Results 1 to 5 of 5
    Dec 2008
    Ellsworth Hub 29" XC Rear
    Does anyone have any tips on keeping my rear hub from loosening? I have the 2011 Evolve with the 29" XC Wheelset. Right now I am using two 17mm? wrenches to tighten the outside bearing nuts. I started off snug and played with tighter torque. But after a few hours of riding the hub will work its way loose. Also i have tried different quick release torques nothing so far seems to help this.
    Thanks,
    Paul
    LBS Manager
    Reputation: Johnny Hair Boy's Avatar
    Other than trying a bit of blue lock tight on the threads I don't know. One of our racers had that issue but it went away after about a week I just wrote it off as break in.
    Dec 2008
    Well there is a bout 700 miles on this hub. Come to think of it, it may be just some dust in there. I have not serviced it yet and I had similar probs with a king hub about 10yrs ago where the slightest bit of dust would make it loosen. If that don't do it I will try the LT.
    Thanks for the reply,
    Paul
    Mar 2011
    Me too!
    I am having the same problem with the rear wheel on my 2011 Evolution (also the 29" XC wheel set). I tighten down the outside bearing nuts and, after a ride, the nuts are lose again (which causes some alarming side-to-side play in the wheel). I will try cleaning and see what happens. I have less than 500 miles on these wheels.
    Regards,
    Jason
    Quote Originally Posted by Treetrimmer View Post
    Thanks,
    Paul
    Dec 2008
    hows your offset on that rim? Mine is off about 1/4" to the drive side. Tried to get it right but it seems that the nipples are maxed out from the factory.
  1. Replies: 28
    Last Post: 08-23-2005, 07:18 AM
  2. Replies: 36
    Last Post: 03-01-2005, 07:44 PM
