Results 1 to 31 of 31
    Ti bolts who has them
    Does anyone know where we could get our hands on ti bolts in Ontario
    humber river advocate
    broadcasting from
    "the vinyl basement"
    build trail!
    does this guy have a store or???
    Can we pick up or is it just mail order ?
    your guess is as good as mine, but he has been around for a while.
    broadcasting from
    build trail!
    Reputation: ghettocruiser's Avatar
    He is mail order only.
    The above statements have not been evaluated by the Food and Drug Administration
    No. Just No.
    Reputation: Circlip's Avatar
    Not sure if you have any previous experience with Ti fasteners, but depending on what material you are threading them into you should be aware of the potential for galling with a reactive metal like Ti. The technical details from the materials engineering side are above my pay grade, but suffice to say that it's not a good practice to a dry install with Ti fasteners threaded into any other metal. Fasteners that are low torque, or are more likely to be removed and reinstalled without significant time gaps in between can probably do fine with grease.
    Anything that is higher torque, intended to be left for extended periods, or Ti threaded into Ti and you should probably be looking instead at a copper-based anti seize prep for the threads. Bike stores sometimes carry "Ti Prep" (e.g. Finish Line branded product) but you can also get copper anti seize from just about any auto parts supplier at a fraction of the cost by unit volume (although you may end up with a larger amount than you ever need for a lifetime).
    I may be telling you what you already know, but figured better safe than sorry. If anyone with more specific engineering knowledge would like to add or refute anything above, please feel free to help educate.
    I have a Truvative Stylo World Cup stem. Aluminum stem, Ti bolts. It seems like it came from the factory dry threaded. It's not that old and I don't have much experience with Ti bolts, so I can't say if it is, or will be, a problem or not.
    No. Just No.
    Quote Originally Posted by smilinsteve View Post
    Could be fine???
    Speaking for myself only, I don't dry thread any fasteners. Mostly greased threads, with selective application of thread lock compound or copper anti seize paste for specific fasteners where it makes sense.
    I'm even using carbon assembly paste on an increasing number of (non-threaded) component interfaces these days, even those that aren't necessarily carbon, to prevent slip without need for excessive torque.
    Maybe I'm just overly attentive on this area of bike assembly and maintenance?
    Quote Originally Posted by Circlip View Post
    Maybe I'm the only guy attentive of bike assembly and maintenance.
    fixed.
    (well I would have never bothered with that...)
    No. Just No.
    Quote Originally Posted by ghettocruiser View Post
    fixed.
    Touché.
    sock puppet
    Reputation: osokolo's Avatar
    Quote Originally Posted by the bob View Post
    What application do you need the Ti bolts for?
    Signature
    Team NFI
    Maybe I'm just overly attentive on this area of bike assembly and Ham Fistery?
    FYP
    Quote Originally Posted by osokolo View Post
    Not any particular application I just want to replace all my bolts with Ti
    I got in touch with that link and ordered what I needed ( wanted ) Thanks guys
    Apr 2005
    It might be a good idea to send an email to Toronto Cycles separately, advising him that you ordered. When I ordered, the notification from his software got hung up somewhere in the Internetz, and it wasn't until I followed up that he found out. He was very gracious about it, and I got the order quickly after that.
    Good job!
    Quote Originally Posted by smarty View Post
    Cheers ... Thanks dude
    Toronto Cycles is cool and it's not just for Canadians. I've had them ship stuff to Colorado a couple of times. Very quick, and nice people to deal with. Fair prices and cheap shipping, but they use regular post and it kind of stinks not getting a tracking number.
    sock puppet
    you are the first
    baggie with platforms weight weenie rider that i know...
    i can see switch to spandex and clipless with titanium spindle just around the corner...
    unless titanium bolts are used for something else other than saving weight - in which case - please do share.
    i do use titanium bolts with my brake calipers, just because they came with them. never purchased any other titanium hardware...
    No. Just No.
    There have been many world cup DHers that were or are known to be notorious weight weenies, sometimes even having their race frames built out of lighter tubing than stock, and treated as having a very short disposable lifespan.
    Evil Jr.
    I'd almost venture to say that weight saving innovations are bigger in DH that in XC right now. It's a lot easier to shave weight off a 35lb bike than one that's already 20lbs.
    Apr 2005
    To me, there are several reasons why one would use titanium bolts:
    1. Weight. Note that the savings are negligible, but there are savings to be had. If you are trying to get the weight of your bike below a target, and have done everything you can to get there, except replace the bolts, that negligible savings might get you across the line.
    2. Aesthetics. Personally, I like the looks of a bike that has matching bolts throughout.
    3. Just because. I have thought a lot about what goes on my bike. Why not finish off a great build with titanium bolts?
    And finally, there is a certain satisfaction to be had with turning a titanium bolt into a frame - it feels so much smoother than a narsty old steel bolt, for example.
    4. They don't rust
    5. They come in colors
    sock puppet
    well, i stand corrected...
    4. They don't rust
    who am i to challenge the distinguished members like smarty and circlip, not to mention GM and smilinsteve... i guess i have ways to go before i start buying bolts in colours...
    What can I say dude because I can ????
    Ok on a serious note yes it is to save weight ,,, and no saving weight is not just for Lycra lilies ,,, where needed you add and where you can you save ... Let me give you an example . I just changed my front hub from 9 mill Q R. to 15 mil and gained 8 oz but between the new fork and wheel the stiffness is worth the 8 oz. And if I can drop 4 oz by changing all my bolts to ti. Hey why not.
    4. They don't rust
    I am getting mildly irked that my stem bolts turn orange inside after three months.
    Evil Jr.
    Oh please, you're talking to a guy that buys different colour cable ends!
    sock puppet
    bob, you freak me out...
    ... and if we just ...
    Why dude ? Lol
    Toronto Cycles is a good guy, I think his name is Tom. I've ordered a few items from him in the past and everything has been good and shipping is super fast... 2 days I think. Even made a mistake (not sure if it was mine or his) on some bar ends, really no big deal but I sent him an email and he sent out the proper ones before I had a chance to send back the old ones, only a $20 part but still nice to know there is still trust out there.
    I think his brother has an american counter-part store in Buffalo that sells the same items for across the border, but I am not sure which one is the fabricator (or contracts it out) for some of the items.
    I ordered a few Ti bolts for my non-existent water bottle cage in black, sure are sweet! and I am positive I could feel a difference in weight!!
    Gotta say though, the rear deralleur (sp?) pulleys he sells are super smooth way nicer than the ones that come stock with an XTR rear deralleur and spin a lot longer, shifts are crisper too.
    But, I digress on the topic, sorry... Ti, Ti, Ti, Ti
    D
    Somewhere lost in the Bush!
    Quote Originally Posted by osteo View Post
    In that application, where the bolt is basically filling a hole and has almost no stress, aluminum bolts work fine, are cheaper, and come in more colors
    Evil Jr.
    Why dude ? Lol
    *cough* the bob: Posts Per Day: 17.19 *cough*
    Always nice to have fresh blood in here!
    True, true, but Mom, I really wanted it!!
    D
  1. Replies: 7
    Last Post: 05-14-2010, 03:56 PM
  2. Aluminum bolts to replace steel water bottle bolts?
    By RockadileSX in forum Weight Weenies
    Last Post: 06-11-2009, 02:50 PM
  3. Replies: 6
    Last Post: 04-20-2008, 03:33 AM
  4. Replies: 6
    Last Post: 09-21-2005, 10:27 AM
  5. alloy stem bolts and brake boss bolts??
    By carbnjunkie in forum Weight Weenies
    Last Post: 06-24-2004, 10:50 AM
