Page 1 of 2 12 LastLast
Results 1 to 25 of 48
    Pics of YOUR Moments?
    Hey guys, I'm considering a Moment and would like to see some pics and set-ups. THANKS in advance to any/all replies!!!
    all your base
    Reputation: primefocus's Avatar
    Feb 2007
    woot!
    [IMG]moment mkIII[/IMG][IMG]Photobucket[/IMG]
    funfunfun!
    THANKS! That's exactly what I was looking for
    Owner, Spoke Apparel
    Reputation: meneone's Avatar
    I'll post better pictures. Shooting some this week hopefully.
    www.SpokeApparel.com
    T-Shirts for Mountain Bikers
    Here you go man. Better pics of my 2006 Moment build......as well as details....
    Wheels – I9 Freeride Hubs (silver), DT Swiss 4.1 Rims
    Saddle – WTB Laser V, Grey
    Post – Thompson Elite
    Cranks – Raceface Atlas
    Bottom Bracket – Chris King
    Cassette – Sram PG-990
    Brakes -Avid Juicy Seven
    Tires – Maxxis ADvantage 2.5″
    Bars – Raceface Deus XC
    Stem – Tompson Elite, 110 mm, 20 Degree Rise
    Headset – Chris King
    Fork – Fox Talas 36 RC2
    Shock – Fox DHX Air 5.0
    Shifters – Sram X9
    Derailuers – Sram X9
    MTB SOCAL
    Reputation: yangpei's Avatar
    Here's my 08 Moment with 36 TALAS fork. I'm running X0 shifters / derailleur and XTR crankset. The wheels are King / Mavic. I think it weighs about 31.5 lbs, if I remember correctly.
    Kokopelli Racing
    "Curb drops to flat, or curb drops to transition? There's a BIG difference there." Qfactor03
    nice pinky man
    all your base
    Feb 2007
    you should see his brownie
    Reputation: bpnic's Avatar
    Aug 2005
    My old Moment (v 1.5) here, I'll post the newer Moment later (v 1.0)
    I've learned most everything the hard way.
    Well, here's my Moment. 31.5 lbs. The only thing I might change on it is the rear shock. I might go coil....
    Attached Thumbnails Attached Thumbnails Pics of YOUR Moments?-pict0002.jpg.jpeg
    Does this help?
    My buddy:
    2009 Medium Smoke Anodized.
    Wheels – Hope Pro2 Hubs (silver), Mavic 819 Rims
    Saddle – Syncros AM
    Post – Gravity Dropper
    Cranks & BB – Shimano XT
    Cassette – Sram PG-980
    Brakes - Formula Oro K24, 180 mm (front), 160 mm (rear) rotors
    Tires – Continental Mountain King UST 2.4
    Bars – Syncros Bulk
    Stem – Tompson Elite, 70 mm, 0 Degree Rise
    Headset – FSA Xtreme Pro
    Shock – Fox DHX Air 4.0
    Shifters – Sram X9
    Derailleurs – Sram X9 (rear), Shimano XT (front)
    Weight - 32 lbs
    Reputation: F.N.G's Avatar
    Nice!!!
    Looks good! Good luck with those Formulas. I had the same ones on mine and ended up switching to Saints. They screamed like mother!
    Reputation: Jimba's Avatar
    Hey all, I've been diggin' the Moment for a while and have recently been seriously considering one to replace my Chumba XCL. It's a nice bike that I'm not totally dissatisfied with, but I've broken the seat stay once already... guess I'm looking for a bit more.
    I have a quick question for all you running 36s out there. What's the BB height when equipped with this fork? I may end up running a coil shock matched to a new Manitou Travis 150 that I have, but I'm a little concerned because of the geometry numbers listed on the website with what I would imagine is a 32? Let me know, thanks!
    The website states 14.2 inches with a 150mm fork. The extra 20mm axle crown height of the 36 raises it another .2inch.
    On paper 14.4 inch is really high for this amount of travel but in reality it does not seem to be detromental to the cornering of the Moment.
    Of course the height/profile of the tyres makes a difference and the amount of sag makes a big difference too. I tend to run a lot of sag on my bikes (30% on My Moment), I like the way the rear tracks the ground when set up that way. In the corners the bike compresses for loads of grip and stability.
    Thanks for the quick response Nsynk! It's interesting that you say the geo numbers are measured with a 150mm fork because what I see on the website is a static fork length of 520.7mm A2C. The A2C length on my Travis is the same as most 160mm forks at 545mm which is what causes my concern.
    Seems to me that increasing the fork length by nearly an inch would raise the bottom bracket by a good half inch with changes in the head & seat tube angles of about 1 degree. You raised a good point about sag and tire profile, but with my considerations I think any other changes to these numbers would be negligible.
    So with a presumed static BB height of ~14.7" and running roughly 28-30% sag, I should get a sagged BB height of about 13.7"... does that sound about right? This would be just under an inch higher than my XCL, and while not all bad, it would take some getting used to. I'll tell you one thing, pedal smacks on technical climbs would NOT be missed for sure!
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    Wouldn't 30% sag amount to around 2", at both ends of the bike, dropping the BB 2" and not just one?
    After calculating it I came up with about 1.8", so yeah you're right. Two tenths would be splitting hairs, and BTW Manitou for whatever reason measures their shock stroke at 56mm. Sounds even better yet!
    don't worry about bb height with our travis. 1 inch up front doesn't translate into 1 inch increased bb height, more likely less than 1/2 inch, which shouldn't cause any concern.
    I don't think the BB would be raised by as much as 1/2 inch probably 1/4 to 1/3 inch. If you think that the pivot point for rasing the front is actually the rear axle you could work it out using trigonmetry. With the points being the rear axle and the original top of the crown and the new top of the crown. The crown top points are only an inch apart and a long way from the point at the axle. Creating a long very thin triangle. The height of the triangle as it passes the bb will be the increased height of the BB. I recon the BB height is more like 14.4 , Which is still 1/2 inch to 3/4 inch higher than most AM bikes with 6'sh inches of travel.
    Sagged would be about 13.5, pretty ball park I think
    As an aside. I have considered running a 190 x 57 mm shock. They used to be quite common (Orange Patriot fro example). That would lower the BB by 3/4 inch and slacken the angles by 1 1/2 degrees. I doubt the warranty would remain valid but it might be worth it for the excellent geometry.
    local trails rider
    Aug 2005
    Quote Originally Posted by Nsynk
    Is there rear tyre to seat tube clearance for that?
    I dont know and also how about the shock to frame clearance. Especially with a piggy back shock?
Hot Deals
Contests
Latest Mountain Bike Articles
