Results 1 to 11 of 11
    Truth: how to tell model year?
    I bought it on e-Bay; supposedly a 2004 model. But the serial #s on the frame and rear triangle begin w/ "03". Does this mean it's not a 2004? Is there a difference between frames made these two years?
    ...one more clue
    I hit SUBMIT too soon. It has an AVA R shock on it. I'm not sure whether that helps distinguish the model year 03 versus 04.
    zeb
    zeb is offline
    two first numbers are yearmodel identification numbers :03 was made in 2003, and 04 is 2004 and so on.
    I think the frames betwen 03 and 04 are the same , differences would be between non propedal and propedal equipped AVA shock ( i think )
    Sep 2004
    Quote Originally Posted by Jaydg
    Longer linkage on the 04 and longer shock as well which is supposed to offer more progessive smother suspension.
    I have an '04 Truth and the frames serial number starts with an 04 and the rear is 03. So it might have been the norm in 04 or at least for the early models. I purchased mine in April or May of '04.
    Reputation: David Campbell's Avatar
    Nov 2006
    03 or 04 . . . somewhere in 04 or 05 is when they changed the eye to eye length of the rear shock (and the rocker and whatever else was required to keep the ICT working right) to 7.875" from 6.5" . The larger air volume makes for smoother "shockage" So . . . prior to the rear end change, they were the same (at least between 03 and 04). If your shock is 7.875 long, then you have the newer rear design.
    Hope that helps
    We're going down WHAT??
    Reputation: jonsocal's Avatar
    No TRUE model years on Ells bikes
    At least that is what i was told. I was speaking to a former Ellsworth employee and he told me that there are no year to year designations to any of the Ellsworth bikes. The '05 and '06 Moments are exactly the same. '07 they were different (asym chain stays). I am sure the Truth is the same.
    "Political correctness is tyranny with manners."
    - Charlton Heston
    Reputation: EVERYUSERNAMEISTAKEN's Avatar
    Quote Originally Posted by David Campbell
    Hope that helps
    Your avatar looks brutal!
    Reputation: barratana's Avatar
    Oct 2007
    Hi,
    How can I check my Truth year, shoul I look for the frame or rear triangle?
    Wich suspension should I use? Diferent years use diferent suspensions lenght´s?
    Rides like wrecking ball
    Reputation: Bulldog's Avatar
    Quote Originally Posted by grbadave
    Where is it broken?
    LOL - I kill me.
    Sorry, back to Homerland.
    Quote Originally Posted by Hesh to Steel
    With people liking mongoose and trek bikes now, what's next in this crazy world? People disliking the bottlerocket?!
