Results 1 to 3 of 3
    aji
    aji is offline
    what thread lock do you use for to lock the screws
    im going to remove the chainstay of my moment for servicing, what thread lock do you guys use if at all to re-tighten the bolts on the chainstays and the bolts near the cranks?
    thanks
    bi_ke
    Guest
    Quote Originally Posted by aji
    thanks
    Blue
    One Gear
    Reputation: .40AET's Avatar
    Blue is good. Beyond that, you could have problems getting them out again. Red needs a heat gun and green is for f'n ever. Loktite makes a thread prep that helps a lot. Make sure the treads are clean and degreased, then use the thread prep.
