    On your left.
    XX1 with 180mm cranks?
    Does anyone make cranks compatible with XX1 rings (76mm BCD)? In 180mm length?
    M
    Reputation: Nater's Avatar
    I believe the XX1 spider will fit on other SRAM crankarms. Not sure if the spider is available in it's own or not.
    If it is, get an XX1 spider and ring, and mount it on X9 180mm arms.
    This is an aftermarket XX1 spider that will work on X9 arms too...
    Universal Cycles -- North Shore Billet 1x11 Crank Spiders - Fits Sram X0 and X9 Cranks
    Or this spider allows XX1 rings to be mounted on White Industries crank arms...for sure available in 180mm length.
    Universal Cycles -- White Industries XX1 Crank Spider
    On your left.
    Good ideas above, makes me wonder if the carbon Sworks cranks could be used - if a spider exists. I would think some sponsored pro has such a setup.
    M
    On your left.
    Heck yeah - Specialized makes an XX1 spider for their Sworks cranks.
    M
  1. 180mm cranks better on 29r?
    By danza in forum 29er Components
    Last Post: 03-18-2013, 10:38 PM
  2. 180mm cranks
    By btadlock in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-26-2012, 11:10 AM
  3. Mojo HD w 180mm Cranks
    By TACORICAN in forum Ibis
    Last Post: 03-02-2012, 12:27 PM
  4. 180mm press-fit BB cranks?
    By thirdnipple in forum SRAM
    Last Post: 08-15-2011, 01:00 PM
  5. WTB.... 180mm cranks....
    By paco664 in forum Singlespeed
    Last Post: 02-26-2011, 09:23 PM
