Results 1 to 13 of 13
    New to me Epiphany
    I just built up this 2008 Epiphany and cant wait to take it for a spin this weekend. Yes I realize the steer tube is stupid long, and yes I know Im missing the front derailleur...what kind does it take anyway? Any recommendations?
    Two questions...
    Ive got a monarch RT3 mid tune and ellsworth tuned Float R. Floodgate or no floodgate?
    Anyone else running their Epiphany as a 1x9? I really enjoy it on my other bike.
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    The front der you need is the high clamp style
    do you happen to know the clamp diameter?
    LBS Manager
    Most of the newer ones come with shims for any size
    Mar 2005
    Quote Originally Posted by huevos View Post
    Two questions...
    Sram X-Gen, not so good.
    Are those the old magnesium rockers?
    Kind of a yellowish hue...pretty sure the are magnesium. Should I be worried, I ride xc.
    Mar 2005
    Maybe, Ellsworth recalled the original magnesium rockers because they broke...check back to the original threads in this forum a few years ago after they were introduced.
    WARNING epiphany owners-broken rocker arm
    Update on Epiphany rocker issue...
    The good ones will have serial numbers stamped on the inside of the re engineered rockers...if you don't have the serial numbers I'd contact Ellsworth and try to get an RO and a replacement.
    Not being the original owner of a bike that's out of warranty shouldn't be an issue as this is a serious safety concern and they should still honour the recall.
    Good luck.
    It is one of the later mag rockers with the serial numbers. This appears to be one of the later frames and rockers. Hopefully things hold together. I saw one of these threads earlier.
    looking good, it will provide you with many years/miles of enjoyment
    Mar 2006
    No floodgate! You really don't need it.
    Quote Originally Posted by outside! View Post
    Okay, Ill try the float again. I tried it for one ride, it felt great going down, but awful going up. Am I the only one that thinks the torque numbers are really high on these bolts?
    Mar 2006
    It may depend on your climbing style. I am mostly a granny gear, sit and spin type climber. Having said that, the times that I am in the wrong gear and have to stand and mash, the front fork moves around more than the rear suspension and whatever movement the rear has seems to increase traction. The only time I lock the rear is when I am climbing on pavement. I never use the platform setting on my rear shock.
    fair enough, it's certainly worth a try.
  1. My New Epiphany
    By gone2vegas in forum Ellsworth
    Last Post: 07-26-2009, 07:21 PM
  2. Epiphany Q's
    By moomin in forum Ellsworth
    Last Post: 05-05-2009, 10:05 PM
  3. Fox F-120 on an Epiphany???
    By kbell in forum Ellsworth
    Last Post: 02-02-2008, 11:34 AM
  4. Fox DHX 5.0 on an Epiphany?
    By Luke454 in forum Ellsworth
    Last Post: 04-22-2007, 12:29 PM
  5. Epiphany for a Big Guy??
    By cgreg in forum Ellsworth
    Last Post: 07-13-2006, 01:41 PM
