Results 1 to 16 of 16
    Jan 2013
    Wanted: A cheap rigid fork to "fix" Cannondal and Yakima Q clips for mk5 Jetta in GTA
    I'm looking for a cheap rigid fork to put on my old Cannondale M700. It came with a 1 1/4" headset for which I cannot find a shorter/taller stem. I want to replace the fork so I can use some adapters/reducers and switch to 1 1/8" standard size. Anyone in GTA have a cheap fork available, preferably aluminum? Did I mention cheap?
    Also, need the clips to put my Yakima racks on my mk5 Jetta.
    No. Just No.
    Reputation: Circlip's Avatar
    Note: Anyone with items to sell that may fill the OP's needs please send PM to bishskate rather than posting.
    Good luck to the OP in your search.
    Jan 2013
    Quote Originally Posted by Circlip View Post
    Thanks. I hope I'm not breaking forum rules with the post, just trying to keep things local. Kijiji/CL have not turned up much.
    No. Just No.
    Quote Originally Posted by bishskate View Post
    No worries. You're essentially asking for help, and the folks around this forum like to help so it's all good. Just trying to keep it from looking like CL in terms of posting info about items for sale (which mtbr does have some guidelines about).
    Reputation: secret agent's Avatar
    Did you try Woodman for stems. They make a bunch of sizes that fit the headshock. That might be cheaper than a fork. I used to have 2 cannondales and I still have a couple of stems including a Woodman.
    Burnt Norton
    Team NFI
    Give Veteran Youth at Cycle Solutions-Beaches. As I recall he has a bit of a collection of some of that old stuff and if he doesn't he probably will know where.
    Reputation: veteran_youth's Avatar
    Nov 2006
    Quote Originally Posted by Enduramil View Post
    Sorry Circlip, but as I was called right out I am responding in thread. Will try to add some general info to give it mass appeal!
    Shop can probably help you out w/some 1 1/4-1 1/8 head tube adaptor shims (press into the frame so that it will accept a standard 1 1/8 HS and this fork. Haven't checked in a while but may still be kicking somewhere.
    But above and beyond that, you may not be aware but Giant has brought 1 1/4 stems back under the moniker Overdrive 2. Almost all of their high end models come stock with them so they have a pretty wide selection of stems. I remember responding to your last query on here a while ago not sure why I didn't think of it then.
    Giant Connect SL OD2 Stem (Stems) - Bike Gear | Giant Bicycles | United States
    Andrew
    Jan 2013
    Apologies to circlip for the contra-band thread that won't die LOL
    Thanks guys,
    I checked out the Woodman stems and the Giant link. Both are for threadless stems, but my bike is old enough it uses a quill stem. If I had access to a metal lathe it would be really easy to produce half a quill stem to which a threadless stem would then clamp.
    I'm sure someone will PM me but for those of you with advice regarding other solutions, I think there is a benefit to others facing the same issues. Hours on google has not reaped much info so far.
    likes to rides bikes
    Reputation: VR6ix's Avatar
    Ontario forum on VWVortex.com, although they will (rightfully so) tell you to post in the Canadian Parts Classifieds forum instead:
    Ontario Forum: VWVortex.com - Ontario
    Canadian Parts Classifieds forum: VWVortex.com - Canadian Classifieds Parts
    Ontario forum on TDIClub.com, although they may (rightfully so) ask you if you really have a TDI or not, lol! Not that it matters...
    Ontario - TDIClub Forums
    also known as Plaid Shirt Guy...
    No. Just No.
    Quote Originally Posted by veteran_youth View Post
    Ya ya...
    Ya ya ya...
    I see this as a special problem needing a bit of community knowledge and help, so no big dealio.
    Team NFI
    Well, you are the only one here who is pretty retro in his parts selection other then me. Though riding that elevated chainstay Alpinstars you have kind of confirms it.
    Nov 2006
    Quill stem? That changes everything!
    I.D. of a 1.25 fork is actually 1.125". Therefore you can find any junker 1.125 fork, and assuming you have a miter (or a steady hand) cut the steerer at an angle to match the wedge in your current stem (leave the top square). Swap your bolt and wedge into it. You now have a 1.25 quill adaptor that will accommodate any 1.125 threadless stem.
    Edit because I forgot how to make sense.
    Team NFI
    The RGMC beacon was activated.
    Jan 2013
    Took a few readings but I think I understand. As long as the wedge will not fit inside the steerer tube that is a genius idea!!
    Nov 2006
    The wedge should be a 1.125" diameter as well, and as such it shouldn't be possible for it to slip into the steerer. You could probably find any 1.125" tubing and use it for this purpose, but at least you know a steerer tube was built to withstand the exact forces of this application.
    Also it's probably worth mentioning use a THREADLESS steerer. You will need to pound the star fangled nut below the point where you are cutting but that is easy. An aluminum steerer off an older Judy or the like might have a greater wall thickness which could help with wedge tightening (less digging/binding maybe?).
    So whichever way you slice it, I guess you are still looking for a 1 1/8" fork!
    Jan 2013
    Hang about, wouldn't I need a cap for the top of the tube to hold the bolt head? There would be a lot of force to keep the wedge tight.
  1. Need help picking light rigid fork from list of "budget" ideas
    By vikingshelmut in forum Weight Weenies
    Last Post: 06-15-2013, 03:17 PM
  2. Yakima q clips for 2013 jetta
    By tangaroo in forum Cars and Bike Racks
    Last Post: 12-08-2012, 07:43 PM
  3. Replies: 0
    Last Post: 02-16-2012, 11:08 AM
  4. "Paid Spam" Fatback Fork Wanted!
    By bdundee in forum Fat bikes
    Last Post: 09-04-2011, 04:47 PM
  5. White Industries "Rock Solid" carbon rigid fork weighed
    By mechBgon in forum Weight Weenies
    Last Post: 07-13-2011, 12:54 PM
