Hope someone can help....
Shifting was a little funny the last few days. Checked everthing and narrowed it down to the shifter pod.
Could not remove the cable after removing the plastic plug. The cable head is sitting 1/8" down from the hole. Next took apart the shifter pod. Three phillips screws and one 4mm screw. Next tried shifting and found only 7 detents. The pod will not shift into the 8 detent. Either up or down, no luck.
There are a lot of small parts so I am reluctant to pull the the rest of the pod apart. Any easy quick and simple fixes at this point?
