Results 1 to 5 of 5
    Reputation: justbuster69's Avatar
    allen screw keeps getting loose
    my ells moment's rear joint on the drive side keeps geeing loose.every ride i need to tighten it.any remedy i could do?threads are not loose.
    blue loctite?
    ok will give it a try thanks
    If the same bolt keeps coming loose, my guess is that bearing is seized or very stiff.
    Take the bolt back out and check the bearing, it is a good idea to service all the pivots regularly.
    'Sealed" is a euphemism for "leaks more slowly".
    jummo
    tnx
