Results 1 to 11 of 11
    Maybe stupid question: 6pack-Rogue
    Hi maybe it,s a stupid question but if I want convert my 2005 6pack 135mm QR CK rear hub to 135mm 12mm t/axle like the Rogue what I have to do , switck the rear parts of the pack for these of the rogue , posible or not .?
    on the pack I have 7.5 x2.0 dhx5 shock but keeping the rockers it,s ok the problem is for the rear ???????????????????????????
    locked - time out
    Reputation: TIMBERRR's Avatar
    Feb 2006
    FInd a guy with a rogue. Make friends. Play frankenbike to see if the rear ends are compatible. I'm thinking NO but heah, It's worth a try in the name of bikedom.
    locked - time out
    Feb 2006
    How the heck did I post twice? OPPS Sorry.
    zeb
    zeb is offline
    It wont work because of different bearingsystem on pivots, even if you would change both chain and seatstays.
    Time is not a road.
    Reputation: chad1433's Avatar
    Is the rear spacing the same? I would think the Rogue would be 150mm.
    Got Rogued!
    Reputation: raceimp's Avatar
    Mmmmm... Actually, I'm for the experimentation thing, but in this case, I think it will create a mutant! Messing with species is not always good, unless you're prepared for Apocaliptic views!!!
    In a less dramatic minding, I would really like to know if it works, 'cause a mutant thing is an evolution to the perfection... Cross the breeds, they've said!
    siinga did a goood job with his Frankenfork... I realy like those stories.
    Ellsworth Moment / Ellsworth Rogue / Rocky Mountain Vertex / KHS SS
    thats right living legend
    Reputation: blackagness's Avatar
    Mar 2005
    This thread is making me throwup in my mouth a little.
    It just seems wrong somehow? Man should not atempt to play GAWD!
    Can't stop, Won't stop.
    Got Rogued!
    @ blackagness: By the way, it was a joke... Sorry if I sounded serious. But I have to agree that the frankenfork project of sinnga was a little tempting.
    MTB SOCAL
    Reputation: yangpei's Avatar
    Quote Originally Posted by chad1433
    I'm pretty sure my Rogue has 135mm rear spacing with a 12mm thruaxle. I'm not sure if the new ones are different.
    Kokopelli Racing
    "Curb drops to flat, or curb drops to transition? There's a BIG difference there." Qfactor03
    convertion
    For sure the rear spacing is 135mm ,I have to check the tire clearance.
    Got Rogued!
    Same thing here... 135mm with 12mm axle.
