Page 7 of 7 FirstFirst ... 34567
Results 601 to 695 of 695
  1. #601
    SISSIF
    Reputation: TheCanary's Avatar
    May 2014
    Quote Originally Posted by tdc_worm View Post
    I won't give the angle set all of the credit...running a stiffer shock spring resulted in rear riding higher in the stroke, keeping more weight on the front wheel. slackening the head angle dropped the stack and moved the saddle forward, again helping to place a little weight on the front wheel. if offset is measured on the y axis of the fork, then slackening the head angle should reduce offset, thereby increasing trail. with the axle on a 29er being so high (compared to a 26 or 2.75), it seems like a mm change here and or there would be amplified.
    at the end of the day, the changes may or may not matter, and i could just be getting used to the bike. that said, i don't intend to revert back to the softer spring and the normal headset, as I haven't inherited any negative traits.
    YMMV
    Have the 1.5* Works angleset installed to slacken the front. Hard to change up just one variable at a time but I'm pretty keyed into the Wrecker and this has been a great change. I've gone back and forth between Low and X-Low quite a bit for different missions and this seems to give the best of both worlds. Goes up and pedals better than the Low setting and handles and descends better than the X-Low setting.
    Really like the steeper seat tube, noticeable change, had to bring the front of the saddle up to compensate. Also shortened the reach so went up 10mm on the stem. The DELTA has really good pedaling kinematics, limited by seat position, now it really feels like a trail bike, grab a gear and leap out of the saddle. Took it up some loose, tight switchbacks that I've struggled on in X-Low with no problem. Steeper seat tube seemed to more than offset the slacker fork and the front was less floppy climbing - longer stem probably helped too, hard to change just one variable.
    Definitely settled the front end descending too. Less hunting while carving, able to hold a line better and actually holding tighter lines. The Wrecker is soo good, to be able to throw it into turns with even more abandon is amazing.
    Been riding a lot so the changes, while subtle, are certainly noticeable and add up to a better ride.
    Now the bad news, the Ohlins coil has less lower stack with the integrated crown and race and is not compatible with the Works angleset, had to go back to the Pike for the set-up - another variable. The offset on the Works is in the lower cup and the crown race has significantly more stack than a CC race. Thinking I may be able to switch to the CC angleset that has more of the offset at the top cup, only 1* but I get my Coil back.
    So, ongoing refinements.
    But... Mainly riding!
    Big Wheels and Fat Skis keep me young.
  2. #602
    Reputation: titusquasi's Avatar
    Quote Originally Posted by TheCanary View Post
    I really like the sound of this and may end up trying a -1 myself.
    -1.5 puts you under 65 deg correct? Wow.
  3. #603
    Dec 2008
    Have the 1.5* Works angleset installed to slacken the front.....
    Pretty much sums up my position with the 1* angel set.
    So is the crown dragging on the lower bearing cup? Either way, total bummer as I was aiming for an rxf 36 over the push acs3 system.
    What Stem length were you swapping between? I have a new 50mm stem that I have been holding off on installing in place of my current 35mm....
  4. #604
    SISSIF
    May 2014
    Yep. The integrated steerer/race puts the crown up against the lower cup. The Works crown race is taller(more stack) than most, probably to deal with clearance issues. The Pike works(Ha!) fine with the included race.
    I'll be trying the 1* CC angleset that has the offset in the top cup with the stock FSA lower. I like the Works design better and it still may not work but LBS has the upper CC set laying around so worth a try.
    Went from 50mm stem to 60mm on a medium. Before seated to pedal I'd be stretched on a medium, standing reach I would be better on a large. Now, with the steeper seat tube, the large would work best.
    Once I get the Ohlins sorted out we'll see.
  5. #605
    Dec 2008
    Bummer. How severe is the contact? Could you remove a tiny bit of aluminum on the bottom/front of the cup giving enough clearance to free up the crown?
  6. #606
    SISSIF
    May 2014
    May be worth a try. Gonna check out the CC option first.
  7. #607
    Can you guys with the Works Components headsets confirm the model needed for the Wreckoning, please?
    Nevermind. I found a thread I started last winter with the info: 44/62.
