Results 1 to 3 of 3
    xx vs. sram carbon s-2200 cranks
    Got a new epic 29er evo R. 1x 10 with the sram s-2200 carbon cranks. The seller gave me a xx crankset with the purchase. Does anyone have an opions on the 2 cranks? is XX better and should I install that? or not that much difference? I haven't removed the s2200 to weigh them yet.
    Reputation: bikerboyj17's Avatar
    They provide different gearing options. If you want to go 2x10 id say put the XX on. If you want to stay with a 1x10 just leave the s-2200 on there.
    Jan 2009
    i beleive you can mount slammer gears onto the s-2200 . the boltcirkel is smaller i believe 4x104mm and the grammy 4x64mm
    so you can mount the more common chainrings onto it.
    for example 38/24 or 36/22.
    much better for an 29'er
  1. Change SRAM S-2200 on Stumpjumper to Single Ring
    By altezza2k2 in forum Specialized
    Last Post: 02-06-2012, 04:38 PM
  2. Replies: 0
    Last Post: 05-21-2011, 01:27 PM
  3. SRAM XX Cranks
    By Genesis in forum Titus
    Last Post: 11-20-2010, 11:23 AM
  4. help - cranks (XTR and SRAM)
    By jac02000 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-31-2007, 06:57 AM
  5. Best Cranks Set to Run With Sram XO
    By promtber in forum General Discussion
    Last Post: 01-30-2005, 06:08 PM
