Results 1 to 27 of 27
Thread: xtr rapid rise?
    Reputation: gthcarolina's Avatar
    Mar 2005
    xtr rapid rise?
    I'm building up an ebay bike with some stuff that was on it and some new stuff. I have three lightly used rear derailleurs: An XT, An XTR 952 and an XTR rapid rise 953. I have never used the rapid rise before. I will run a 9 speed cassette with XT shifters. Does anyone have an opinion on the rapid rise derailleur? Some reviews I read elsewhere indicated it was hard to get that der dialed in.
    germs, needles, milk, death, snakes, mushrooms, heights, crowds, elevators
    PCC
    PCC is offline
    I have converted my Deore XT rear derailleur from the standard to Rapid Rise (RD-M750-SGS to RD-M760-SGS) and I have had no problems with it so far other than having to relearn which lever does what. Setup was easy and pretty fast and the derailleur shifts like a charm.
    Originally, I thought that Rapid Rise was a joke because using your thumb to push the rear derailleur onto the next gear made sense to me. After thinking about it for a while Rapid Rise made more and more sense to me so I made the jump. Just as I expected, it works great!
    Mar 2005
    9 speed?
    Quote Originally Posted by PCC
    I feel kind of silly that I didn't know this existed. I've gone from 7 to 8 to 9 speed over the last 15 or so years and I have never seen a derailleur that does this. I'm guessing you are running 9 speed? Have they trickled this down to lower groups too?
    Reputation: lebikerboy's Avatar
    Jan 2005
    I'm running XTR 8 speed on 2 bikes with rapidrise. XT now has it although it's now called "low normal" which refers to which gear the derailleur sits on when no spring tension
    is present.
    Quote Originally Posted by gthcarolina
    Mar 2005
    Quote Originally Posted by lebikerboy
    is present.
    Are you running the long cage or the short cage? I have that choice to make too.
    Mar 2005
    I dislike Rapid Rise a lot! Tried it with XTR 95x and the new 960 shifters. It was not very widely accepted in the 95x world so Shimano forced it on you with their 960 XTR. Somebody at Shimano obviously thinks it is the only way to go. I do not see the merits in it, i.e. what is wrong with pushing the chain up the cassette and letting the RD pull it down. With Rapid Rise if your cable is not clean and pretty new it does not shift very well at all. I ended up having to replace the rear shifter cable probably 5-10 times as often to get it to shift right all the time.
    About 6 months ago, switched to SRAM x.0 after using XTR for many..... years. Really like the X.O trigger shifters and RD. And i hated grip shift when it first come out, so was pretty leary of going to SRAM.
    Quote Originally Posted by mtbdcd
    When Rapid Rise came out for XTR derailleurs several years ago, it was one of the highest rated derailleurs on mtbr. It currently has a 4.44 out of 5 rating after 271 reviews.
    The advantages of RR or Low Normal are
    1) It's a more intuitive way of shifting since both sides work the "same way" -- i.e. the same action on both sides shifts in the same direction. You can argue about how "necessary" this is once you're used to the "normal" shifting, but after having acclimated to BOTH systems, I personally prefer the Low Normal system.
    2) By using the spring to shift to larger gears, you regulate the amount of force pushing on the chain, which allows the system to utilize the gates (the spots on the gears where the ramps are and where the teeth line up properly for shifting.) This can result in smoother shifting compared to when you force the chain over with thumb pressure.
    3) I can shift down as far as I want without waiting for the cranks to turn, which results in the abiltiy to downshift further more rapidly. You can only shift about 3 gears at a time with the thumb trigger before you have to wait for the chain to move and "catch up." With low normal, you can actually shift from the highest gear to the lowest without turning the cranks at ALL. When the cranks start to turn, the chain shifts all the way down in less than one rotation. This is handy when you find yourself needing to suddenley shift down unexpectedly. You just keep banging away on the trigger and the system shifts down VERY quickly.
    I'm not referring to you personally, but I seem to see this comment a lot from people who haven't actually used low normal derailleurs. I agree that this issue "seems" like a logical assumption, but in practice it simply doesn't seem to be the case. If you look at the reports of people using low normal, they just aren't having this issue. In my personal experience, even in sloppy conditions this hasn't been a problem. My shifts are at least as good if not better than they ever were with the "high normal" shifters I used before moving to low normal, and I haven't had to adjust my derailleur since I initially dialed it in right after I got it.
