Results 1 to 47 of 47
    nimble biker
    Reputation: Picard's Avatar
    Apr 2005
    XTR rear derailleur can't shift chain to inner largest cog?
    why can't my XTR rear derailleur shift the chain to the largest inner cog?
    I have 1X11 XTR setup. my XT 2X10 could shift to largest cog.
    did the LBS misconfigured my derailleur?
    fRIDEday makes me happy!
    Reputation: FullBladdy's Avatar
    If they installed it then yes. They will have to work the hi-lo adjustments so it can get into that chain ring. It is not difficult but is better performed by someone who has dialed in a number of bikes. I suggest taking it back to them as it is a quick adjust then you go ride!
    Reputation: donutnational's Avatar
    Jan 2013
    Quote Originally Posted by FullBladdy View Post
    It's one screw, look at and if it's hitting when you try to get it in the biggest ring then back it out a bit at a time until it goes in. Could also need cable tighter or wheel could be in wrong. Not worth taking to the shop unless shop is right next door and they will look at it immediately.
    Contains no juice.
    Nov 2003
    You're like a caveman who buys a Ferrari.
    nvphatty
    Guest
    Quote Originally Posted by Finch Platte View Post
    you knew this.
    Quote Originally Posted by Picard View Post
    Quote Originally Posted by donutnational View Post
    Sure but if I just paid a shop to install a part and it doesn't work correctly I would much rather take it back to them as that is what I paid for. It is like getting new brakes on your car but it won't stop. Do you fix it or take it back to the shop? I try to assume that the normal biker may not wrench on their bike as much as some others and may mess things up more if they don't know what they are doing. True it is a simple screw but service and testing should have been performed prior to giving the bike back to the client.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    You have failed at using the internet.
    Self Appointed Judge&Jury
    Oct 2000
    Well this was all a very interesting read. I feel enriched to have happened upon it.
    Life Is Short
    Reputation: fatcat's Avatar
    Mar 2006
    https://www.youtube.com/watch?v=y3x13dD0UiQ
    may be the B set screw adjustment see :22
    from this creepy looking dude
    Thats if you are running a 40T or higher cassette. The 11 speed XTR is supposed to
    be ready freddy with the 40T, but if you have the larger 42T, it may not properly
    shift into the P us*y cog. Good luck!
    Ride More, Eat More
    Rabid Lana fan
    I'm going with "It's because he touches himself at night".
    No amount of adjusting can undo God's curse on that derailleur.
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    passed out in your garden
    Reputation: cmg71's Avatar
    Mar 2012
    umm did the shop also change the trigger to 11 speed?
    if not, never go back there
    always mad and usually drunk......
    Cycologist
    Reputation: chazpat's Avatar
    Too much brake dive…no wait, that was another thread. Did the shop figure out what was wrong with your fork while you were there?
    There are two types of people in this world:
    1) Those who can extrapolate from incomplete data
    Oct 2007
    Yeah, why learn to actually fix your bike, thats stupid. You should get the mechanics cell number and next time your derailleur is messed up on the trail you can call him and he'll come out and fix it. My question to you would be why would you take your bike back to the same idiots who couldn't do the work correctly in the first place?
    2015 Niner Jet 9 Carbon
    2014 Focus Raven 27R
    2017 Lynskey GR250
    2016 Niner BSB
    1987 Haro RS1
    Magically Delicious
    Reputation: Cleared2land's Avatar
    No further comments from the OP?
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
    Contains no juice.
    Nov 2003
    Quote Originally Posted by Cleared2land View Post
    Usually never are. You should know the drill by now.
    gobsmacked Moderator
    He's trying to figure out what happens to the refrigerator lights when he closes the fridge door.
    Oct 2000
    Quote Originally Posted by girlonbike View Post
    We all know it's a little penguin that shuts them off.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    So cryptic. A random question here and there, completely unphased by mockery. Picard might be a bot.
    Contains no juice.
    Nov 2003
    I'm not going to mock you for using 'phased' instead of 'fazed', but as far as him being unfazed, I beg to differ.
    Trail courtesy cost$ money - Page 4- Mtbr.com
    nimble biker
    Apr 2005
    Lbs is investigating my problem
    Sent from my SM-N900W8 using Tapatalk
    all this time I have been a hack...
    Contains no juice.
    Nov 2003
    Quote Originally Posted by cjsb View Post
    Huh?
    nvphatty
    Guest
    and when your bike is amiss do you take it to a neuro surgeon??
