Results 1 to 8 of 8
Thread: XX1 Gripshift
    Reputation: VICpt's Avatar
    Good job! XX1 Gripshift
    Ive been reading and listening that the XX1 gripshift fails!?
    Ive always used gripshift - my first bike had it installed - and i liked it and got used to it.
    I want to mount a XX1 but im having this doubt: trigger or gripshift.
    Can you guys using the gripshift give any feedback?
    Cleavage Of The Tetons
    Well, I can tell you that it is outrageously overpriced for the same technology that is in $30 OEM grip shifters!
    "We LOVE cows! They make trails for us.....
    And then we eat them."
    Mine hasn't failed yet, but rattles like a mofo. I do like the function of GS though, so for now I'm living with it.
    What do you mean by "rattles"? rwitte.
    Agree rideit, the prices are obscene, thats one of the disadvantages of dealing with a market owned by two giants - SRAM and SHIMANO.
    I know 3 sponsored local riders who are loving XX1 and all three had their Gripshift fail in the first week of use. They love the Gripshifter but are racing with triggers now. I am running 2009 X.9 grippers that I got on sale at CRC for $30 FOR THE PAIR. Still work great 3 years later.
    Mar 2013
    I've used both the XX1 trigger and the grip shifter. I'm currently using the trigger shifter because I feel the shifting is a bit more accurate than the grip shifter. I felt like with the grip shifter I could accidentally over shift when going down a rougher down hill section. A couple positives to the grip shifter is that you can shift through a lot of gears FAST which is nice on a 11sp. Also if/when you crash a grip shifter will (most likely) clear your top tube when your handle bars spin at mach 1. I've already chipped the paint on my top tube with the trigger shifter. I think they both have their place just depends on your needs. I personally liked the accuracy, reliability, and the feel of the trigger shifter.
    Quote Originally Posted by VICpt View Post
    The plastic housing around the shifter is loose and rattles. I've loosened the clamp and squeezed it all together as much as possible, which helps a little, but doesn't eliminate it.
    Quote Originally Posted by rideit View Post
    The problem is that it isn't the same technology. If it was, they would be reliable .
    Here's a thread about new gripshift failures:
    XX1 Grip Shift Failure
    If you are ok with 9 speed, get some 9 speed gripshift, and you will never worry about them.
  1. XT/Gripshift
    By J.R.A. in forum Brake Time
    Last Post: 04-05-2013, 12:48 PM
  2. XTR 985 and XX1 Gripshift
    By onobed in forum Brake Time
    Last Post: 01-16-2013, 12:25 AM
  3. Replies: 402
    Last Post: 03-20-2012, 04:04 PM
  4. Replies: 10
    Last Post: 10-30-2011, 05:43 PM
  5. Replies: 0
    Last Post: 09-16-2011, 10:14 AM
