Results 1 to 10 of 10
    Team NFI
    Dear MTBREC Ninja's
    Your mind tools are lacking. Please try harder.
    Looks like metal fatigue to me, but your mention of mind powers made me realize that the most obvious difference between metal fatigue and mental fatigue is the letter N, and Ninja begins with N. You may be on to something. Maybe not
    ups and downs
    It looks like crash damage, they'll never warranty that frame...
    Team NFI
    Quote Originally Posted by rockyuphill View Post
    So claiming that it failed due the torque applied by my ego wouldn't pass muster then.
    Quote Originally Posted by Enduramil View Post
    It's a fatigue failure, not an ultimate strength failure. Fatigue failures happen at far lower stress levels than the ultimate strength of a material, sometimes as litle as 10%, but over millions of cycles. That means that your ego torque wasn't too much for the crank to handle all at once, you had to apply it over and over millions of times before the crank got annoyed and gave up. Something like this: "Man this guy pisses me off. If i just start to crack a little, maybe he'll take me off this bike and I won't have to listen to him anymore, but I'll still be in one piece."
    Team NFI
    Quote Originally Posted by nickboers View Post
    So it couldn't handle the superior mind tools combined with the sheer awesomness of post count.
    Reputation: veteran_youth's Avatar
    Nov 2006
    My analysis is as such: If that is a left hand crank arm it broke due to awesome pedaling forces. If it is a right hand crank arm it broke due to general hackery.
    No. Just No.
    Reputation: Circlip's Avatar
    Reputation: ghettocruiser's Avatar
    I had to click the link to see if that was legit.
    When I saw name so close to "clavicle" on an ultralightweight carbon part, I falsely detected shenanigans.
    The above statements have not been evaluated by the Food and Drug Administration
    Team NFI
    Quote Originally Posted by veteran_youth View Post
    It is indeed a right hand crank. However the 20 years of data show that the right crank always receives more torque due to that being the dominant leg. This means that it is the stronger.
    The minions atTeam NFI has found a much simpler solution and more cost effective solution.
    Profile Racing E-Store
