Results 1 to 6 of 6
    Is an SPV 3 way a good choice for an Id?
    I would like to go for an air shock on my Id and I have found a good second hand unit.
    Itīs a 7.5"x 2" 2004 model.
    Thanks.
    Feb 2005
    This would be a California Id
    The SPV Swinger should fit your Id fine but the standard Id calls for a 7.875" eye to eye shock. The 7.5" eye to eye shock will lower your bottom bracket down a bit and slacken the head angle too. This could be a good thing if you ride where more stability at speed will benefit you. Not so good if you ride where roots and rock clearance is an issue.
    Reputation: slowrider's Avatar
    3 way
    I used one on a 5 Spot and it worked well for a while but it didn't hold up well.
    Reputation: Mike Brown's Avatar
    Make sure this is a recommended shock for the frame per Ellsworth, otherwise using it could void any warranty- would be the same for ANY BIKE COMPANY, NOT A JAB AT THE E WARRANTY! Please do not take it as such....Peace, Mike
    Swinger air 3 way is ok!
    Thanks for yor advice! Just checked an ellsworth 05 catalogue and the swinger 3-way comes as one of three shock options.
    Itīs allready mounted on the bike waiting for the saturdays ride.
    trail fairy
    Get the fox RP3 or the Ellsworth customed tuned fox, it is something else on the ID
    I would'nt waste my time with anything else this shock rocks on this frame period!
  1. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  2. Scott YZ2, a good choice...
    By cajgeers in forum Bike and Frame discussion
    Last Post: 05-04-2004, 03:44 PM
  3. '04 SPV 3 Way Compatibility/Bushing Help?
    By ilpescatore in forum Shocks and Suspension
    Last Post: 03-04-2004, 08:55 PM
