Results 1 to 3 of 3
    Dec 2008
    XTR Shadow B-axle movement
    Hi guys,
    Having not yet used a Shadow, I am wondering about the movement I have in my B-axle hanger. The hanger moves very easily in the directions pointed out by the arrows below, especially when moved from a 3 o'clock position towards the bolt stop.
    Check out this video of the issue: http://www.youtube.com/watch?v=9zR4-CFR9UA
    I have replaced the standard hanger with a carbon version, which might have contributed to this. Now I wonder whether this will affect my shifting or not. I suppose that once the chain is fitted, it will keep the derailleur from flapping about, but since I haven't used the Shadow yet, I'm not entirely sure of how the hanger works.
    Attached Thumbnails Attached Thumbnails XTR Shadow B-axle movement-xtr-shadow.jpg
    Yes, that is supposed to happen. SRAM and Shimano stuff both do that. Just run the chain through and adjust.
    http://bike.shimano.com/publish/cont...0RD%20Tips.pdf
    The gap is there to allow adjustment for the b-tension screw. That allows the whole derailleur to move on the screw and adjust based on different bikes, cassettes, etc. Varying amounts of "play" is normal since the b-tensions are probably adjusted different.
    For the record, I have 2 XT shadows.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Movement on that axle is normal. Install the chain and ride.
  1. xt shadow or xtr shadow rear derailleur
    By scoholofo in forum All Mountain
    Last Post: 01-11-2012, 04:49 AM
  2. Replies: 0
    Last Post: 06-06-2010, 06:03 AM
  3. Superlight Dropouts - Axle Movement
    By reamer41 in forum Santa Cruz
    Last Post: 04-22-2009, 09:43 AM
  4. Bipedal Movement vs. By Pedal Movement...
    By ICanDigIt in forum Passion
    Last Post: 06-26-2006, 08:46 PM
  5. chain tension issues/axle movement
    By bighitboy in forum Singlespeed
    Last Post: 03-06-2006, 05:23 PM
