Results 1 to 5 of 5
    XTRcrank/XT derailler
    I just installed a new xtr external bb crankset on my bike. The problem is,if it is installed as per instructions , it should have two spacers on the drive side. If I do this then the xt front derailler does'nt seem to have enough throw for the outer chainring. If I only go with one spacer the crank comes pretty close to my chainstay.Anybody have this problem before? Does an xtr fd have more throw?
    Quote Originally Posted by doncoyote
    What generation XT fd do u have? Cuz I think the older M750 may have that problem, but I do believe ive seen the M760 work with the xtr crank.
    I'ts the new 760
    thats why I'm confused as to why it won't work
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Make sure the high limiter screw is far out enough to allow it to move. What size is your BB shell? You only need two spacers if its 68mm.
    Yup, it's a 68mm .
