Results 1 to 12 of 12
Thread: 2-wheel drive?
    Jul 2014
    2-wheel drive?
    Attempts to drive both wheels on a bicycle have always been a mechanical nightmare, but on an ebike it should be easy. Is anyone doing it?
    I'm thinking of this for hauling loads and tractor-like applications.
    With a front hub motor? And a regular one for the back wheel. How would you work the power?
    Moderator Moderator
    I rode an Easy Motion (BH Industries, the Spanish conglomerate) with 2WD. Lots of fun, but, even with a sensor that adjusted the power when one wheel started to slip, didn't notice any advantage over 1WD. The real fun was when the torque sensor (apparently) got stuck and the bike flew up a fairly lone, relatively steep fire road. Also, I had a front hub motor with rear 8-speed derailleur; fun, but nothing special.
    Reputation: Dougal's Avatar
    Power through the front wheels undoes the self correcting nature of your front steering. It becomes unstable and requires a firm grip on the bars.
    So you can do front wheel assist. But it needs to be linked to the torque and speed applied to the back wheel.
    Sent with 100% recycled electrons.
    Owner of www.shockcraft.co.nz and NZ Manitou Agent.
    www.dougal.co.nz Suspension setup & tuning.
    SPV Devolve
    Jul 2014
    You would have to have both motors run off the same controller and both motors would have to be the same as well so the power output is identical on both. It could successfully be done but the need just isn't there. I've put my rear wheel moto bikes places only goats go. The actual need for the front wheel to be turning would be far less than 1% of the time.
    Nov 2015
    If this was a good idea, Rokon would be MX champion..........
    Nov 2015
    So, let's wait a couple of years and see if they are sucessful......... If so, they will be the first.
    Mar 2016
    Quote Originally Posted by andytiedye View Post
    I know some guys who have done 2x2500w systems, but they don't post online. There are several folks over on the Sondors forums who have done the 2x750w on the Fattie.
    Catfish ...
    Here, diagonally!
    Reputation: JACKL's Avatar
    Seems like the only time this would be an advantage would be really slippery terrain like snow or ice. Normally by the time the terrain is steep enough to benefit from 2wd, the weight is mostly on the rear.
    Could be a benefit in packaging just being able to use 2 motors to increase power output though. Heat removal should improve at any given total power level.
    Moderator Moderator
    I think that 2WD with separate dedicated systems is a good idea for an individual who can pedal minimally or not at all since they would be able to get home with the still operating one. I realize that if both systems are inoperative the individual is in trouble.
    Reputation: Bigwheel's Avatar
    A much simpler way to achieve two wheel drive is to use a front hub motor and use your pedals and proper gearing to activate the rear wheel. I have over 2000 miles on this type of setup and it works just fine.
    A bike by any other name is still a bike.
  1. Replies: 22
    Last Post: 11-15-2016, 01:48 PM
  2. All Wheel Drive MTB'S!!!!
    By Beartrap Blade in forum General Discussion
    Last Post: 11-21-2014, 11:15 PM
  3. Wheel build:belt drive+IGH
    By Chalkpaw in forum Commuting
    Last Post: 12-22-2011, 08:06 PM
  4. Single speed drive train and wheel help?
    By Utilityman in forum Singlespeed
    Last Post: 11-12-2011, 05:56 PM
  5. Front wheel drive question
    By alanm in forum General Discussion
    Last Post: 10-22-2011, 12:02 AM
