Results 1 to 3 of 3
    Slow and Old
    Reputation: Timmy S's Avatar
    ID Disc Brake Issue...
    I am the original owner of a 2002 Ellsworth ID. I am now installing Shimano XT disc brakes (I had Avid "V" brakes before) and have run into an issue with the rear seat/brake stay and interference with the brake adaptor. The top of the Shimano brake adaptor hits the weld at the junction of the stay and the bikes disc brake adaptor and reinforcement.
    (I vaguely remember others with this issue) What to do? Grind off part of the Shimano adapter? Will the adaptor then still be stong enough? Or I understand Ellsworth makes a disc brake specific stay for this bike. Will this solve the problem? Thanks for your reply.
    Tim
    Reputation: Mike Brown's Avatar
    Not that this helps directly with your issue, but whatever you do, make sure that you face the disc brake mounts. Otherwise, things will not sit right. Peace, Mike
    Rolling
    Reputation: lidarman's Avatar
    IF you only have to grind a little, you will probably be fine since I'm sure there is plenty of safety factor in the size of the adaptor. This is especially true if it's the end where the bolt threads in.
    Quote Originally Posted by Timmy S
    Tim
  1. Adaptor for disc brake mouting on forks?
    By dawgcatching in forum Brake Time
    Last Post: 12-25-2004, 12:17 PM
  2. Deore disc brake with CODA discs?
    By nusbus in forum General Discussion
    Last Post: 07-09-2004, 06:42 AM
  3. deore discs?
    By xisaacx in forum Brake Time
    Last Post: 07-06-2004, 03:44 PM
  4. Surly 1x1 and Avid mechanical disc brake issues...
    By pennstatebiker in forum Singlespeed
    Last Post: 05-16-2004, 04:54 PM
  5. Avid road disc brake for mtb
    By K2footsrgn in forum Brake Time
    Last Post: 02-17-2004, 01:54 PM
