and it looks pretty good, 30'x50' of usable space. since i'm not a big fan of a manicured lawn due to environmental reasons and like riding a bike... it's time to join pump track nation (though i think i can squeeze in 2 dirt jumps also).
the soil is perfect around here with just the right amount of clay, though this will make digging tough. a mini excavator will be used and special attention will be given to aesthetics, grading and environment. i've talked about this in the past how building a trail (or pump track) can be used to improve the environmental footprint of an area. now i will do it on a micro scale with focus on naturalization (native plant species/other features) and some urban agriculture thrown in (i like organic vegs).
should be an interesting outside the box urban landscape project.
I remember that many of the arguments around dirt jumps and pump tracks in some Mississauga locations were due to the aesthetic limitations. Many complained that this sort of build is ugly and and never complements other natural areas. There were also arguments about a lot of dust blowing around. Along with concerns about kids leaving their trash behind and "hanging out" after hours and so on, killed a bunch of plans back in the day. I bet the neighbors are going to love this; though you seem to be in a bit of space there. It would be great to see a well made, aesthetically pleasing construction though.
I really like the idea of having a pump track/veggie garden. The only problem I see is that things like potatoes and squash really get around in a hurry.
neighbors shouldn't be an issue, got none to the back of me and the others will want to use the track. the lot is an older one so it has tons of space all around compared to new houses.
i have some connections to cots forestry restoration dept to get advice on plants and general landscaping.
Looking forward to the results. You have a lot of bike and bike related projects on the go. I find it hard enough to keep the regular stuff on the go and get lots of riding in.
You may just want to see if your municipality has a Grading By-law, or a by-law which might prohibit or otherwise require approval for this sort of thing. Even if you don't seek approval, at least you'll know what you're up against in case the municipality does receive a complaint (which I would rate as a very high probability given this type of project) and enforces the by-law.
ain't changing the grade, nor cutting trees, nor building a deck or shed... just a wee bit of landscaping and ornamental rocks... quite common in this area, you should see the complex gardens and sheds put into backyards
plus my trail building etc. experience... shouldn't be a problem.
Yeah pretty sure he also had the Lee Like Bikes plans. Just saying.
His track was a pretty basic loop, I think on a bigger track with more features you have more to work with to build momentum. On his small track it became very critical to get the rollers right as they were the only source.
I've seen videos of other peoples' backyard pump tracks and it's not as easy as it looks to get right. As soon as you see the rider pedaling (out of necessity), you know something ain't quite right.
The pump tracks at Ray's and Joyride all had to be tweaked too. At least in the garden, it's just pushing a little dirt around.
people tend to make the radius of the berms to tight and space the mounds to close. they want to cram to much into a small space. i've seen this on trails i've been asked to tweak the flow. 9 times out of 10 it just has to be relaxed a little. most dirt jumpers/bmxers have figured this out long ago.
you literally want to carry your momentum from berm to berm, where the rollers add speed by pumping. you can then add a cross over gap/table jump in the center to add some fun.
got a little more planning done, talked to a professional trail builder who makes these things and works with hoots. we shall see if my design is valid.
got some more rocks delivered for the rock garden on the back of the berms and some pavers... that's where i'm going to plant perennial herbs Growing Culinary Herbs In Ontario and sedum...
everything flagged, scoped and papered... excavator time shortly...
i'll be publishing an open source trail project pdf and a hard copy with all the info/dimensions/etc... some newer sustainability concepts for the urban landscape will be explored with this concept that might be worth documenting... anyway around 2500 square feet...