    1 deg ordered!
  9. #609
    SISSIF
    May 2014
    Yep. Ordered according to head tube length. Actually ordered mine from Fanatik as they were out of stock at Works.
  10. #610
    Jan 2017
    This might be a stupid question for TheCanary or tdc_worm, but how does slackening the head angle with the works headset make the seat angle steeper? Is this just from the drop in the front end that occurs?
  11. #611
    SISSIF
    May 2014
    Essentially. The differences are small but noticeable. Flipping the chips works by dropping the BB and the front triangle rotates back slightly giving the other changes: longer wheel base, slacker front end and seat tube.
    By slacking the head tube with an angle set the front triangle rotates forward giving similar changes, in slightly different proportion, except... the seat tube gets slightly steeper.
    For me, starting with the seat all the way forward, flipping the chips was more of a compromise. For others the fit may work fine either way.
  12. #612
    This angelset set thing is very interesting and something I might want to try! Thanks for posting the info.
    With the -1 angleset what mode are you running it in-low or ex low? If run in ex low (which is what I perfer) does the angelset still steeped the seat tube to were it feel better than without the angelset?
  13. #613
    Dec 2008
    Any progress on this? I was looking at the calculator on CC website, and it doesnt show a ZS44 option, only and EC44 option....
  14. #614
    SISSIF
    May 2014
    I think the EC44 would work, as long as you don't mind the added stack height, probably allows more room for the offset.
    Didn't get around to trying it myself, let someone ride the Wrecker with the Pike and they had to have it, couldn't pass up the easy sale since I knew it would take a large frame to get where I wanted.
    Hope they bring out some new colors this winter.
  15. #615
    Dec 2008
    Hope you have a spare sled! Wrecker or not, there is still tons of bike season left!
  16. #616
    SISSIF
    May 2014
    Yep. Mini-Wreckoned the trail bike with the Ohlins coil fork, the CC inline coil shock and stouter rubber. It'll do till the next round of big bike releases.
  17. #617
    Jul 2017
    Such a sweet ride. Feel like I've found "my bike" after two years of swapping around. Considering most parts were pulled from my older Nomad 3 I'll likely change a few things out, probably start off with a bar that doesn't have as much rise..
    Gunmetal The Wreckoning (stickers removed)
    Invisiframe wrapped
    LightBicycle carbon 29" rims(31.6mm inner width)
    Onyx hubs w/ black chrome powder coat (boost F/R)
    CushCore foam inserts
    Maxxis Minion DHF 2.5" WT up front
    Maxxis Minion DHR II 2.4" WT out back
    Rockguardz carbon downtube protector
    Easton Haven 32mm stem w/ 35mm clamp
    Easton Haven carbon bar (40mm rise, 750mm wide)
    ODI Rogue lock on grips
    Shimano Zee brakes front/rear
    Ashima 2 piece Flotor rotors (203mm front/180mm rear)
    Push Elevensix
    2018 Fox 36 with ACS-3 and Push shimstack
    Raceface SIXC cranks (170mm)
    Crankbros Mallet DH (Older style)
    Absoluteblack 30T oval boost chainring
    Ethirteen LG1 bash with tensioner removed
    Ethirteen TRS Race cassette (9-46t)
    KMC X11.93 black/silver chain
    Shimano XT GS rear derailleur and shifter
    Rockshox Reverb 150mm stealth(removed the guide connector at the base of the post to slam it an extra 3-4mm)
    Rockshox Reverb 1x remote lever
    Fabric Scoop Gel () radius profile (all black)
  18. #618
    w/ that suspension on a Wreck, among your other components, that's about as nice as bikes get. maybe as good as bikes will ever get. YOW
    Quote Originally Posted by Cycle_Sauce View Post
    Invisiframe wrapped
    Push Elevensix
    breezy shade
  19. #619
    Dec 2014
    To wreckoning owners.
    I want to jump to 29er game and Wrekoning is on top of my list. I'm wondering whether a Wrek will be any good for the UK - short, twisty and narow trails. I'm on the Ibis Mojo HD3 (with -1į angleset) and I love it. There is a video from my trails (it's not me)
    https://m.youtube.com/watch?v=6Jxj8HLthLo
  20. #620
    Quote Originally Posted by wcinek View Post
    Trails look super fun. From what I can see, I'm pretty sure I'd have a good time on them with my Wreck.
