Results 1 to 3 of 3
    Help with Epiphany Build
    Last year I picked up an epiphany frame from pricepoint and a marzocchi 55 fork and I'm finally getting around to building it up. This is my first build and I'm looking for some feedback if the parts I have picked out are going to work.
    There may be some better parts, but these are what I have picked out at the moment that I can get the best prices on. This is just a backup bike that will see occasionaly use.
    Race Face Turbine Riser Handlebar, 31.8 x 725mm 3/4"
    Race Face Turbine Stem, 60mm +/- 6 degree
    Race Face 10-Speed Evolve Chainring Set, 104mm 24/32/42
    Shimano XT M785B Pre-Bled Rear Disc Brake Kit Metal Pad 1700mm Hose
    Shimano XT M785B Pre-Bled Front Disc Brake Kit Metal Pad 1000mm Hose
    Shimano XT RT86S 160mm 6-Bolt IceTech Disc Brake Rotor
    Shimano XT M771 10-Speed 11-36t Cassette
    Race Face Ride XC Seatpost, 27.2 x 375mm
    Shimano XT RT81M 180mm Centerlock IceTech Disc Brake Rotor
    Shimano XT M786-GS 10-Speed Medium Cage Shadow+ Rear Derailleur Shimano XT M780 2/3 x 10-Speed Shifter Set
    Sun Ringle Charger Pro Wheelset 26" 9mm/QR15/QR20
    *Below are the specs on the wheelset
    Cassette Body Type: Shimano 9/10/SRAM
    Front Axle Type: 15mm Thru , 20mm Thru , 9x1
    Front Hub Spacing (mm): 100 mm
    Front Wheel Type: Mountain
    Hub Drilling (spokes): 24 spokes
    Hub/Brake Compatibility: 6-Bolt Disc
    ISO Diameter: 559 / 26" mtn
    Internal Rim Width (mm): 28 mm
    Material: Alloy
    Rear Axle Type: 10x1
    Rear Hub Spacing (mm): 135 mm
    Rim: Sun Ringle Charger
    Spoke Info: Wheelsmith Straight Pull
    Tire Type: Tubeless Compatible
    Valve: Presta
    Weight: 1699 g
    Wheel Size: 26
    If you're running a triple with an 11-36 cassette you definitely need a long cage rear derailleur. In fact, your 42-32-24 crankset and 11-36 cassette are right at the maximum 43 tooth capacity of the XT long cage derailleur [(36-11) + (42-24) = 43]. Also, why did you get one centerlock rotor and one six-bolt rotor? You need both rotors to be six-bolts.
    Also, don't forget a chain, grips, saddle, pedals and tires!
    Quote Originally Posted by Schwa72 View Post
    Thank you very much. The long vs. short cage is something I was concerned about. As far as the rotors, just not paying attention. I'll correct both when I place my order.
  1. 08 epiphany
    By mJUSTINm in forum Ellsworth
    Last Post: 07-03-2014, 06:26 AM
  2. Epiphany 275
    By jredone in forum Ellsworth
    Last Post: 06-10-2013, 10:13 AM
  3. Epiphany or not?
    By sammon287 in forum Ellsworth
    Last Post: 05-14-2012, 09:08 PM
  4. Epiphany SST
    By Hank Wanker in forum Ellsworth
    Last Post: 03-13-2012, 07:25 PM
  5. Epiphany SS2
    By dogonfr in forum Ellsworth
    Last Post: 12-30-2010, 07:46 PM
