Results 1 to 6 of 6
    Sizing problem w/ID, HELP!!!!
    I have a brand new ID California Edition. I absolutly love the bike , but I can't get it to fit. 30 mm spacers,120 mm - 10 deg stem w/125 travel fork. 10 in. of seatpost atleast. It feels small to me. Real small. Any ideas ??? Much appreciated.
    Rolling
    Reputation: lidarman's Avatar
    Quote Originally Posted by BubbaTime
    So what size is bike and what size are you?...All that is confusing without the other info.
    Size
    Large frame. 6'1 1/2 proportionate.
    TT 24.25
    ST 19
    HT 4.75
    Rolling
    What seatpost are you using? Is it a standard type or the two-bolt Thomson type? IF so, you might want a setback post on that...get the seat back so at 3 o'clock your knee is over the pedal center.
    I can't see why the bike feels so small..With all those spacers on the steerer, the long headtube and the large angle in your stem, you must be pretty upright--maybe that's it. You might have long enough arms you can do without he spacers and use a zero rise stem. I have no spacers and 5 deg rise on a short stem-- and my bar height lower than my seat about an inch (medium frame)
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    I don't ride an ID, but it sounds like you have too much post and too much stem rise. 10" of post on a large frame at 6'1" or 6'2" is too much. If you have around a 34" inseam, the saddle height from the pedal(5 o'clock position)to the top of the saddle(center portion) should be around 38". I would try ditching the spacers or putting them above the stem and see how it feels. I'm 6'2" with a 34" inseam and I ride a large Truth(24.25 TT), I run the above saddle height with a 130mm/5 degree stem and a 5mm spacer-perfect fit. Also, with the 5" fork and 10 degree stem, try a riser bar w/ less than 2" rise.
    Got the fix !!!
    20 mm spacers and 120 * 10 stem. AWESOME !!!
    Thanks everyone..
  1. Help! FSR sizing dilema...
    By Mingsta in forum Specialized
    Last Post: 03-31-2004, 04:30 PM
  2. heckler sizing
    By antm in forum Santa Cruz
    Last Post: 03-22-2004, 02:19 PM
  3. shimano 11 tooth cog problem
    By toad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2004, 03:21 PM
  4. Avid mechs - housing question / problem...
    By DSR in forum Brake Time
    Last Post: 03-03-2004, 12:29 AM
  5. Sugar 3+ Drive Train problem / question HELP!
    By mattstep in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-10-2004, 01:42 PM
