    Good For You
    Reputation: The_Boy's Avatar
    Q about Sustained Energy...
    Some powdered mixes get slimy if you leave them mixed for a while (more than a day). I was wondering if Sustained Energy does this. I would like to prepare it the day before or two days before an event and not have it get slimy.
    Jun 2005
    If you keep it on ice you should not have a problem other than shaking up before you drink it to make sure it is mixed. I would try to keep it closer to one day ahead of the event rather than two. I have used mixed Sustained Energy that was 3-4days old as long as it was refridgerated. Even then it takes on a slightly different consistency. The fresher the better, but keeping it cold is the key. Good luck!
    "It's just that nobody likes Cornfish." francois
    Which way? Uphill.
    Reputation: nepbug's Avatar
    Sep 2004
    Quote Originally Posted by cornfish
    Yeah, keeping it refrigerated is key once it's mixed. You'll only make that mistake once, believe me. I haven't noticed a major difference in consistency if mixed a day ahead.
    Blog
    Just keep spinning. Just keep running. Just keep paddling.
    Just keep moving forward.
    SS Chimp
    Reputation: 32x18's Avatar
    Hammer Nutrition info on pre-mixing
    I have always avoided pre-mixing Sustained Energy after 1 particularly bad experience. I will take it in dry form and mix it when needed rather than pre-mix.
    all single...all the time