  21. #621
    Hi,
    I can answer this as I made the exact same move.
    Like you I loved the Ibis HD3, a dream bike and a great trail bike.
    Like you I couldn't ignore the pull of the 29er and wanted something in the 150-170mm category.
    The reviews on the Wreckoning were too hard to resist, my local shop also sells them so a win win!
    When I got the Evil I though I would keep the ibis to save losing loads of money. After riding the Wrecker the ibis never really came out of the garage again. The evil does everything and more the Ibis did.
    The only thing I would say is it's a bike that needs to be pushed hard to make it come alive, sadly I'm not that rider 90% of the time but when I have pushed it, it's amazing.
    The only thing you will regret is the money you will lose on the Ibis when you sell it.
    Also make sure you get the right size.
    Neil
  22. #622
    Sep 2017
    I live in the Uk down in Devon, when I was considering moving from my 27.5 stumpjumper to a Wreckoning I wondered the same thing,but you need not be concerned, its such a great bike that you can have fun on it anywhere,took me a while to get it dialled in,& even now after 4 months im still learning things,but its the best bike ive owned,very stable at speed,& inspires you to go faster.
    Get one....you wont regret it.
  23. #623
    Reputation: Sid Duffman's Avatar
    Oct 2015
    Hi Wreckoning rippers. It seems that a frequent comment about the Wreck is that it needs to be pushed hard to "come alive," and may be not so great at slower speeds. Can anyone explain that a little further? I understand that it may shine brightest in the hard charging situations, but is it really worse than other long travel 29ers at more modest speeds?
    I'm looking for a point-and-shoot plow of a bike, that is very stable and confidence inspiring when things get a rough. However, I'm not a particularly aggressive rider, and don't race, but I do like going fast as much as the next guy. I'm wondering if the Wreckoning will still be awesome with a more conservative approach, or will it just feel like a pig? (I already have a light/efficient/nimble trail bike which I love, so I'm not looking for a 1 bike quiver here, but a bike that encourages me lay off the brakes and just go.)
  24. #624
    Dec 2016
    Quote Originally Posted by Sid Duffman View Post
    Check out my review of this bike on YouTube riding tame trails. Channel name "Trailjunkie" think it will answer most of your questions
  25. #625
    I think the Wreck could be a good fit for you. I don't find it particularly challenging to ride at slower speeds, on tight trails, or on mellower trails that are not particularly high speed or technically challenging. It's not as fast or efficient as my 429Trail or as quick and playful as my Calling, but I have zero issue riding it on most of the same trails.
  26. #626
    dmo
    dmo is offline
    Reputation: dmo's Avatar
    I feel the same way but also wonder why not a Following MB? Maybe a better fit for trail riding? I keep going back and forth, wreck or following mb?
    Sent from my SM-G955U using Tapatalk
  27. #627
    Sounds like you need a Wreckoning based on what you've said. I would say it's a pretty good trail bike, impressive climber for what it is and amazing when things get fast and rough. It does everything well, but shines on the DH. Just point and shoot.
    You already have a light trail bike so this would compliment that well.
  28. #628
    Oct 2015
    Thanks for the replies, y'all. To clarify my question, I'm not going to be riding this (potential) Wreckoning on tame trails; I'll be riding technically challenging trails, but at less than full pinned speed. @trailjunky, I enjoyed hearing your review in your video. I took note when you talked about demoing it at Moab, and it gave you the confidence to hit those trails chunky really fast. That's exactly what I'm looking for in a bike.
    I'm just having a hard time wrapping my head around the sentiment that the Wreck is awesome when going all out, but not great when not pinned. This thread is an example: Wreckoning - 11.6 - settings
    Is it that the first part of the travel is very stiff, but once you get beyond that it opens up and become more plush and active?
