Quote Originally Posted by PurpleMtnSlayer View Post
    Thanks flippin
    Another sample of their work. This is my Spartan. 2 different forks. Pike 160 and 36 RC2 170
  4. #204
    Jul 2016
    Hey JC, sweet ride. Hey looking for your feedback since I know you have experience on a lot of the bikes I am looking at. Coming from a Nomad looking for something more playful but can still handle tech/rock gardens. Been considering either adding a 5010 or something like a calling, recluse, bronson, jeffsy 27.5 and selling the Nomad. What are your thoughts on some of the bikes mentioned/recommendations based on what I am looking for? Thx DUDE!
    Quote Originally Posted by JCWages View Post
    Picked mine up today. Weight for large with pedals (342g) is 29.72lbs. It feels a lot lighter riding it around though and I'm used to 27-28lb bikes. Love it!
    Attachment 1120405
  5. #205
    ZEN RIDER!
    Reputation: Mt.Biker E's Avatar
    Mar 2006
    Life in every breath
  6. #206
    Brand Ambassador SuperModerator
    Reputation: JCWages's Avatar
    Jan 2015
    Quote Originally Posted by jsites.slo View Post
    So far this thing hasn't let me down. It is quite amazing that it is only 131mm of travel. I really loved my Spider 275c for how playful it was and the superb climbing efficiency but it beat me up on the really rough descents. It could handle the rough for sure but it didn't feel very nice compared to say the Tracer. The Calling feels MUCH more composed and doesn't beat me up yet retains a very playful attitude and maneuverability is crazy. Sometimes I ride ADHD style in that I start off going fast and have a path lined up but then I see something to the side that I want to hit and SQUIRREL I immediately switch direction to hit whatever caught my eye. This bike allows me to ride like a nutcase without a solid goal in mind except to have fun. The solid build and super forgiving geometry and suspension keeps me safe when I'm riding like a hack. It's definitely more playful and efficient than the Nomad I borrowed a few weeks ago. Great bike but a different category for sure.
  7. #207
    Reputation: AaronJobe's Avatar
    Waiting on rims
    Attached Thumbnails Attached Thumbnails Is something EVIL.........CALLING?-img_1381.jpg
  8. #208
    Reputation: jdcatnau's Avatar
    Feb 2007
    I know what I'm doing tomorrow.
  9. #209
    Sep 2013
    Hi,
    Newbie to Evil bikes, do I set the sag meter just below the 30% mark or cover up the 30% mark for the sag?
    Thanks.
  10. #210
    If I'm remembering correctly, Evil's thinking is you obscure the mark. But be willing to play around at just +/- 30%. On my Insurgent, I ended up settling around 27-28% measured on the Monarch shaft marks and just below the mark on on the meter. ~210 psi or slightly under and I weigh ~155 in riding gear. My feeling is that, with regard to this shock, the pedaling platform is quite a bit better than 30% and it brings the bottom out resistance up a bit to where it's perfect for my style. Overall bike balance feels better, too. Set at 30%, the plush feel is indisputable, but I felt the rear felt slightly squatty under pedaling and the the travel o-ring would be knocked off the shock several times per ride. For reference, I'm running a Lyrik 160, solo air, again set-up at 27-28 percent sag. All this said, the DELTA is a great performer. Set-up anywhere near 30% will make for an incredible ride. Sorry for the long-winded reply!
  11. #211
    Feb 2007
    Finally got mine built up last night and I noticed some vertical play when I had picked up the bike from the frame to hang on the wall. I could see linkage move as if the shock wasn't extended all the way. Any suggestions? I'm going to go through everything with a torque wrench to see if that helps.
  12. #212
    Quote Originally Posted by jdcatnau View Post
    it's normal for the fork and shock to settle a tiny bit from the weight of the bike.
  13. #213
    Mar 2012
    [QUOTE=jdcatnau;13069811 I'm going to go through everything with a torque wrench to see if that helps.[/QUOTE]
    Usually A good idea to deflate your shock before torquing things down. Just take note of psi, deflate it, and then go to town. Less loading on the hardware.
