    Reputation: KRZTACO's Avatar
    Smile Ellsworth: Foam // Steel Balls
    After a couple rides I wanted to see if any loose marbles were flying around reeking havoc on my fork so I pulled the bike apart.
    Low and behold some steel balls came out with some minor scratches on the stem...nothing big but definitely could become worse if I kept riding for a while without checking it.
    So, I went down to the Home Depot and purchased some plumbers foam (found it in the cleaning supply area). Pulled everything off and threw some foam in the top tubes (where the stem inserts) and the seat post area. Now, I'm good!
    I love the bike, and shouldn't had been so lazy and foamed before I put everything together the first time.
    KRZ
    Rolling
    Reputation: lidarman's Avatar
    I should patent the idea of putting corks in the headtube, bottom bracket, and seatube, before the bead blast process, then license it to ellsworth so people don't have to do this! How much extra work is it to prevent this?
    Glad you are protecting yourself, because Ells won't be held accountable for their lack of processes.
    Reputation: RockyRider's Avatar
    Quote Originally Posted by lidarman
    I dunno- probably another $1000 worth of work per frame
    But for that price you will also get a laser etched "EBB" graphic etched on the frame (Ellsworth Ball Busting)
  1. "Balls of steel award" $850
    By jimmyboy in forum Singlespeed
    Last Post: 02-26-2007, 09:08 PM
  2. Balls as big as my wheels
    By jd3 in forum 29er Bikes
    Last Post: 11-13-2006, 12:00 AM
  3. Its got BIG balls.
    By EricTheRed in forum 29er Bikes
    Last Post: 08-26-2006, 02:36 PM
  4. I Have Glass Balls
    By Aquaholic in forum Turner
    Last Post: 12-20-2005, 11:03 AM