  29. #629
    May 2005
    I got on my Wreckoning yesterday on some super mellow trails (Grande Ridge Washington) after a few weeks being off the bike. Just reminded me how fun this bike is on everything from rowdy DH type stuff to buffed out XC. I think it may be the perfect AM bike for the PNW and definitely not limited to one type of terrain. Two full seasons on this bike and it keeps getting better. For reference my last bike was a Kona process 111 and this bike does everything better, including climbing.
  30. #630
    Jun 2015
    Yeah - I'm in the same boat of wondering about this. I've owned/loved my (v1) Following, but want more squish/capability without loosing the fun-factor.
    I think about how to either make the Following MB "bigger" [coil fork + 11.6 in rear... if it can fit?], vs. making the Wreck "smaller" [dual-position fork + stiffer/poppier shock settings].
    I don't think I could loose either way, honestly. But my gut hunch says for the rocky west that the Wreck could be a better quiver-of-one. Thx for the link on shock settings... I think it's a good start.
  31. #631
    wretch
    Reputation: Truckee Trash's Avatar
    Quote Originally Posted by laserjockrock View Post
    I want to do very bad things to the new Following MB ... 11.6 and the ACS Fox....yes please! Whenever I tell people about the Wrecker and how much I love it, the only follow up comment I have is if I could I would also own the Following...
  32. #632
    Rocks belong
    Do you have to use the boost version of the AB 30T oval ring? (For it to line up in the Evil upper chain guide?) Or could a standard AB 30T sram direct mount ring work?
    I like 'em long, low, slack and playful
  33. #633
    Jun 2015
    The 6mm offset absolute black oval on my sram carbon cranks lined up perfectly.
  34. #634
    Quote Originally Posted by 06HokieMTB View Post
    You can use a standard ring, but you'll have to correct spacing/chain line with spacers behind the drive side BB cup.
  35. #635
    Are any of you guys doing longer trail rides on your wreckonings? Say in the 20-30 mile range? Not something I'd do all the time with it but just wondering how it works for longer trail rides like that. Also curious what the average'ish weight is on these builds?
    edit: google helped me find a thread about the weight. sounds like 31-32 for most builds.
  36. #636
    Jan 2017
    @dfinn I regularly do 25-30 mile rides, often once a week, I have a wreckoning with 11.6, and weighs about 35lbs, i think it works fine for this, probably easier on a lighter bike but no reason you couldn't do this on the wreckoning
  37. #637
    I do occasional rides in the 20 range on mine. Again, does just fine. I do have a Calling and a 429 Trail that get pulled out more often for those types of rides, but I have no problem doing them on the Wreck. Mine is running an 11/6 as well, large frame, just under 30 pounds.
  38. #638
    Rocks belong
    And this is exactly why I asked...
    Quote Originally Posted by PurpleMtnSlayer View Post
    Quote Originally Posted by godfather View Post
    Those two comments contradict each other. The standard SRAM AB chainring is 6mm offset, Boost is 3mm offset.
    PurpleMtnSlayer says the 6mm lines up perfectly
  39. #639
    Jun 2015
    I was happily surprised the standard ring lined up. Again, I'm running sram cranks and obviously one 2.5 mm bb spacer on the drive side per gxp design.
  40. #640
    Rocks belong
    Oh. Well that answers it. SRAM GXP BB's use NO spacers for 73mm shells. (And two 2.5mm spacers for 68mm shells) You should actually remove that BB spacer from your GXP bottom bracket. (Which would then move your chain ring 2.5mm and require a 3mm offset/BOOST chain ring)
    68 mm bottom bracket shells require one 2.5 mm spacer on each side of the bottom bracket shell.
    73 mm bottom bracket shells do not require spacers.
    https://www.sram.com/sites/default/f...e_manual_0.pdf
    Shimano (not SRAM) BB's use 1 drive side spacer for 73mm shells.
    Evil Bikes: The Wreckoning - User Review-capture.jpg
  41. #641
    Jun 2015
    I'll be damned. I can admit when I'm wrong. Sorry if you bought the wrong ring. But hey this set up, even if incorrect, performs great.
  42. #642
    I only have 2 shakedown rides on my Wreck, but I noticed two things right away: 1) the bike doesn't bob like I would expect a single-pivot suspension to bob, and 2) the rear suspension isn't what I would call "super plush", despite having so much travel.
