Results 1 to 11 of 11
    Epiphany Ti Bolt Kit
    Anyone know if there is one available?
    no one?
    Reputation: bridgestone14's Avatar
    Mar 2005
    http://www.mtbti.com/catalog/catalog.asp
    About half way down or so he has some bolt kits for bikes. I have no info on this other then the webpage. I was looking for some ti bolts for my thomson stem and came across it and remember you were looking for a kit for you bike. If this works out let me know. I am interested in a set for my moment.
    cheers
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
    Is titanium a good metal to be replacing the bolts with at the pivot points and shock mounts?
    Mike at mtbti.com
    I've been running a ti bolt kit on my 07 Ibis mojo frame with no issues whatsoever. I am 215 with all my gear on and am pretty harsh on my equipment.
    I've got a couple of racer friends with the kits on their ellsworth bikes with no issues.
    Just my .02
    Mar 2005
    You don't have a pic of the kit do you?
    I worked with a dealer that sells Ellsworth. They are exact factory matches to the steel bolts.
    Mike
    Reputation: ventana1's Avatar
    Wow, good luck with that... please post your findings...you can find Ti bolts from various companies on line, however, from a couple work projects we found that the motorcycle racing industry had some relatively odd pitch, diameter (including metric) and head profile Ti hardware. We found the really odd ball hardware from them. Good luck.
    Ride to Live... Live to Ride
    im still very interested. i read a horror show post about the ti ruining the paint. is this still a concern with ellsworth frames?
    got the ti kit for my evolve...
    fit perfectly, no problems.
    How much weight did you save with the ti bolts?
