Results 1 to 3 of 3
    Nov 2007
    Bushings for Fox RP-23 on Ellsworth Truth?
    I am building up a new -2008ish Pre SST Truth frame. I want to install a FOX RP-23 rear shock , and am in need of a new set of reducers for the shock. Does anyone know either the measurements I need? I know Cambria carries most sizes, but I just do not know the size needed. Thanks
    Someone on the forum may know the answer. If you don't get an answer or want to go to the source, call Fox and they'll help.
    Nov 2007
    Thanks. For some reason I thought the adapters came from the bike companies, but you are right-Fox had them, and has an interactive section on their website to find them. Here is where that is in case anyone else ever is looking for them. They had them in stock and shipped them same day.
    Go under Quick Tech Rear Shock, and then to Rear Shock Fit Chart and most bikes are listed.
  1. Bushings for 2000 Truth
    By philipb in forum Ellsworth
    Last Post: 08-31-2010, 08:57 AM
  2. Ellsworth Truth
    By Marcus75 in forum Passion
    Last Post: 08-19-2010, 08:02 PM
  3. Replies: 0
    Last Post: 08-11-2010, 11:40 AM
  4. Looking to try out Ellsworth Truth
    By mtbikermom in forum California - Norcal
    Last Post: 09-07-2008, 09:24 PM
  5. Truth shock upper carbon bushings?
    By ventana1 in forum Ellsworth
    Last Post: 07-06-2007, 12:04 PM