    This is a guess, but I think the factor that would explain both things is the leverage ratio curve built into the DELTA suspension. It might take rowdier riding to get the shock into a more lively part of the curve.
  43. #643
    Feb 2014
    Quick question on dropper posts for those with size large bikes. If you slam a 170 reverb as far as it will go into the frame how much post is exposed? I'd heard you can't quite slam it to the collar due to the connector interfering with the frame.
    If there are other posts which work slammed like the pnw bachelor 170 I'd be interested in those options too.
  44. #644
    Quote Originally Posted by Skedasticity View Post
    I'm running a 150 Reverb, and it hits before completely bottomed. That's with all the factory bits in place. I bet you'll have close to 20mm exposed with a 170.
  45. #645
    Sep 2017
    This is as far as I can get my 170mm reverb in without the hose being kinked & then the dropper wont work.
    Attached Thumbnails Attached Thumbnails Evil Bikes: The Wreckoning - User Review-dsc_0001.jpg
  46. #646
    Jun 2015
    Guys, everyone with a reverb should consider the wolf tooth lever and cable adapter. I needed a half inch more insertion than the stock set up allowed, the wolf tooth let me drop it an extra two for the bike park. The lever form and function also makes using the post much more intuitive and enjoyable. I was sick of spending money on bike stuff and just going to live with the extra exposed post, until my stock hydraulic hose got a cut during a race and my post was stuck down. In hindsight the $90 for the kit is well worth it.
  47. #647
    Feb 2014
    Well looks like no way a 170 reverb would work for me if that's a large bike. Guess I will probably have to go with a 150 or another post. Any idea how long the connector on is beyond the post?
  48. #648
    Feb 2017
    Reverb 170 in L Wreck
    Old style hose barb ( no connectamajig) cut down a bit on my L Wreck with a 170mm post. Center bb to seat rail is 28 inches exactly. Post is 3/4 inch from full insertion.
  49. #649
    Jun 2015
    Quote Originally Posted by ludorhb View Post
    Omitting the connectamajig saves ~25mm the Wolf Tooth another ~15mm. I think someone could slam a 170 on a large. But I'd pull the shock and make sure the rear tire clears the seat before I'd ride like that.
  50. #650
    Oct 2016
    Hey guys, thinking of getting a used Wreckoning frame,on the photos looks like the rear triangle has some rub damage from the chainring and on the inside from the tyre. Looks like cosmetic damage no real damage on the carbon but was wondering anybody knows how much will a new rear triangle only cost from Evil? Its a good deal on the frame so i wanna make sure if it fails its worth it replacing the rear. Thanks
  51. #651
    Reputation: BPSarge's Avatar
    Oct 2007
    I removed the hose guide inside the seat tube and have no problem getting my 170 in my large. Also no issues routing the hose after the guide was removed.
  52. #652
    Jun 2015
    Quote Originally Posted by BPSarge View Post
    How?
  53. #653
    Oct 2007
    Used a long punch that fit inside the tube and worked it out of the hole. It's held in with some week epoxy that came out easy.
  54. #654
    Jun 2015
    Interesting. Thanks
  55. #655
    Anyone with a medium wreck able to measure an actual seat tube angle for me? I know with these bikes frame size is important because of the slack actual seat tube angle. I have a 33" cycling inseam and just measured my bike and its roughly 27.5 to the seat rails or 29.5 to the top of the saddle. Could anyone help a brother out?
  56. #656
    Reputation: vikb's Avatar
    Quote Originally Posted by sb1616ne View Post
    The STA will be the same on every size Wreck given the same distance from pedal to to of saddle. So in that sense frame size doesn't matter. So same person on a Med or a Large will have the same actual measured STA. The only difference will be how much seatpost is above the top of the seat tube.
    Safe riding,
    Vik
    www.vikapproved.com
  57. #657
    Reputation: rondre3000's Avatar
    Quote Originally Posted by vikb View Post
    Exactly, so OP what you really need to be worried about is how much closer to the rear wheel you'd be on a Medium vs a Large.
    Sent from my Pixel XL using Tapatalk
  58. #658
    Quote Originally Posted by rondre3000 View Post
    That won't change either for the same leg length.
