Results 1 to 5 of 5
    Reputation: orange juice's Avatar
    Dec 2009
    120mm fork on moment?
    do you guys think that my 120 mm marzochii bomber33 rlo will work just fine for my ellsworth moment frame in terms of stance and handling?thanks in advance
    The fork will have a shorter static length and axle crown so will steepen the geometry and lower the bb. That will be fine for more xc orientated riding and for jumps/4x . You could match the travel front and back by fitiing a shorter eye to eye shock, that would also correct the geometry. Alternatively you could use an angleset headset to slacken the head angle and lower the BB even further. www.ofanaim.net sell them.
    Reputation: toHELLuRIDE's Avatar
    I dub thee "Scorpion King"!
    I've built up a number of short travel Moments using 120 mm forks and all performed admirably. My approach has been to use the same length shocks but with a shorter stroke. The result is a really spiffy high performance trailbike. A couple of rather high dollar builds with American Classic 350 wheelsets, Schwalbe tires, three piece carbon cranks w/ti bottom brackets, BB-7 brakes, and light stems, bars, & seatposts weighed in under 24 pounds and were unbelievably stable and a blast to ride. Good luck with yours!
    Reputation: Bike Zen's Avatar
    Quote Originally Posted by toHELLuRIDE
    LOL @ toHELLuRIDE
    Zen Bicycle Fabrication, Portland, Or.
