Results 1 to 6 of 6
    Nor­wegr
    Reputation: Vegard's Avatar
    XX1 Derailleur screw broke.
    Quote Originally Posted by Vegard View Post
    I tried contacting SRAM, but I'm not getting a reply, anyone know what spec it is so I can replace it?
    I managed to salvage and use the piece without the 'head' on it, so the derailleur functions; alas not to it's full potential as the screw isn't long enough.
    Reputation: J.B. Weld's Avatar
    Don't know the size but most lbs have a scrap bin of trashed derailleurs, you could probably mine one from there.
    Don't know the size either but I've replaced them before and know that it's a standard thread. You can take your saved piece and match it up at a hardware store.
    Nor­wegr
    $20 later I'm the proud new owner of a working limit screw for my derailleur.. The X.0 limit screw is the same as the XX1.
    MTBR Member
    Reputation: ncfisherman's Avatar
    $20? Should be like .20c from the hardware store.
    Nor­wegr
    Yes and no, don't have any hw stores with that diverse of a selection around here and that was the price of the SRAM replacement.
  1. SRAM X0 Rear derailleur limit screw busted
    By Mountain Medic in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2015, 10:17 AM
  2. derailleur limit screw size
    By the5ifty in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 07:39 AM
  3. Front Derailleur Limiter Screw
    By alazamboozle in forum Beginner's Corner
    Last Post: 11-10-2012, 03:24 PM
  4. Broke rear derailleur hanger
    By twistedmentality in forum Specialized
    Last Post: 07-02-2011, 07:21 PM
  5. 07 stumpjumper headset screw broke off!
    By singletrkmind in forum Specialized
    Last Post: 03-02-2011, 09:41 AM