    Safe riding,
    Vik
    www.vikapproved.com
  59. #659
    Really?! Man, I'm all sorts of confused then. Thx for the correction.
    So really the only consideration here is how much seat tube is exposed?
    Sent from my SM-T810 using Tapatalk
  60. #660
    Yes and that will determine how long a dropper you can use.
    Safe riding,
    Vik
    www.vikapproved.com
  61. #661
    I just posted this in a wreckoning sizing thread but am
    Looking for some immediate feedback so gonna post it here as well.
    Im 6í5í with a 32 inch inseam. I have a hard time fitting on most bikes. I have recently purchased an evil following MB XL. Love the playful nature and pedaling platform but Iím running a 140 fork and that has shortened the reach on this bike. I have realized I can overwhelm this bike pretty quickly and the combination of the shorter wheelbase, reach, and shorter travel from what I am used to. I want to sell my following MB frame at replace it with a wreckoning with a 150 fork to be my everyday TRAIL assasin. The numbers look good with a 150 fork. Has anyone run a 150 fork on the wrecker?
  62. #662
    Quote Originally Posted by tbjorkman View Post
    I can't remember mention of a 150 on a Wreckoning. I think the only issue would be BB height as it's already on the lower end for it's travel. If you can deal with that it should work great.
    PM'd you about the XL Following MB you may sell...interested.
  63. #663
    Jun 2015
    Thanks for bringing this up... I'm super-curious of creating such a 'crossover' bike, too.
    Here on the CO Front Range, there are a couple shops that have apparently put a Dual-Position Air front fork for 160/140mm operation (for the steep climbs), and I've heard it's a good fit. Also, I recall a post from another fellow in the SouthEast who did the same, and uses the DPA in the 140mm range for "trail" riding... stating that it's more nimble, etc.
    I think it's a good idea with merits for the right conditions. I'd seriously consider a DPA if I didn't want a coil fork (thinking the Push ACS3...), so I may consider a lower front end as well. Just wouldn't want to be under-gunned when going out to Moab...
  64. #664
    Response I have received from this is that it would lower the B.B. too much but even in the extra low position the B.B. would still be around 334-335. Thatís not ridiculously low
    in my opinion. Yes itís low for some ridiculously trails with large square hits but the intent of going to 150 is to ride this fast as **** on trails that arenít necessarily gnarly Moab. IMO 335 BB rides can do just fine in pretty technical terrain.
  65. #665
    SISSIF
    May 2014
    Started the Wrecker off with a DPA Pike. Definitely helped pedaling up steep, tight trails.
    It was ok all around but there are much better performing forks - Coil! So got used to climbing with a slack bike. Hopey steering damper has been mentioned to help pedaling but I never got around to trying it.
    This summer found maybe the best solution - Works angleset. Slacking the front out helps on the downs but it actually steepens the seat tube angle and noticeably improved pedaling.
    I'd say FOX Coil conversion with an angleset would be hard to beat.
  66. #666
    Just took my Wreck up to Laurel Lakes in the Eastern Sierras. It's a brutal climb with plenty of HAB. I can't believe how well the bike climbs steep, techy, loose slopes. There were so many times I thought, "there is NO way I'm clearing that", but I just hung on and kept my head down, and I'll be damned but it kept the momentum, kept hooking up over the rocks and scree like nothing I've experienced before. Every time I braced for the rear wheel to spin out it wouldn't do anything worse than "chirp" and dug right back in. I have to rethink my expectations about what's possible, and that's intoxicating stuff.
    I've done that climb on a RIP9, a Mojo SL, and a Mojo HD. This is the first time I realized I could theoretically clear the whole thing if I only had the cardio and gearing to keep up my momentum without blowing up.
    Of course, the trip down was fantastic. The Wreck ate all that rocky stuff like it was nothing. Hell, it felt like it wanted to play much harder.
    A couple side notes:
    - The lack of plushness I felt initially was from too much LSC on my X2. Even with zero clicks of LSC, the bike doesn't bob much under pedaling. I could probably stand to add a few clicks, but no rush.
