    Epiphany updated rear triangle
    Does anyone know if the newer style rear triangle and rockers (2010-2012) will fit on a 2009 frame? I'm looking to get more tire clearance which the newer version offers. If someone good give me some measurements from the newer versions, that would be great. Thanks.
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    Yes you can put the newer "whale tail" style seat stay and rockers on the older non sst frames. It will give alot more tire clearance. I have 650b wheels mounted in one with some room to spare. That said it will probably cost almost as much as a new frame.
    thanks for the info, i bought some 650's after i read they will fit my frame,, but it never mentioned it will only fit the 2010's and up.
    Reputation: geardoc's Avatar
    Yep, I made the same mistake with my '08 Epiphany.
