Results 1 to 26 of 26
    Looking for a saddle for endurance as well as saving some weight.
    I could use some help on a saddle I have the stock fizik saddle that came on my giant advanced anthem 2013. Its just ok, not comfortable at all for endurance. I used to have a specialized saddle that was awesome and had very little cushion. (but I wont support specialized anymore, personal reasons) so I get high end bibs that have great padding. So I want light weight and comfort. I do a lot of xc racing plus long distance stuff. thanks
    Mr. Buck E. Fikes
    Reputation: Oh My Sack!'s Avatar
    I love my Kontact Saddle. No more perineal pressure or pain and it's like it isn't there when you're pedaling due to it's shape and skinny nose. Great 30 day money back guarantee if it doesn't work for you.
    Kontact Bicycle Saddle - Black - Kontact Bike
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Try Bontrager Evoke RXL carbon saddle. It was a wide, flat perch that is very comfortable for Endurance events. Weighs only 152g:
    Looking for a saddle for endurance as well as saving some weight.-rxxxl2.jpg
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    The Romin pro. 150 grams and comfortable as hell.
    Specialized Bicycle Components
    18 Focus Raven Lite
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Ergon SM3- the best/most comfortable saddle I've used.
    e
    Find an LBS that demos saddles. You leave a small deposit and get to try numerous different saddles, they might even measure your ass for you. 😬
    You down with entropy?
    Reputation: esilvassy's Avatar
    I personally like Selle SMP
    I have used these for 4 years now, several hundos and all the training for those.
    They have a wide variety of widths, many now have carbon rail options too.
    For starters get your ass measured. I had bikes that came with 135mm saddles and I always thought that was the size I needed but Then I started having problems real bad ones black & purple a$$ and I had to drop out of a race I was doing good in. I went to a shop and got measured and found out that I'm a 143mm. I also use a bib that the padding comes down more covering more of the area where my inner leg comes up and makes an ass of them self's )))
    Dickhouse
    Dec 2010
    Ergon SM3 all the way!
    I used to use Fizik saddles and thought I had found my match, yet still dealt with numbness in the nethers on long rides. When I switched to the Ergon SM3 the difference was night and day. I didn't know what a good saddle was until using the Ergon! The wide and flat rear section acts as a perfect perch for your sit bones. It is also a very versatile saddle. I find myself using at least three areas on the saddle, all comfortable. The nose is long and still shaped well to give you enough support when climbing something fierce. I also like that they offer different sizes and their saddle selector online. I would've traditionally gone with a Large size, but after getting measured I fit better on the Small, and it's a perfect fit.
    I've done many endurance and ultra-endurance races, and never have a sore bottom, not once.
    Something with wheels and brakes.
    92Fifty' Race Team
    Your Best Friend
    Reputation: Silentfoe's Avatar
    Another +1 for the Ergon SM3.
    I'm a mountain bike guide in southwest Utah
    Has anyone tried SQ LABS?
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by demondan View Post
    They look interesting.
    I currently ride Spech Romin's on all 4 bikes but might try the SM3 out.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Dec 2013
    I use the Fizik Ares. It is designed after the Antares but they chopped 30 mm off the nose to make it UCI compliant in TT races. I like that, as it hangs up on my bibs less when starting to pedal and getting back up on the saddle. I hate it when the nose of the saddle catches the back of my bibs. It weighs 164 grams on my scale and I bought it on chainlove for 75$ It has not yet seen an 8 hour ride and of course with saddles more than anything else, ymmv.
    Reputation: el_novato's Avatar
    Aug 2010
    i use sq labs work great but break on a very silly fall
    then I puted on a fizik arzione with it I had finished La Ruta on costa rica el reto del quetzal on guatemala (4 days) and two full seasons of the local marathon championship (10 races of 100 kms) I love it and still good as new
    Quote Originally Posted by el_novato View Post
    Seems like you've had better luck than me. I use the Arione also because its the most comfortable saddle ever, but I've broken two of them, they snap right through the middle of the shell. I've also broken an Antares in the same spot. I keep buying them though because they're so comfortable, the flex of the shell makes it feel like I've got ~1/4 of suspension on my hardtail. I also like how the saddle gently gets wider, there's not a "shoulder" going from the nose to the rear of the saddle. It makes it easier to get behind the saddle when you need to get your weight back.
    What model SQ Labs did you break?
    Reputation: sjfsr-shep's Avatar
    Aug 2013
    I have heard good things about the Specialized Romin. Thinking about trying one.
    Daniel the Dog
    I like Fizik saddles but I break them. I broke a Fizik Aliante 75% of the way through the a 100 mile race last year. Luckily the awesome volunteer fixed it by clamping on the break spot. It worked and I finished.
    Happy Trails
    Reputation: Scott In MD's Avatar
    Is your saddle a Tundra? I thought the Tundra on my C'dale was the most uncomfortable saddle ever. I swapped it for a ProLogo Nago and ended up buying two more for my other bikes.
    I use the same type of saddle I've always used (it just fits). the 1990 Flite. use it on road and MTB. Just over 230 grams. But I can be on it for an entire day and I'm fine. Little sore, but would be sitting on anything that long.
    If you can be blissfully ignorant to the notion that something is impossible, then you might surprise yourself. -- Andrea138
    Reputation: DITD's Avatar
    Nov 2012
    San Marco Rolls.... Get yourself one and you'll never have saddle issues again..
    Fat & Single
    Just ordered myself a Ergon SM3, will see how it goes for 6hr+ rides, someone says to me "if you ride a bike for 6-9hrs you can expect a tender ass", while the Spech romins i have just swapped over to are really good for under 6 hrs, im still open to try others.
    Will see how the Ergon goes.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Reputation: June Bug's Avatar
    I'll be trying one out in the next few weeks. They have instructions on how to do the butt-o-meter measurement at home; one must know this to order the correct width saddle. They do have a bewildering array of saddles, but I may call them when it is time to narrow it down to one or two.
    Fat & Single
    I have 2 x 3h rides in on the new Ergon, feels a bit spongey but no sit bone pain yet. The Romin Pro i took off is the same though.... need to crack a 6h ride out before drawing conclusions.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Cheesiest
    Reputation: intheways's Avatar
    I wanted to like the SM3, but the squared off corners rubbed my thighs. Thankfully there are many options
    "Paved roads...just another example of needless government spending"—paraphrased from rhino_adv
    Grip it and rip it.
    Reputation: Damitletsride!'s Avatar
    A saddle should be the last place you should think about saving weight imo. Unless there is a saddle you already know you really like that comes in a carbon or lightweight version. I like the Fizik Gobi, does the job for me but everyone is different.
    "Pain is inevitable, suffering is optional"
    michaelmblog.wordpress.com
  1. Ti Bolts for Rotor - Weight Saving?
    By phlegm in forum Weight Weenies
    Last Post: 05-18-2014, 06:53 PM
  2. weight saving going from xx/xo to xx1/x01 ?
    By Norwayrider in forum Weight Weenies
    Last Post: 07-04-2013, 01:40 PM
  3. Replies: 12
    Last Post: 03-04-2013, 12:48 PM
  4. Best price to weight saving ratio parts ?
    By David C in forum Weight Weenies
    Last Post: 08-23-2011, 02:28 AM
  5. MBA recommends saving weight by switching top caps?
    By arrover in forum Weight Weenies
    Last Post: 03-10-2011, 07:33 PM