    - I did manage to fit a 175mm KS Lev Integra on my Medium Wreck. This is very much a YMMV kind of thing. I was using a 150 before at minimum insertion and kept wishing I could get a little lower without losing travel off the top. A lot of careful measuring told me that it could work in my case, and it's been great. The only downside is that the seat clamp on the Lev is just *barely* able to get my saddle level considering the super laid-back angle of the seat tube.
  67. #667
    Reputation: Rynee's Avatar
    Aug 2014
    hi @kestrel242, thanks for sharing your experience, that sounds very intriguing. can i ask two questions - are you running a round or oval ring up front? and which rear tire, on what rim, and at which pressure?
    great that the 175 lev fits - i guess it feels like a big big bmx now hehe
    cheers, rynee
  68. #668
    Rocks belong
    Quote Originally Posted by kestrel242 View Post
    This is becoming more common place and is definitely worth mentioning. The shape of your saddle can definitely dictate this as well. More specifically, saddles that sit higher on the rear and slope down to meet the rails at the nose will work better on frames with such a dramatic bend in the seat tube.
    For example, at WTB Silverado Thinline has a very "level" profile when compared to other saddles. I found my seatpost clamp was almost out of adjustment when I put on the WTB saddle.
  69. #669
    I believe it. I have a Selle Italia SL XC Flow, which barely works jammed all the way nose down. I'd be more comfortable if I knew I had the adjustment range to pitch it too far down. I have a Selle SMP Hell that does have the high profile rear and sloped down nose, which may work better that way. The main issue for me is that the wide part of the Hell saddle sits substantially further back than the flow, and I tend to ride with my saddles as far forward as possible since I spend so much time climbing.
  70. #670
    Quote Originally Posted by Rynee View Post
    The ring is an Absoluteblack 28T oval. Next time I try that climb I may switch to a 26T round ring.
    The rear tire is a Nobby Nic 2.35 Pacestar at 25psi on a Yuan'An 40mm (35 interal) AM/Enduro rim.
    cheers, rynee
    I wouldn't say "it fits" in a general sense. It's possible that it may fit for some people, you'd just have to do your homework to see if there's enough room in the seat tube to accomodate it. It is fun getting the saddle so far out of the way like a trials bike, no doubt.
  71. #671
    Jun 2010
    What's the max insertion on a M Wreckoning? I'm thinking of a 9point8 at 175mm. Curious how close I could get to having it totally slammed down.
  72. #672
    Rocks belong
    For those of you slamming 175mm droppers into smaller frames, I'm kinda surprised you're not buzzing the saddle with the tire when the wheel is at full compression!
  73. #673
    Nov 2006
    I tried a 150 KS Lev on my small Wreckoning. It would have buzzed the underside of my seat at full compression.
  74. #674
    Oct 2015
    Why would a longer dropper cause a saddle buzz? The length of the dropper doesn't alter the position of the top of the seat tube, which is what limits how low the saddle can be.
    In other words, a fully inserted, fully compressed KS lev 150mm post will have the same saddle location as a fully inserted, fully compressed KS lev 125mm post. The only difference would be that the 150mm post will have a higher saddle position when the posts are fully extended. What am I missing?
  75. #675
    What am I missing?
    For the same rider [ie leg length] a 175mm dropper will be lower than a 150mm dropper at full compression hence more likely to come into contact with the rear tire. That's what they are getting at.
    Safe riding,
    Vik
    www.vikapproved.com
  76. #676
    Good point. I just installed it this past weekend and didn't hit anything big enough to bottom out. I'll air down the shock and check it out to be sure.
  77. #677
    Quote Originally Posted by jpease View Post
    The guys at Evil came up with 225mm as the max insertion depth on a Medium Wreck. IMHO, that's a very aggressive number. If you measure out the seat tube yourself, you'll see what I mean.
    As others have pointed out, there may be an interference issue between the saddle and rear tire. I'll check mine out ASAP and let you know. I was running just about min insertion on my 150, so in theory if I can't clear the rear tire at the bottom and full compression, it's probably unlikely that anyone else will (at least on a M frame).
  78. #678
    FWIW, when I aired down the shock I had 2Ē to spare to the bottom of the seat when there was 4Ē of exposed post from the seat tube collar to the top of the Lev Integraís collar. If thereís an elastomer bumper it could be tighter still.
