Results 1 to 8 of 8
    Feb 2013
    Aluminum Frame Mods
    Not MTB related but...
    I have an aluminum track frame that I wanted to add bottle cage mounts and cable routing to. Does anyone know of an aluminum frame builder within/around the GTA?
    Jul 2013
    I expect that any shop that does aluminum welding could help you out. I'm on the hunt, myself, for someone in Woodstock.
    Is the frame something special, or do you just have it laying around and would prefer it was a road bike?
    Bicycle tubes are very thin. Most fab shops don't have experience with tubing so thin. A frame should also go through a heat treat process after welding.
    You could pick up a cheap new aluminum road frame for around $100.
    db9
    db9 is offline
    What about True North Cycles?
    swm
    swm is offline
    For bottle cage mounts look for riv-nuts.
    Jul 2013
    Looks like True North doesn't do aluminum.
    db9
    db9 is offline
    re True North Cycles..
    A e-mail or phone call would confirm if they do Aluminum or not
    For OP
    As SVM stated - riv-nuts, you can get them thru Aircraft Spruce Canada and look around for rivet style cable stops - Nova Cycles Supply carries them and I'm sure there are other sources - used on carbon frames
    Reputation: veteran_youth's Avatar
    Nov 2006
    After all that if it is a true track frame it will likely be 120mm R hub spacing and lack a derailleur hanger. Some horizontal dropout hangers do exist for dirt jumpers but it still seems like a lot of trouble to go through to have to run an antiquated 5 spd freewheel. Does it at least have a drilled brake bridge?
  1. Aluminum frame vs Steel frame.....or does it even matter
    By Tan&Green in forum The ReCycle Bin
    Last Post: 06-15-2016, 11:24 AM
  2. Frame vs Frame - Alpha Gold Aluminum vs QUICK CX , OPTIMIZED 6061 ALLOY SAVE
    By Paramount X in forum Bike and Frame discussion
    Last Post: 05-23-2013, 07:37 PM
  3. Frame mods
    By Keith Medlock in forum Bike and Frame discussion
    Last Post: 03-26-2013, 06:15 PM
  4. Help! Corrosion on Aluminum frame...
    By Puzman in forum Passion
    Last Post: 09-12-2012, 04:40 PM
  5. Frame save an aluminum frame?
    By aBicycle in forum General Discussion
    Last Post: 06-29-2012, 10:38 PM