    The main reason people shy away from low normal seems to be the fact that when you first try it, it feels VERY strange. I found that once I gave myself time to acclimate to it a bit, however (one good ride), I got used to it a lot faster than I thought I would, and I quickly started to appreciate it's advantages. I am in a position where I can switch to high normal if I want, but I prefer the performance with low normal.
    Larry
    illuminator82
    rapid demise
    not to use the cliche' but i dislike the system immensely! first- is cost!!! second, counter- intuitive after we were all trained on grip shift or shimano systems. third, with cable stretch and 34t rear, recipe for headaches. fourth-break one, and you will if you crash hard once on the bars.i have been around mtb's for a long while and i have switched back to SRAM and XO system (yes i know you can go the less expensive route with x7's). 1:1 ratios and no more prob's..F$ck sh*tmano for their planned obs...
    Reputation: DaveX's Avatar
    Quote Originally Posted by lalittle
    I'm not referring to you personally, but I seem to see this comment a lot from people who haven't actually used low normal derailleurs. I agree that this issue "seems" like a logical assumption, but in practice it simply doesn't seem to be the case. If you look at the reports of people using low normal, they just aren't having this issue. In my personal experience, even in sloppy conditions this hasn't been a problem. My shifts are at least as good if not better than they ever were with the "high normal" shifters I used before moving to low normal, and I haven't had to adjust my derailleur since I initially dialed it in right after I got it.Larry
    I agree, I've been using rapid rise since it was introduced and I haven't had to replace cables any more frequently then I did in My pre rapid rise days.
    Just ride.
    Reputation: Lothar Othp's Avatar
    Jun 2005
    Good job! Love it
    I've been running rapid rise since it was first introduced. Never had any problems. I'm a climber so it suits my riding style. It allows me to downshift under full power on tough technical climbs without missing a beat. I've used rapid rise with both XT & XTR rapidfire 9sp shifters and have never had a problem.
    Jan 2005
    Looks like the majority like rapidrise/low normal. Maybe Shimano's on to something after all!
    Quote Originally Posted by Lothar Othp
    Quote Originally Posted by brook_63@yahoo.com
    This only seems to be an issue recently with the discounted "hot deals" on the older derailleurs.
    This is only a negative BEFORE you acclimate to the new system, which takes a lot less time than most people think it will. Now that I've used both, I can actually switch back and forth between the two systems without all that much trouble, and the vast majority of people who use both systems for any length of time tend to find the rapid rise system much MORE intuitive. It's really the "traditional" system that is counter-intuitive once you learn both systems.
    Again, this is something you hear from people who don't use a low normal system. After several years of use, there has been no evidence of low normal systems causing any more cable stretch than high normal systems.
    I honestly don't understand what you're saying here. A crash can break ANY rear derailleur if you hit it hard.
    I have very little experience with SRAM derailleurs, but I just don't have ANY of the "problems" you refer to with Shimano. This is besides the point, however, since the original question is about low vs high normal, not Shimano vs SRAM. To answer the original question directly, I prefer the rapid rise/low normal.
    NOTE: Not that this necessarily matters, but I use the XT, not the XTR.
    Larry
    illuminator82
    you make very good points
    to give you some perspective i have been riding for over twenty years, and i am not going to acclimate easy to something that is ingrained for too long. i tried rapid demise for over a year, and i still dont like it!!! yes it is intuitive NOW, but my memory is not. just like i route all my brake lines for the front to my right hand. i have been on motorcyles way to long and would hate to suffer the consequences of going into a turn to hot, lets say around 120mph and grabbing the wrong brake!! so i hope you can see a little how my memory works. so, no, i am not going to switch back and forth, yes i own more than one bike always have always will.
    sorry for the misunderstanding, but i meant the bulbous shifter pods. which are horrendous looking, and functionally meant to break. how do i know, cuz i broke one, and changed it out so i could run avid brakes instead of a shimano(ie microsoft...lol) freaking system..
    i will give you this, the XT and XTR derailleurs are great! smooth, realiable, this is meant to the older systems and maybe your experieinces differ, but i could not keep mine working very smoothly nor could i grab a bunch of gears without probs..
    just my lousy 2 cents..
