Results 1 to 16 of 16
    Team Sanchez
    Reputation: El Chingon's Avatar
    Questions for Rogue owners
    Can you help me out?
    1. 73mm BB, but what spindle length if I wanted to run an older XT crankset?
    2. What is the wheelspacing in the rear, and is it thru axle?
    3. Does this frame have ISCG tabs?
    4. Seat tube length on the Large frame?
    Thanks in advance!
    Leash Law Enforcer
    Reputation: Pinch's Avatar
    Don't know the answer to your questions, but that gold Hadley hub sure would look nice on a black or smoke Rogue!
    Not sure re: BB, I've got X-type external BB thingy.
    rear wheel spacing is 135mm (I use a Hope Pro-2 bolt through with 12mm axle)
    ISCG mount present (I've used E13-DRS)
    Seat tube length is almost, if not, identical to small frame. I had to get a VERY long Thomson post (410mm) to get the correct height. What this means though, is that the top tube is well out of the way when riding.
    cheers
    trail fairy
    <hr style="color: rgb(183, 183, 183);" size="1"> Can you help me out?
    Thanks in advance!
    Sheesh
    MAXXIS 4C!
    Helmet for your neck
    Leatt FAQs
    Team Sanchez
    Just doing my research boys! The Highline is still at the top of a very short list.
    trail fairy
    MAXXIS 4C!
    Leatt FAQs
    "Its All Good"
    Reputation: Whafe's Avatar
    Quote Originally Posted by trailadvent
    Sheeeeessssshhhhhhhhh trailadvent, I am beginning to think you are coming back home to Ellsworth.............. Am thinking you have withdrawl symptoms.............
    trail fairy
    Ahh no I'm on the 2 Ts for some time for now though I hardly touch the Spot these days the RFX is getting all the attention, somehow Ive become the freerider that was always trying to get out
    By that I mean just riding for fun do it all no boundaries except my own limits
    yeahhaaaaa
    MAXXIS 4C!
    Leatt FAQs
    "Its All Good"
    yeahhaaaaa
    All good, trust you buggers to start fully into that style of riding once I have gone !!!!!!!!!!
    All good though, we will hook up again in the near future for some rides.... Whistler is calling you, make sure you answer TA....
    trail fairy
    Tis true funny how things develop though Im leading that charge at the mo momentus is still unsure about it all but hes going great Spotz(Mudgy) is still very XC though we got him a full face helmet the other day and knee pads
    Definitely all on just scedule it at the same time as the Homer conevention in September so I can work both in hehe
    MAXXIS 4C!
    Leatt FAQs
    Reputation: Id Rider's Avatar
    I 'll help you with your questions...
    73mm shell and a 113 spindle should do the trick (maybe a 118 if you need to run some kind of chainguide system...might have to do a little experimenting. I run SAINT cranks on mine with X-Type BB with no chainguide and front derailluer.).
    The rear end is 135mm spacing and the frame is available with either a 12mm thru axle (get the aluminum Hadley version) or a QR rear end that uses a spacer/reducer type setup.
    Yes, it has ISCG tabs.
    All sizes of the Rogue (of which there only two) have 17" seat tubes; only the TT length changes.
    The water bottle mounts are disappearing mid-year (FYI).
    I have been riding one for about a year and half (got a pre-production prototype) and it is awesome. Stiff, uber-plush and climbs like an Ellsworth...
    Let me know if you need anything else -
    - Mondo
    mondo@thepathbikeshop.com
    Sold the Id; riding the Rogue, saving for an Evolve...I ride, I know.
    http://www.thepathbikeshop.com
    Team Sanchez
    Thanks Mondo! My only concern then for someone like me, is that I"m 6'2 with long legs. 34 inch inseam. I"ll be showing an obscene amount of seatpost when trail riding.
    Time is not a road.
    Reputation: chad1433's Avatar
    Quote Originally Posted by El Chingon
    Not to mention that you'd probably lose your Homer Club card if you did buy one!
    "Its All Good"
    Quote Originally Posted by chad1433
    Be a lost homer with no card and a homeless dude from team Sanchez....
    Yeah, if you have a 410mm post or longer, it might look weird, but will work. I ride mine with a pretty fair amount of exposed post when climbing and it's OK.
    Mondo
    Team Sanchez
    I"m out! Looks like I"m gonna hang tight for the XL Highline. Thanks for all the replys.