  14. #214
    fc
    fc is online now
    mtbr founder Administrator
    Reputation: fc's Avatar
    Aug 1996
    Hey Dom,
    It called me to and I answered! Is something EVIL.........CALLING?-p3020049.jpg
    IPA will save America
  15. #215
    Feb 2007
    It's done! Shimano XT drive train except race face turbine cranks and AB 32 chainring
    XT brakes
    Crank Brother highline dropper
    Rental bars and stem
    Stans flow rims with Onyx hubs
    Ethirteen tires
    WTB volt saddle
  16. #216
    Jan 2015
    XT brakes
    Ethirteen tires
    WTB volt saddle
    Slick! Congrats man.
  17. #217
    Jan 2015
    My fork decals showed up yesterday!
    Is something EVIL.........CALLING?-16683234_10154400320206295_1594202316_n.png
  18. #218
    Feb 2007
    Quote Originally Posted by flipnidaho View Post
    Found the lower shock bolt to be loose. Snugged everything to torque spec on the bolts and it's now tight, no vertical play.
  19. #219
    Jan 2015
    Put some blue Loctite on it. Mine came loose twice. Then the head stripped while trying to torque it to spec. Set the Wrench for 65 in.lbs and striiiiip. The bolts are very soft so I don't want to touch it often.
  20. #220
    Feb 2007
    That's weird, mine says 85 in/lbs.
  21. #221
    Jan 2015
    Mine too. That's my point. I was 20 in.lbs lower than spec and it still stripped. Eek!
  22. #222
    Reputation: Dominator13's Avatar
    Sexy....but why is it clean? ;-)
    "You don't stop playing because you get old, you get old because you stop playing!" - Unigeezer
  23. #223
    Feb 2007
    Quote Originally Posted by Dominator13 View Post
    Waiting for 16" of snow to melt, but it's a good thing I'm only 45-min from Sedona.
  24. #224
    [QUOTE=jdcatnau;13072876]Waiting for 16" of snow to melt, but it's a good thing I'm only 45
    Nice! Should've gone to the Fat Tire Fest. I do understand that weather thing. Hasn't been much of an issue here in Santa Cruz over the last few years, but it is boggy now. It'll take a week to dry after even the slightest rainfall. Have to do the steep rocky runs, which there aren't many of. I know....blah, whine, blah.
  25. #225
    Feb 2007
    Anyone with RF cinch cranks experience rubbing on the chain guide in the two lowest (large) cogs? I added another spacer to the BB as Dom referenced but now the chain is rubbing on the highest (small) cogs.
  26. #226
    Jan 2011
    Yes...
    To finish with my nightmare-ish issue with my Next SL, I ended up adding 2 very thin spacers between the cup and the crankset, so outside of the BB. It works, but the chain definitely rubs against the chainguide on the two lowest (large) cogs.If I put more spacer, I can't tighten the DS arm on the spinde. I still dont understand what is wrong.
    Anyway, it works now. It rubs a little, but it works. The chainline is definitely not optimal in my opinion.
    French line enthusiast and expat in Denver
    I like bikes, I really do.
  27. #227
    Are you using boost chainring?
  28. #228
    Jan 2011
    In my case, I'm using the standard Cinch Raceface 30teeth chainring, good question for Jdcatnau though.
  29. #229
    I should have mentioned this before. I got a Boost specific chain ring that fits a 12 spd and was able to remove the spacer. Works like a charm now.
  30. #230
    Feb 2007
    Quote Originally Posted by AaronJobe View Post
    Yes, absolute black boost cinch with shimano 1x11.
  31. #231
    Feb 2017
    140 or 150mm fork
    Hello Calling owners, just received this grey beauty of a frame and parts are trickling in.
    Fox 36 RC2 arrives next week, and will need to be dropped in travel. Planning on 140mm, does anyone have any experience with a 150mm fork on the calling? How does it behave?
    Also, any WB cage recommendations that match the bomber vibes of the frame?