    IPA tester
    Reputation: Dirtrider127's Avatar
    Picard
    It would best to do a couple of things differently in your posts if you really are looking for answers and not wanting to get plastered with negative post replies.
    1. Post in the correct section of this web site. In this case it would be under drivetrain. In there you can search for posts where someone like yourself got the answer to the same question or one close to it.
    2. Google- there is so much information on topics you can spend hours and find more than you need. You use if your planning to do it yourself or want to learn.
    3. If you're going to use the LBS to fix it bring your bike in clean, listen to their expertise, learn i bit from them in the process, and say thanks for helping you out. Might even follow it up with a tip of some sort
    4. Ride the bike and enjoy the day
    "We'll ride it until they pave it."
    -Urban Yeti
    Dirttreaders.com
    > /dev/null 2&>1
    Feb 2012
    Whoops! I'm losing my edge.
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    Quote Originally Posted by Procter View Post
    And I thought it was a cunning play on the OP's name.....
    Quote Originally Posted by nvphatty View Post
    Depends. If you have a Specialized Epic with a Brain shock, a neurosurgeon would be handy when the Brain goes on the fritz.
    > /dev/null 2&>1
    Feb 2012
    Quote Originally Posted by JackWare View Post
    Yes, Jack's right. I was making a phaser pun.
    Set phasers to kill!
    Contains no juice.
    Nov 2003
    D'oh!
    Lol
    Contains no juice.
    Nov 2003
    Quote Originally Posted by Dirtrider127 View Post
    Picard
    Uh, I would switch 2 for 1.
    Google first, then bug us.
    > /dev/null 2&>1
    Feb 2012
    Finch, wouldn't be surprised if Picard has added you to ignore list and can't see any of this.
    Nutrailer
    Aug 2016
    Maybe this explains things;
    Contains no juice.
    Nov 2003
    Maybe he'll have the lbs show him where the ignore button is.
    Reputation: andrepsz's Avatar
    Jan 2013
    Chain too short.
    Nutrailer
    Aug 2016
    Probably best if they press it as well..
    Nutrailer
    Aug 2016
    Please stay on topic 😉
    Reputation: d4nt3ch's Avatar
    Sep 2015
    Your chain might be too short. I had to add a few links going from 1x11-36t to 1x11-42t.
    B screw might help a bit but if your cage is hitting the largest cog, your chain is too short.
    Sent from my SM-N930F using Tapatalk
    > /dev/null 2&>1
    Feb 2012
    It's a good theory, but if he were Borg Picard, wouldn't he be exceptional at fixing mechanical items, and integrating with others?
    Nutrailer
    Aug 2016
    ... and if we just ...
    Jan 2009
    Does your frame have a direct mount dropout? A friend of mine had an LBS install a new 11-speed XT der to a DM dropout, but did not remove the pivoting piece on the der. Same symptom, unable to shift to the big cog... Only guessing you have he same issue...
    Huh?
    I have been adjusting the B screw using the "hack" tchnique according to the video. It was actually helpful, he extends the derailleur so he isn't fighting the spring tension when he turns the B screw. the last time I did a 42T install I think I used his technique by accident because the wolftooth B screw is gigantic. But in the past I admit that. fought the tension of the derailleur spring.
    B A N N E D
    A photo of the derailleur setup might show this.
    > /dev/null 2&>1
    Feb 2012
    It's like we're all just talking to our monitors here
    Magically Delicious
    The OP is no longer in the building
    B A N N E D
    Probably regenerating.
    Just a flesh wound
    Reputation: Prophet Julio's Avatar
    OP, the 1 x 11 thing is a hoax. You can't use the top cog. Everyone knows that...Geez!
    Just kidding. Some good suggestions above. Good luck.
    My name is Chris and I ride a Prophet 650b with a Lefty.
  1. Rear derailleur will not shift to low gear
    By dan87951 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2016, 04:05 PM
  2. Replies: 21
    Last Post: 12-23-2013, 11:34 PM
  3. Replaced Shimano Bottom Bracket, now front derailleur won't shift to largest gear.
    By unsavory in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2013, 01:15 PM
  4. I have a new problem. Cannot shift into largest chain ring.
    By chuck732 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2011, 04:56 AM
  5. Rear Derailleur Index shift adjustment help, please?
    By Unicornz0 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2011, 05:15 PM
