Results 1 to 10 of 10
    Nov 2012
    XTR Shadow Plus Clutch and MRP G2SL
    Hi Guys,
    I just installed my new Rear Derailleur Shimano XTR M986 Shadow Plus with Clutch and SRAM 1090 chain. My Rear cassette is 11-36 and front cog is 36T, I run 1x10. however when I had my LBS adjust the shifter, they told me that my chain is too short to use the MRP G2 chain guard. Chain is full length 114links uncut. I have attached picture with the chain on 36T rear and 36T front. Does it look like it is too short to use the chain guard?
    Yes, I'd agree - too short.
    Nov 2012
    Quote Originally Posted by Slash5 View Post
    Damn, what are my options? Who makes longer chain?
    I'm not convinced it is too short. There is a good article on PB - tech tuesday - about setting for the right chain length.
    Basically, leaving the chain on both big rings, pass it through the lower roller of your guide, then you deflate your shock. Fully compress the rear suspension of your bike. A good chain length should bring the derailleur cage at a 45 degree angle or so.
    If your chain is too short, it is probably not by much.
    You will engage at least 6 more teeth on the chainring - since the chain is 1/2" pitch, that's 3 inches more chain - plus the extra required
    for the longer run from guide to derailleur.
    Only 2 solutions I can think of - sacrificing an piece of another chain and a second quick link - or find a bike store that
    uses bulk chain and can cut the length you need.
    I know my local LBS uses bulk 9 speed chain, not sure about 10 speed.
    Dec 2009
    with short cage it's works... need a new chain or clutch off?
    Nov 2012
    I will check the article on PB and see how much length i have after the let the air off from the rear shock . If not will run it without the G2 till I get new chain.
    Is the XTR RD-M986 SGS or GS?
    Reputation: ToneyRiver's Avatar
    I had the exact problem I was/am running an xtr derailleur with a clutch but with a straitline silent guide. When I was on the large cog on the back with the clutch on there was tons of drag on the chain because it was too short and the clutch was pulling back on the chain. Not much of a fix but I ride now without the clutch on, with the chain guide there is not a lot is chain movement anyway.
    Nov 2012
    Quote Originally Posted by fcaw11 View Post
    This one is SGS long cage
    Quote Originally Posted by ToneyRiver View Post
    I ran it thru the chain guard and did short 2miles ride. It felt fine, i was able to switch to the 36t without any issue. I will monitor for any weird noise and behavior.
  1. Clutch Broken on XT Shadow Plus
    By WarBoom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2017, 08:09 AM
  2. Shimano Zee Clutch Lever keeps coming loose turning clutch off - advice?
    By coursemyhorse in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-22-2017, 04:01 AM
  3. Butcher Vs. Clutch
    By Enduro4710 in forum Specialized
    Last Post: 01-21-2012, 08:21 AM
  4. xt shadow or xtr shadow rear derailleur
    By scoholofo in forum All Mountain
    Last Post: 01-11-2012, 04:49 AM
  5. Shadow or non-Shadow for a low-geared 'cross setup
    By AndrwSwitch in forum Cyclocross
    Last Post: 09-27-2011, 08:55 AM
