    Riser bar (big rise) instead of flat bar for 24hr. Good idea?
    I've currently got a flat 600mm Scott pilot bar on my 26" Scott Scale which is great and gives a lovely climbing position. However I'm doing a 24hr in May and worrying about neck/shoulder pain in the second half of the race.
    I'm thinking that if I put a riser bar with a riser stem on then it'd give me a more comfortable 'sit up and beg' position.
    I'm not going for glory as I prefer xc racing, but just want to do a 24hr for the experience. Therefore all out speed is not that important, however finishing is!
    Any suggestions as to the amount of rise to add? I'll add a bit of width too (to approx 680mm) as that'll take some of the steering forces away.
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Re: Riser bar (big rise) instead of flat bar for 24hr. Good idea?
    The wider bar with a slight rise will be all you need imo. Along with a slightly shorter stem to make up for the extra width.
    I'm a mountain bike guide in southwest Utah
    That's going to put a lot more weight on your sit bones.
    No free lunch!
    Whining is not a strategy.
    Feral Roadie
    Reputation: bbense's Avatar
    May 2010
    I would not tweak your position w/o a lot of time in the saddle before the event. There's no free lunch when it comes to bike position. Every change has a consequence.
    I think your basic idea is solid, that you should probably have a slightly different position for 24hr vs XC , but if you have to spend as much time tweaking the 24hr position has you've spent on the XC position. If you don't want to invest that time, I'd just stick with your XC position unless it's obviously painful on longer training rides.
  1. Flat bar vs riser bar
    By dudesok in forum General Discussion
    Last Post: 11-20-2012, 10:14 AM
  2. Flat handle bar VS Riser?
    By 4nbstd in forum 29er Components
    Last Post: 07-14-2012, 06:45 PM
  3. Riser bar as a dropbar, good idea?
    By zonoskar in forum 29er Components
    Last Post: 03-09-2012, 02:40 PM
  4. Who's gone from flat bar to riser and why
    By pamt in forum General Discussion
    Last Post: 03-02-2012, 06:21 AM
  5. Flat bar or riser?
    By bridger in forum 29er Bikes
    Last Post: 01-07-2011, 08:49 AM
