Results 1 to 10 of 10
    Reputation: vibiker's Avatar
    New question here. Id rear tire fit question
    Anyone try mounting a Panaracer FR 2.4 on the back of an Id? If so, does it fit?
    Or how about a Maxxis Mobster/High Roller 2.35?
    BTW, got the first question answered here:
    http://forums.mtbr.com/showthread.ph...38788#poststop
    Drugstore Trailrider
    Reputation: papajohn's Avatar
    Quote Originally Posted by vibiker
    I have the Panaracer FR 2.4 on an Intense, and there is no way it would fit on my Id. On my Id I am currently using a Geax Sturdy 2.25 and it comes within a mm or two of rubbing the chain stays.
    There was a thread about this issue several months ago, you might try to search for it. I can't understand why Ellsworth made a free-ride bike that has such limited space for the rear tire.
    John
    Body Armor--Don't Leave Home Without It!
    Custom User Title
    Reputation: coldsteele's Avatar
    Quote Originally Posted by papajohn
    John
    The ID is not actually a FR bike. But i do have a Conti vertical pro 2.3 (which is the carcus not the knob with) and I have plenty of room (1/4 in around). If the Panaracer is measured to the outside of the knobs you might be ok. you might still have some rub until the knobs get worn down.
    My ID is an '02 I dont know if the clearance has changed through the years.
    Ologist
    Reputation: Valhalla's Avatar
    I put a Wierwolf 2.5 on the back with low pressure and didn't find any rubbing - clearance was minimal. I did replace it with a 2.3 though.
    Fyi
    For anyone else interested, I ended up putting an IRC Kujo DH 2.35 and it worked great. A very slight amount of rubbing on the edge of the front derailuer when in the small chain ring. The big red sidewalls look kind of ugly, but oh well.
    Custom User Title
    Quote Originally Posted by Valhalla
    The 2.3 is what is going on my bike and I will keep the 2.5 on front. I am not going to reverse the direction like some do.
    Tire Fit for Id
    I've run 2.3 Conti and 2.4 WTB Mutos, both are close but stay away from mud with either one.
    Another local rider uses the 2.4 you asked about but those are real close, he went back to the 2.1 Fire XC for the rear.
    dan996tt
    Guest
    Rear Tire Fit - ID
    Anyone here fit a Kenda Nevagul 2.35 on the back of an ID?
    After speaking to a few members on this board, I am interested in going with a Kenda BG/Nevagul combo, with BG 2.1 F / Nevagul 2.35 R. Anybody recommed against this setup?
    Thanks,
    Dan
    Reputation: wXman's Avatar
    nevegal/ID
    i run my ID for most situations with a WTB Timberwolf 2.5 DH casing, up front and a Mutano 2.35 in the back...unless I'm gonna do a lot of climbing, then I put Mutanos front and rear. I just rode Downieville last Saturday with it in the latter setup and it was s-k-e-t-c-h-y on the more technical downhill sections. I would have LOVED to have had that Twolf on there.
    However, I had a Nevegal on the rear and the bike handled absolutely awesome with that tire. Waaaaay better handling on the DH than the Mutano, but DAMN slow rolling on the climbs...very noticable (Of course, that Timberwolf up front ain't exactly light or fast rolling ) Only problem...it rubbed the chainstay yoke...quite a bit, depending on psi in the tire. That would be my perfect setup though if it didn't - Twolf up front, Nevegal in rear....that Kenda is an awesome tire for the trails here in NorCal
    "Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure or nothing." - Helen Keller
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. Rear Tire question for Norcal/SoCal Riders
    By longboarder9 in forum Wheels and Tires
    Last Post: 06-05-2004, 02:41 PM
  3. Front size vs rear size tire question
    By mtnbikerx in forum Wheels and Tires
    Last Post: 05-08-2004, 10:33 PM
  4. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  5. Biggest rear tire for the Superlight?
    By Earthpig in forum Santa Cruz
    Last Post: 02-12-2004, 12:20 PM