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Oh really. Explain to me how the left rapid-fire shifter works. What lever do you use to get into a lower gear, what lever gets you in the higher gear?
    It's a great thing when we introduce mountain-bike shifting to new customers. Now both sides of the shifters work exactly the same, much less confusing.
    illuminator82
    dont get your panties all soiled
    re-read my post. i was just making the connection to having my front brake lever being used with the right hand. i run all my bikes motocross style. never said anything about shimano's system interfering with that.
    i will not even respond to your question.....
    Mar 2005
    Larry
    I used Rapid Rise for 2+ years so your implication i did not use it is incorrect. Never did find it intuitive! And the cable drag causing poor shifting applied to EVERYONE that i came across that used it. If you notice a lot of the positive feedback comes from people that have it used it a short time. Much of the negative feedback comes from people that have used it much longer. Obviously everyone has their likes and dislikes. And if you like it that is fine, that is what makes the world go arount. But i do not after a long time of trying..... to like it. The 960 XTR is really nice looking stuff and makes you want to like it. But give me the old 952 without rapid rise!
    I am curious, why does SRAM not use rapid rise if it is so much better? Is it a Shimano patent?
    I was making a general observation based on reading a lot of different reports. I was not referring to you directly, and I even stated in my post that "I'm not referring to you personally." I tried to be careful to NOT imply that my generalizations applied 100% to all people, but based on my reading, I believe they do apply to "most" people.
    Larry
    Mar 2005
    Larry
    You did and no problem. And obviously Shimano agrees with you. Just not me. But i do nopt think 960 was an improvement over 952 in how you shift. I really struggled with the chainring shifting on my 960. Took a lot of effort to shift to the big ring. But no one else seems to have this complaint, so guess i am a wuss.
    I first went from high-normal to low-normal, because I wanted front and rear to operate with the same logic (release = down-shift). Good when you are a beginner or in a hurry.
    I achieved that, but found something that I could not learn to stand: the slower up-shifting during acceleration. Tensioning one gear always felt like taking more time that releasing one gear. And I have more time between the one-shiftings at deceleration than at acceleration.
    So I am back at high-normal RD and like it.
    I think there will be a new-color high-normal XTR RD option next year, just like already for the new-color Deore, LX, and XT. Aren't shops starting to discount the low-normal RD's?
    What we need is a high-normal front derailleur!
    Mar 2005
    Wow thanks for all the STRONG opinions
    I appreciate all the feedback and I'm surprised to see such strong pro and con on this question. I guess that's how it goes with most innovations i.e. thumbshifter vs trigger shifter, friction vs STI and some of the older things. (And currently sloping top tube vs trad on road bikes.) Anyway, if i often try to shift while climbing and grind my gears in doing so, will the low normal RD help me? (I know I'm not supposed to do that, but I talk on the cell phone when I drive too . . .) It seemed like the "Cow Bell Fan" suggested this is a possible benefit.
    Quote Originally Posted by anden
    It's actually the other way around -- as one of the pro-high normal advocates already pointed out, the discounts right now are on the high normal derailleurs. Prior to this, the prices were about the same.
    The short answer is most likely "yes." In general, low normal tends to shift smoother under load. By using the spring tension for downshifting, it is easier on the drivetrain to shift to lower gears since it allows the drivetrain to take advantage of the gates (i.e. the sections on the rear casette with ramps where the teeth align properly for shifting.) As you pointed out, it's STILL proper technique to plan ahead, and to back way off on the pedal pressure during the shift. That said, in practice I find that shifting is indeed smoother in this situation (which we all run into from time to time.)
    Larry
    Chrome Toaster
    Reputation: Hecubus's Avatar
    Understatement of the year. LOL! Yeah everybody has a strong opinion on it. Its really one of those things you either like or you don't. RR came out in 1998 with the 953 and it was one of the best recieved Shimano derailleurs ever, contrary to what many people think. Shimano did not just force it as the standard simply because they felt like doing so for no good reason. Look at the reviews here for the 953 and it was one of MTBR's most reviewed and highest rated derrailleur, the only one with a reviewers choice award for many years.