  79. #679
    Sep 2014
    Quote Originally Posted by Dalas51 View Post
    late response but inside the rear triangle is kinda a design issue as there is not a lof of clearance and rocks really tear that area up cosmetically. I truly think Evil should have put something in there to protect the frame, if you are spending over 3k all that stuff should be worked out.
  80. #680
    Any New England riders out there? I am right between a med and large and looking to sit on one before I buy. I am located in Maine but travel around most of New England for work. You will be rewarded with some of your favorite Maine beer!
  81. #681
    Jun 2012
    Anyone know what is the largest tire you can fit out back on the Wreckoning maybe 2.5/2.7? Thanks.
  82. #682
    Jun 2015
    I get some minor rub with 2.3 dhr II double downs and with 2.4 dhr II exos. Its minor enough that some all mountain style proctors stopped the paint from getting scuffed.
  83. #683
    So any confirmed info out there about an updated Wreckoning yet? If so, what's the consensus on release date?
  84. #684
    Jun 2015
    I would guess theyíll wait one more year. The Wreckoning was a slow release and itís already up to date on the latest standards, which is why itís not on sale currently like the Insurgent. Itís also pretty smack in the middle regarding reach but next year will probably be a little behind so theyíll make it 2cm longer but keep the rest unchanged. Thatís what I think at least. Like the following MB.
  85. #685
    Jun 2015
    Yea I agree: reach, trunnion shock mount and color will be the only changes.
  86. #686
    Aug 2014
    Quote Originally Posted by Christoffer Du Rietz View Post
    It's not on sale because they don't have any to sell... in my size
    It takes half a joule more to accelerate Brass Nipples over Alloy Nipples on a 29er to 30kph.
  87. #687
    Reputation: grrrah's Avatar
    Quote Originally Posted by softbatch View Post
    We must be the same size.
    Just put in an order for Jan/Feb. Only change I really want is more rear tire clearance, but I can live with a Maxxis 2.4/2.5.
  88. #688
    Quote Originally Posted by grrrah View Post
    Which is?
  89. #689
    Reputation: smithcreek's Avatar
    Nov 2012
    You can pre-order? I'm waiting also.
  90. #690
    Jun 2015
    It took me awhile to come around, but I really like my wreckoning. The DSD tuned shock and Avalanche cartridge are huge complements to the bikeís ability.
  91. #691
    Which is?
    Large? I just noticed more of the other sizes are out now too.
    Quote Originally Posted by smithcreek View Post
    Well, paid for a backorder at Fanatik. They said I could cancel anytime before it ships (if something else better comes). They have 1/5/18 as the eta; Evil said February. We'll see if anything else pops up first.
  92. #692
    Large?
    Bummer. Was really hoping you weren't going to say that.
  93. #693
    Nov 2012
    Gotcha, I'm waiting on a full build straight from Evil and they said early Feb. I'm in Rhode Island. For the kind of riding I do during the winter it's either fat bike or short travel 29", so as long as they get them before Spring I'm good.
  94. #694
    Nov 2012
    You can order large Wreckonings from Evil as of last night. I assume that means they have them in stock and are shipping. Just pulled the trigger on an XO1 build.
  95. #695
    nice! Fanatik said they expect them in this week or next, so sounds right. They did move their ETA on their website back to 1/10. Not sure if that's a new date, or if they have enough pre-orders to cover the first batch, but can't wait!
  1. Evil Bikes: The Following Ė User Review
    By ducrider in forum Evil Bikes
    Last Post: 4 Days Ago, 08:15 AM
  2. Evil Wreckoning Build Pictures
    By tangrip9 in forum Evil Bikes
    Last Post: 5 Days Ago, 07:27 AM
  3. User Review: Nitefighter BT40S ( CAt Review )
    By Cat-man-do in forum Lights and Night Riding
    Last Post: 2 Weeks Ago, 07:38 AM
  4. Replies: 0
    Last Post: 10-30-2014, 12:11 AM
  5. Replies: 0
    Last Post: 05-02-2014, 01:35 PM
Members who have read this thread: 492
