Results 1 to 3 of 3
    Reputation: TNT-Spot's Avatar
    Moment DHX-Air Shock Question
    Hi! Just want to know why is the DHX-Air shocks on the MOMENT are installed the other way? Can it be installed the normal manner with valve on top? For the DHX-Coil it's installed on that way.
    Custom User Title
    Reputation: coldsteele's Avatar
    the air valve on the main chamber interferes with the rocker arm.
    Team MOJO Wheels.
    Banjo Fitting
    Quote Originally Posted by coldsteele
    So, a Banjo Fiiting will do the trick. I hope Ellsworth will put it on their Moment frames equipped with a DHX-Air. It looks better with the Air-valve on the top.
    Thanks for your reply.
