Results 1 to 14 of 14
    max_29
    Reputation: max_29's Avatar
    Oct 2007
    cracked seat tube
    wonder if anybody can recommend a welder in GTA that would be able to fix a crack in a seat tube.
    it's a steel frame.
    TIA
    X-Ray Guy
    Reputation: Jawz's Avatar
    I have a feeling that the way the crack is moving you would need a whole new seat tube to fix that and not a simple patch over. That might prove very costly
    Evil Jr.
    Ooh, that's not good. Unless that was a really expensive/custom frame, it might just be simpler to replace it.
    Team NFI
    That's into the weld. Not good. Easier to replace the frame.
    It could be welded up and ridden for years, or it could start to crack again pretty quickly.
    fire an email/pic to hugh @ truenorthcycles.
    Reputation: ol-crank's Avatar
    just a warning. I don't know what steel alloy it is made of
    but some metals like chrome moly should be welded carefully (experience welder) and maybe stress relief annealed afterwards, to reduce the brittleness at the weld. Unless this is an expensive frame, you can pick up a cheap steel frame for less than any shop is going to charge you to fix right.
    Reputation: ghettocruiser's Avatar
    Quote Originally Posted by VernDog View Post
    Back in the Steel is Real days in Guelph I had Hugh fix three separate frames for me, including 2 that were broken completely in half. I still have one of them. But now in the era of $150 internet frames, not sure it would be cost effective.
    The above statements have not been evaluated by the Food and Drug Administration
    X-Ray Guy
    just curious...chromag frame?
    max_29
    Oct 2007
    Quote Originally Posted by Jawz View Post
    it's Soma Juice frame
    How old is the frame? If it's still under warranty then contact the manufacturer and see what they can do for you. Get if fixed only if you can't get it replaced for a reasonable price.
    max_29
    Oct 2007
    Quote Originally Posted by aerius View Post
    it's marginally within a warranty period, and although i'm not an original owner, they still offered me a discount price on a new frame
    however, they don't have older models in stock and for the new ones they switched from
    track ends to sliding dropouts, i'm not a fan of those, that's why i'd rather fix my old frame if possible.
    Reputation: kgwisdek's Avatar
    Frank, at Frank's Specialized Welding in St.Catharines. 905-682-0047. Does most of our customer's frame repairs. Old school, qualified, fast, affordable.
    max_29
    Oct 2007
    Quote Originally Posted by kgwisdek View Post
  1. cracked seat tube?
    By em6901 in forum Bike and Frame discussion
    Last Post: 09-29-2011, 10:09 PM
  2. Cracked seat tube
    By 41ants in forum 29er Bikes
    Last Post: 12-20-2009, 05:46 PM
  3. Cracked seat tube ... HELP?!!
    By zul in forum Tooltime
    Last Post: 08-26-2007, 11:41 PM
  4. ID cracked seat tube
    By camg in forum Ellsworth
    Last Post: 10-21-2006, 11:35 AM
