Results 1 to 16 of 16
    Reputation: Van G's Avatar
    Best Trails for Wet Fall Conditions outside GTA?
    Want to go for a ride Sat morning but we've had a lot of rain. What are the best trails in wet conditions? Durham because of all the pine?
    Would drive 45 min from North Toronto.
    Van G - Rider of The Don
    '14 Anthem 27.5 1
    humber river advocate
    Quote Originally Posted by Van G View Post
    east or west north toronto?
    east: durham west: palgrave
    a little further
    east: ganaraska west: dufferin
    broadcasting from
    "the vinyl basement"
    build trail!
    We're in Leaside so fairly central.
    Palgrave is okay after rain?
    First thought was Durham or Ravenshoe because they have so many pine trees which typically means quick draining.
    '14 Anthem 27.5 1
    Durham and most anything on the Oak Ridges Morraine because of the well drained soils. The Morraine is full of coarse sand, gravel etc etc so water infiltrates the ground very well. For the Durham Forest area, the closer you are to the actual Durham Forest Centre the better for late fall/early winter conditions when its been rainy. Walker Property and the southern most Glen Major could be a bit wetter trail wise. Last November my friend and I went to Durham Forest at the Forest Centre and although it had been raining for over a week in the GTA, and it was till moist looking in Durham, the conditions in the Durham trails were essentially perfect.
    Cheers, we'll give it a go.
    Is this the best map for Duraham? Trails suggestions?
    '14 Anthem 27.5 1
    it drys fast in there, lot's of pines. the distance to drive is the same from your location to both locations
    broadcasting from
    build trail!
    Suggested trails if parking in the main Durham parking lot? Route or order?
    '14 Anthem 27.5 1
    It depends what kind of riding you want. You can stay on fire-road type trails or just get on all the singltracks when you see the signs. I don't know the best "routes". If you like singletrack I would stay north and south of Houston road and ride the singletracks there. Bring the map if it makes it easier. Go east and south from the Forest centre parking lot.
    We're looking for single track and anything fun that may be on them.
    Looks like single track starts out of the north main parking lot. Will pack a map and see what happens. Maybe Strava will get us around in a jam.
    '14 Anthem 27.5 1
    Reputation: Braids's Avatar
    There's a trial build at Durham tomorrow. Instead of destroying the trails by riding in the rain why don't you help and build them. Help make a good impression on the multiple user groups that use Durham.
    Thank you.
    Quote Originally Posted by Braids View Post
    Thank you.
    Details?
    '14 Anthem 27.5 1
    Details?
    Durham Forest Trail Build | DMBA
    Puslinch or Turkey Point
    Longer drives though...
    9 lives
    Dufferin has good drainage so it's not very muddy after rain
    Palgrave takes a little longer to dry but it's ok too (mostly sand) but there are also some slick sections when wet
    F*ck Cancer
    Eat your veggies
    Reputation: Crash&bern's Avatar
    Mansfield forest for sure.
    It can rain hard all day , and try to find a puddle
    On the single track.
    Was riding in the rain there today.
    Also good spring riding for the same reason.
    Ride a Santa Cruz heckler
    And many part bikes : )
    " Team Van Go"
    Checked out Palgrave Saturday and then Durham Sunday. Fortunate to get the locals edge at Durham through The Maze.
    Much different than The Don but a great time. Thanks to Derek for the tour if your on here.
    '14 Anthem 27.5 1
  1. Boise Tech Trails II/Fall 2013 - Trail Work
    By Wheelbender in forum Idaho, Montana, Wyoming
    Last Post: 11-13-2013, 09:22 AM
  2. Replies: 4
    Last Post: 10-04-2013, 01:30 PM
  3. Fall Creek Falls S.P. Trails?
    By Lule in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 10-31-2012, 04:05 PM
  4. Replies: 17
    Last Post: 09-25-2012, 11:54 AM
  5. Replies: 11
    Last Post: 10-03-2011, 08:36 AM
