Carbon Evolution
Printable View
  • 01-09-2013
    Velorangutan
    Carbon Evolution
    I don't think it's well known yet that Ellsworth can do a 5" travel configuration of the Carbon frame. Here are a couple pics of one I received.
  • 01-10-2013
    Nsynk
    Only 100 and 120mm are advertised. They would seem to use the two standard shock sizes of 51mm and 57mm strokes. How are you achieving the extra 7mm of travel?
  • 01-10-2013
    Nsynk
    And isn't it called the carbon evolve not evolution ?
  • 01-11-2013
    Velorangutan
    Generally when speaking on travel lengths we round to the nearest inch...
  • 01-11-2013
    wyatt79m
    Such a bad ass frame...
  • 01-11-2013
    Velorangutan
    You are correct. The label on the frame is Evolve. However, to get a quick picture of what it is I called it a carbon Evolution. A 5", err I mean 120mm, carbon 29er bike.
  • 01-12-2013
    Nsynk
    No actually "we" don't. And nor do 99% of manufacturers.
    Mountain biking is an industry plagued with a myriad of "standards" do you call a headset 1 inch when it's 1 1/8th? Or 1.5? Accuracy is essential.
    Travel is used to define the intended purpose of a bike. Where do you stop ? 5.5 inches ? 5.9 inches ? If your willing to call 4.73 inches 5 inches, are you equally happy to call 5.5 or even 6. 2 inches 5 inches? a bike with 160mm travel is designed for a very different purpose than one of 120mm as is a bike of 140mm.
    Ellsworth have always been guilty of this, the rogue for example was quoted as 6,7,8 inches. Ratios which are just not possible.
    We are not stupid. We don't want or need generalisation from ellsworth or their representatives. What we want is honesty and accuracy.
  • 01-13-2013
    Bad V2
    Dude, I think you forgot to take your pills today :eekster:
  • 01-14-2013
    LeBeau
    Really is beautiful! Tell us how it goes running the cables. Are you going to run the housing through the frame or use stops?
  • 01-17-2013
    wabiker3576
    You have to run them through the frame, there are no stops built in . I just did mine and it was a pita , now I have 2 Enlightenments to do, luckly one is going to be a SS , so I only have to run brake housing on itAttachment 770016
  • 01-17-2013
    LeBeau
    How much does it weigh assembled?
  • 01-17-2013
    wabiker3576
    Currently 25lbs , but I'm waiting for a few different parts, but would like to go 1X11 later this spring
  • 02-01-2013
    nkingdon
    tell me more. How is it built out and how do you like the ride?:thumbsup:
  • 02-09-2013
    wabiker3576
    Built it up with XT and Loaded headset,stem,bars ,post and X-lite wheelset. Rides great ,I've only had a chance to do a 9 mile loop on it before the weather to a ****, can't wait for better weather so I can put alot of miles on it. I'm running it a 100mm , but I might swap out the shocks from my Evolution later this year
  • 02-17-2013
    Salt Cycles
    Anyone else have any ride reports on the carbon evolve? I really like the Ellsworth suspension and want to know how this rides different from the al evolve?
  • 02-17-2013
    emejiat
    the biggest diference is the rear stiffnes. The 142 mm plus the revamped chain stay is what gives a lot of rear end. The new chain stay is almost 200 grs more and both are aluminum. The carbon head tube is 5 inch vs the 4 on the Al SST2. I have not tried the new al frame wich is hidroformed vs the old SST2 cold worked. Also the CTD shock vs the RP23.
  • 02-25-2013
    randyjackson
    nice
  • 02-28-2013
    drnich
    So how did you get one with the EW seat post clamp. Mine came with the cheesy black clamp. They told me they had not made the EW clamps for the 30.9 seat tubes yet.
  • 03-04-2013
    Salt Cycles
    I just rode the Carbon Evolve at a Demo in moab last weekend. AMAZING bike. Felt like it had more travel than the 100mm it comes with. Pedals extreemly easy and steers super fast.
    Ellsworth suspension is very unique - if you have not ridden one yet try it out. Super plush but firm when pedaling. I personaly love it.
    LOVED IT.
  • 03-05-2013
    rcgalore
    It also comes with 120mm option... At time of ordering you can choose between 100mm or 120mm.
  • 12-22-2013
    Randy777
    Is the Evolve a bike you can standup and pedal hard without any bobbing? I have a Giant Anthem X 29er which has no bobbing but I really like the looks of the carbon Evolve.
  • 12-23-2013
    jalea
    It is gonna bob somewhat, but it seems more firm than previous Evolves that I have ridden.
    It is tough to compare the bobbing of a Horst link and the shorter link suspension systems that are so prevalent today. I mean the EPIC has to have a brain to keep it's Horst suspension from bobbing and this is just a side effect of Horst.
    But having said that, I still love the feeling that this bike provides over chatter and chunk. This comes with no penalty of pedal feedback like you can get with VPP and small front chainrings.
    It doesn't just wallow in it's travel when you decide to hammer it. It is active though and gives great traction because of that fact. Is this bike fast?? You better believe it.
  • 12-23-2013
    xl_cheese
    The ict design pedals extremely well. It doesn't have any pedal feedback or pedal induced bob. However, standing out of the saddle will cause the bike to bounce with your body weight. It won't stiffen up. You can counter this with the CTD shock settings.
    If you want something that tends to stiffen while pedaling look at the Devinci bikes.
    I tend to be lazy and ride seated a lot so the ICT design is a great complement to that.
  • 12-24-2013
    Pedro
    the 100mm or 120mm rear travel choice is also available on the sst2 (aluminum) Evolve.
