Wanting to extend the season.. but I find that I constantly struggle with being over dressed or under dressed almost to the point that I won't even go. Put this Q in this forum as weather and riding tends to be local (Southern Ontario)
I tend to think (correct or not) that if I'm coolish in the parking lot then I'll warm up as I go - I guess I sweat enough that I don't or the wind chill from moving just makes it worse. So then I add a layer and become over heated as I ride :madman:
Main complaint is I get cold core, feet and head get cold (neck as well) this leads to a headache and then I'm done. Hands are never an issue as I have that dialed in pretty good. As my intensity goes up I also find that at cool and colder temps my throat and airways get really irritated from the cold air.
I see other riders at the trail head dressed like the Michelin man and I wonder how are they not overheating.
Realizing that we are all different - What are others doing?
Thanks for reading..
What I'm currently using...
My outside (top layer) is an older Norco activa jacket (zips open or closed as needed) - and I layer below that. Adding or subtracting merino or Under Armour layers (my ski layers)
Legs are long 'sausage' with padded liner, but no extra layer.
Feet, since I run clips, are a pair of Shimano 'hiking' style boots and smartwool socks.
Head is always tough as finding something that fits under the helmet without applying pressure across my head is problematic (maybe the helmet is too narrow) - cold ears will give me a headache (same with overheating) currently using a X-country skull cap under my Giro helmet.
Get a balaclava, it will keep your neck warm at the same time. You can buy them with a removable mouth piece in case you face is warming up too much. You need to ensure you are pulling the sweat off your body with the clothes you wear as a base layer, from there wear enough to keep the wind and cold out.
Better to be too warm then cold, the body focus' its energy on keeping its temperature.
Other food for thought, you body will focus all of its heat on your bladder if you have to pee. Never hold it as it will just make you cold.
I've found that a lycra running cap fits nicely under my helmet and it keeps my head warm enough until about -20 when I'm in full-on balaclava mode.
For the core, I just keep piling on thin layers by degree ranges. From 5 to 0, I usually do just a long-sleeve jersery and a shell. From 0 to -10, I'll switch to long sleeve merino with a short sleeve jersey and shell. From -10 to -20, I'll throw an undershirt on below the merino. From -20 and beyond, I'll have all that but switch the shell for a lined jacket. :thumbsup:
If it's wet out, I switch the shell for a rain jacket.
My tights are quite thick and windproof on the front. Makes a difference. I wear shorts with a chamois underneath. Also, proper winter shoes make a difference. If you won't be off your bike, those neoprene booties aren't bad, but they pack up with snow like crazy if you do any walking (inevitable if you're snow riding in the forest). It sounds like you're dialed from the waist up.
Having commuted throughout the year for 5 years (35-45 minutes each way), they best advice I can give is, get experience.
Though here are a couple pieces of a more off camber advice
1) If you hate being cold, just dress a little warmer and take it easy, it's winter anyway an you ain't racing (if you are, you'll need no more than a couple layers anyway). Wear a pack and carry extra stuff, or to be able to remove things.
2) If I end up being over dressed, I just open everything right up and put a little chill into myself. When I start to feel uncomfortable, zip it all back up. I find I'm good for a while without over heating after that point. I might cycle this. (Generally only a good idea if you are relatively 'close' to were you can get heat in case things go wrong).
3) I always carry an extra hat and gloves. I sweat significantly from those area's, so it's a nice treat to replace them part way through.
4) Wear whatever you like, but if you like clips, a proper set of winter shoes are the best investment I have bought for winter/foul weather. Your feet won't fall off.
5) I find I am happiest and most comfortable when my core is well insulated, but my arms legs are a little under dressed to expel heat. I find that's a good, relatively safe way to keep me from over heating. As such, I always ride with a vest, I love them. Unless it's really brisk (or windy), often my outer top layer.
I have a balaclava made of some kind of thin material intended for running that works well under the helmet. it keeps the head, face and neck warm to about -12 or so for about 1 1/2 hours. I have not found that I can find the perfect combination of jacket and layers where I will not end up soggy at some point. I have tried a combination of lots of materials and thicknesses. I now just carry a knapsack with a change of clothes and I will just get changed quickly about 45 minutes to 1 hour into the ride. Then I am usually back home or at the truck by the time I begin getting wet again. As to running clips, I tried booties and different socks, but did not work. I just went to platforms with a really well insulated hiking shoe.
Shimano MW-80 Goretex Shoes. A must for any winter commuting / extended riding
merino base layer(s). wicks the sweat up to the next layer efficiently.
GORE windstopper jacket. This thing is unreal. Worth the $$. Pitzips are a must for when you are warmed up to exhaust the heat you're generating.
PROPER FUELING! This one to me is most important. I find as soon as I start to get hungry, my extremities are the first to get cold. Stay fueled, stay warm. You burn more calories in the winter to stay warm.
I like to use a neck guard as well to prevent any wind coming down your neck and cooling your torso
Wool socks. Neoprene is okay if you like the nasty smell that develops after use. Especially good if you want your spouse to stay away from you after you get home.
Other then what else is mentioned. Old school Roach vest I only use in winter. As well as a bomb proof Core Rat Deluxe jacket.
One not mentioned detail especially if commuting or doing trg on the CX bike on roads is knowing the locations of coffee shops. When it's cold out it's handy for when you need to warm up and get warm fluids in. Though I'm really the oddball here. Joely can confirm that if I have the choice between turbo trainer or riding outside in minus 20 in a snow storm. I'll take the snow storm.
I'm 100% certain a Tim Horton's hot chocolate was the only thing between nspace and certain death on one of our Spring rides in Niagara. He was shaking so bad, he could barely hold on to the cup!
I'm a big fan of balaclavas and wool socks ( not like Granny used to make).