  32. #232
    Jan 2015
    Quote Originally Posted by mckleroy View Post
    I used the Fabric cageless WB. It looks less goofy on days I'm not using a bottle. Drawback is it makes removing the bottle harder. I tend to pull hard enough to smack my knuckles on the frame. lol
  33. #233
    Robertson
    Reputation: rpearce1475's Avatar
    Jan 2015
    This is an odd request, but would you mind measuring the distance from the center of the bottom bolt hole on your water bottle to the bottom of it? Wanting to put one of these on my Wreckoning but the water bottle bosses are pretty low near the shock...
  34. #234
    Quote Originally Posted by fc View Post
    Hey Dom,
    It called me to and I answered! Click image for larger version.
    Well? You've had to of been shredding on it the past couple of days. So, your thoughts?
  35. #235
    Jan 2015
    Quote Originally Posted by rpearce1475 View Post
    It appears to be approx. 46mm from the middle of the bottom bolt to the bottom of the water bottle. It sits against the top of the trunnion mount shock. I measured from the middle of the actual bolt to the top of the shock and got the same number.
  36. #236
    Is something EVIL.........CALLING?-img_1466.jpgIs something EVIL.........CALLING?-img_1480.jpgIs something EVIL.........CALLING?-img_1474.jpgIs something EVIL.........CALLING?-img_1471.jpg
  37. #237
    Feb 2007
    [QUOTE=AaronJobe;13088916]
    Looks good
  38. #238
    Jan 2015
    Nice rigs!
  39. #239
    Jan 2015
    Finally put my fork decals on.
  40. #240
    Maiden ride
    Her first ride on what was supposed to be my Calling. I'm definitely not getting it back now. She even likes it better than her Insurgent (with the 11-6/Enve wheelset). Still way better than a girl that's into jewelry.
    Is something EVIL.........CALLING?-2017-03-19_08-05-21.jpgIs something EVIL.........CALLING?-2017-03-19_08-04-51.jpgIs something EVIL.........CALLING?-2017-03-19_08-04-07.jpg
  41. #241
    Jan 2015
    Haha sucker! I'm lucky my Calling is 2 sizes too large or my girl would steal it too.
  42. #242
    Lucky you!
    The good thing about us riding the same size bikes is that when she's not around, I can "borrow" it just by switching post and pedals.
  43. #243
    Mar 2012
    Got about 15 rides in. pretty rad. Swapped out components form a 5010cc. 5'11" 205lb, comfortable on the medium with a 50mm stem. Also have a med wreckoning, this fits much better, feels bigger. running 29-30% sag. the superdeluxe is super deluxe! Pedals very well, relative even to a 5010, western mass has plenty of very technical climbing, especially with snow. The build is light which helps at 27lb. 3 oz. Posted a bike check on Vital.
    Evil The Calling light-n-sprite - eastenwreckoning543's Bike Check - Vital MTB
  44. #244
    Quote Originally Posted by planetx88 View Post
    Which bike would you say is more playful/agile? The 5010 or the Calling?
    Guessing the Calling would be a fair bit heavier?
  45. #245
    Jan 2011
    I'm surprised you get more than 3 pounds of difference with mine (on which I believe you have the only comment ) !
    I have tires a lot heavier, it's a large, but it was weighted before I replaced the Hope X2 with Saints.
    At least I know I have room for improvement. I think I'm going to get a HRII front and a Minion SS rear. Lighter than my Michelin, and probably a lot faster rolling and adequate for the Colorado hardpack
  46. #246
    My Calling frame has been delivered, ordering a bunch of parts now.
    Question - do I need a post to post adapter to run a 180mm rotor in the back? Or is the mount on the seat stay already set up for a 180mm rotor?
    Sep 2013
    Yes, you need a post adaptor for a 180mm rotor. Frame was made for 160mm rotors.
  1. Evil The Calling 26+
    By vikb in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 2 Weeks Ago, 07:35 AM
  2. EVIL "THE CALLING" - Spy shots and first look!
    By Bam da Silva in forum Evil Bikes
    Last Post: 02-11-2017, 10:35 AM
  3. Replies: 563
    Last Post: 02-03-2017, 12:10 AM
  4. calling evil
    By kenwood72 in forum Evil Bikes
    Last Post: 03-10-2016, 06:31 AM
  5. Evil D.O.C vs Evil Sovereign
    By woodc in forum All Mountain
    Last Post: 02-07-2011, 10:13 AM
