Results 1 to 5 of 5
    Jul 2013
    Need help with rs lyrik 2-step
    Hi.
    I need your help. I have a 2009 RS lyrik 2-step mounted on my 2008 Specialized Pith Pro and I am not been able to set it up right. Can you give me some tips or guide lines?
    I fix choppers
    Reputation: HELLBELLY's Avatar
    You forking icehole...
    ...I have the same fork. It should have the approximate air pressures printed on the leg and the sag levels on the stanchion. I started with those and then adjusted it to taste. It took very little to get it where I liked it and I have not messed with it since I bolted it on over two years ago save checking the air pressure. Also try these...trailside tuning guide and the dual air tuning guide. Party.
    "Everything popular is wrong." -Oscar Wilde
    Jul 2013
    Hi Hellbelly.
    In the first place thanks 4 the reply
    Maybe my fork have something wrong cause with my current setting the fork feels too stiff and to get a 20% sag i only can put 65psi on it (i'm 176lbs weight) when i should use 95psi.
    My current settings are.
    LSC 8 clicks (from soft 2 hard)
    HSC 6 clicks (from soft 2 hard)
    Rebound 10 clicks (from slow 2 fast)
    I already took out the floodgate.
    I fix choppers
    The PSI recommendations are just that...recommendations. I cannot recall exactly what my settings are, but I am about 15 lbs heavier than you and I recall that I am running at least 20 PSI less than what is recommended. The Lyrik runs high in its travel meaning that you will not feel it sag much just sitting on it. However, on the trail it rides great. I get full travel and plenty of small bump compliance as well it's solid bottomless feel. I say go ride it and see how it feels without sweating the actually numbers. Now if you actually cannot get more air into it or something weird then send it to Suspension Experts (the best ATMO) and have them check it out.
    Jul 2013
    Many thanks 4 the help!!!!! Today i will ride it again and i'll try to set it up again.
  1. Lyrik 2-Step Question
    By neilether in forum Shocks and Suspension
    Last Post: 09-12-2012, 09:38 AM
  2. Lyrik 2 Step Problem
    By SmokeZR2 in forum Shocks and Suspension
    Last Post: 09-09-2012, 07:00 PM
  3. Lyrik 2-Step vs. Lyrik Solo Air?
    By myitch in forum Shocks and Suspension
    Last Post: 09-19-2011, 07:51 AM
  4. 2011 Lyrik 2-Step
    By bigmike9699 in forum Shocks and Suspension
    Last Post: 05-06-2011, 06:12 AM
  5. Lyrik 2-Step
    By Bad Knees in forum Shocks and Suspension
    Last Post: 03-07-2011, 06:17 AM