Also, in my experience pre-warming your gear. :skep: My Wife maskes me keep alot of my stuff in the (unheated) garage, so I take it in beforehand and preheat it on a heating vent, especially shoes. May sound dumb, but I preheat my coffee mug and my coffee carafe as well!!!
This year I replaced a pair of mitts, gloves and a windshell that I had been using for quite a while. Needless to say I was stunned at the vast number of choices in the these product categories that have crept up over the years. I experienced moderate to severe choice paralysis and ended up just grabbing whatever was on sale. Well, two of the three items turned out to have polyurethane-coated nylon - a product feature which was comparatively rare when I first put together an outdoor kit. That stuff is bad news in winter; don't make the same mistake I did.
- If you are dressed to ride and you are already hot and sweaty before leaving you are wearing to much. The general rules is when you step outside you should feel a wee bit chilly. It's simple really.. to much gear on will get hot sweaty and wet when you start exerting yourself. Bad idea.
- Hydration is important.You lose moisture from breathing while riding.
I spent last year riding in a wool jacket as well as wool base layers and wool jersey. The wool jacket is great for most conditions for me. As long as the temp is below zero the air is fairly dry and I don't get nearly as soaked with sweat as I do with a shell. I know there's shells and then there's shells, I just haven't found the perfect one yet and I begrudge spending what seems like an awful lot of money on something which may or may not leave me feeling like plastic wrapped sausage. Below a certain temp ( I'm still working on figuring out what temp ) and wind factor, I add a shell for a bit of extra warmth.
By the way, I've been riding to work year round since '93 and I still haven't got the clothing completely figured out. What works one year doesn't cut it the next, and there's always new stuff to try.
Merino wool base layers have been the biggest improvement over the years. Having a nice itch free wool layer next to skin does wonders for moving moisture.
Breathable shell is the next major thing. There are lots of trade-offs between waterproof and breathable and windproof. For riding I'd side towards breathable and windproof over waterproof.
For anyone looking for some merino a company I work with is doing 10% and free shipping right now.
Now lets add in one area not at all covered. Eye wear. 2 reasons being hard to ride when you can't see because you had none so your eyes watered. And your lashes froze together.. not fun.
op just needs less insulation on the arms, more on the legs and groin(extra underwear like i said) and to wear a bandana or fleecy banada thing. Also make sure you didn't put on 5 layers of socks that are the same size and your feet are strangled inside shoes that are too small.
electrik..
thanks - 1 layer of sock is all I use :thumbsup: (same as when I ski)
Goggles..
I spend a lot of time in the winter keeping goggles clear - and I also wear prescription glasses - not a great combination - as electrik said - don't breath on them. You can also use the same liquid you use on a hockey clear visor - HOWEVER - most (but not all ) decent ski goggles will have an anti fog coating on the inside - you need to take care of this coating for it to be effective (basically don't touch it and only use the lens cloth to wipe the lens).
Other things to consider - if its really cold - don't keep taking the googles off and on - put them on and as long as they stay clear keep them on - air movement is key to keep things clear so don't block the vents (top and bottom) this is a challenge when your trying to cover your lower face. Old snowmobile trick was a pice of duct tape over the bridge of the nose to make a peak that would deflect the warm breath down away from the goggle - since I no long ride sleds - I'm sure things have improved.
Smith and Oakley makes a number of models for those of us who are optically challenged (so do most of the major brands) but Smith also has Turbo Fan models - basically a couple of batteries and a small fan in the goggle - yep they work...
I have a pair of Smith Pivlocks (with Px insert) that I use in the other 3 seasons and they wrap around pretty good - not sure how well they would work in the deep cold - but up to this point they have been working.
electrik..
Goggles..
For the deep cold some i've seen people use a painter's respirator. There is also a brand of balaclava you can get that has a rebreather attached which acts a a heat exchanger.
Also to consider is your saddle is fitted well and it's somewhat hard and is minimally compressing your veins or artery(some compression is inevitable). So make sure when you sit you're seated on your "sit bones" and it has a good cutout. I was thinking to experiment with compression gear this year as there is some small evidence that when worn on the calves it helps to pump cool blood back up to the heart which is good because we as cyclists don't get as much of that pump as runners do. Some people even use compression socks... though i'm not sure about that.
Lastly some people just have a poor cold induced vasodilation response perhaps due to nerve damage in the feet(slight frost bite). In fact a recent study I read was a bit alarming, it seems when you get "used" to the cold it only means you stop feeling the cold not that your feet have improved their vasodilation response to the cold. So keep warm!
I struggle with cold weather riding all the time because I sweat a lot. It really does not matter what I wear, I sweat and soon enough I'm am soaked, so my preference is to be slightly over-dressed. That way I have a chance to stay out there 1-2 hours.
As for that urban ski video ... pathetic conditions but amazing skills. I would rather see powder ... at least I can imagine myself powder skiing
I use normal oakley snowboarding goggles and a full-face helmet. All winter, every ride. They've never fogged.
I've gone on winter rides with others who were using identical goggles and they have fogged them almost immediately.
I think it must have something to do with the circulation in yer face.
The flip side or the circulation issue is that I have to completely cover my face at like -2C, whereas I see other guys with no balaclava and no glasses even riding at -12C and lower.
Otherwise - Mw80s with thermal insoles on feet, fox thermopaws under MEC pogies on the bars.
My regular Oakley's are fine for most winter rides, They never fogged. Also fleese under gortex, thin tights under a shell, thin but warm balakava, warm gloves (I wear Spyder brand), If I wear hiking shoes, I wear gortex socks over a thin wool pair. I am toasty warm for all winter rides
Hard to see but the googles I'm wearing for skiing are Oakley DH, They never fogged, they were comfortable. My ski instructor loved them and got himself a pair!
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