    The adjustment issue is nonsense. Derrailleurs don't go out of adjustment for no reason. That are completely dependent on outside factors such as housing and cable to stay properly tuned. Merely changing the cable clamp from the top parallelogram to the bottom one does not cause things to go out of whack. Thats all RR does. It changes the clamp position and spring to reverse the pull. Shifting problems with them are due to nothing more than incorrect adjustment, its that simple no matter what gibberish people try to come up with to call it unreliable.
    For the patient minded, let's see if New Top Normal has caught up with New Low Normal in a year from now, as measured by the top-scientific Google-hits method:
    January 3, 2006:
    Deore
    RD-M530 (LN '06): 203
    RD-M511 (TN '06): 396
    LX
    RD-M580 (LN '05): 29,800
    RD-M571 (TN '06): 397
    XT
    RD-M760 (LN '04): 52,400
    RD-M751 (TN '06): 653
    XTR
    RD-M960 (LN '03): 39,300
    RD-M954 (TN '06?): 0
    He be a moose too.
    Reputation: pinguwin's Avatar
    Wink
    No disrespect mean to the original poster, of course, but I think this is irrelevant. It might make a difference for a person who has never ridden, but once you have any level of experience, intuition is irrelevant. You shift and do so without thinking about it. That goes beyond intuition and into instinct. Right now, sitting in front of my computer, I'm not sure which way to shift. Get me on the bike and it just happens.
    This said, neither high/low normal is more strongly supported.
    I'm very suspicious of shimano and have been so for 15 years. Look, I run thumbshifters with 8 speed and will continue to do so for years to come. I don't care about 9 speed, 8 is enough. Hey, I was impressed when six came out and we didn't complain. Ok, back to suspicions...I firmly believe that under the bar shifters would never have been successful if shimano didn't force it down the throats of people. If it was offered as an option, thumbies would have never been displaced and that isn't just my opinion. The first under the bar shifters were awful! I'm going to say that again, awful! So I agree with some of the posters wondering why shimano came out with them. Just because shimano comes out with "new and improved", I don't have to think it's better. I'm also not going to pretend that equipment back yonder was always better either. One thing I've learned, never, ever underestimate the influence of 'hype' in a profit-oriented industry.
    Rapid rise is a solution in search of a problem. IMHO.
    Not me! I can rip through all eight gears in either direction in an instant. Not that I usually do, but every so often I get surprised or have to jump quickly in a race. I'm a gonna say it again: Thumbshifters! Sorry folks, had to get that in just once more :-)
    I don't mean this to be a thumbies rant either, but even if I had gripshift or under-the-bar shfiters, I still wouldn't use rapid rise.
    Funny thing at a race not to long ago, a guy looked at my thumbshifters and said, "Oh, haven't seen those before. Must be new."
    Penguin
    PCC
    PCC is offline
    I don't think I can ever go back to thumbshifters.
    The other night I was riding my bike and purposely rode up a hill in too high a gear and, under power, downshifted three gears until I could pedal comfortably. The Rapid Rise shifted just fine and I did not let up on the pedals at all. Definitely happy with the results.
    Quote Originally Posted by pinguwin
    I agree with your logic here, but in practice something odd happened in my case. Even though I was completely used to high normal shifting, I somehow "liked" the logic better on low normal systems. It's not that I had any "problems" with high normal shifting -- it's just that the low normal design "clicked" with me in a pleasing way. It's hard to quantify, but once again, after having acclimated to BOTH systems, I simply prefer the feel of low normal.
    The thing that seems to often be overlooked, however, is that the way a company holds onto a market is to create products that either work better or are less expensive than other offerings. People seem to think that Shimano creates new designs without any thought toward whether or not it will make sense or even work. This really isn't the case. If the new products don't offer improvements, people will switch to other options -- i.e. SRAM in this case. Shimano, just like other companies, is trying to create a better design, and in doing so, hold onto the market that is being fought for by a very aggressive competitor.
    If my experiences with the low normal derailleur that I just bought weren't positive, I would have immediately switched to something else. As it stands, however, the next derailleur I buy will most likely be a low normal because of the fact that it IS working well for me. THIS is how a company holds onto their market -- they attempt to create products that work better than the competition. If they don't, the competition will take their market away.
    There's a difference between "solving a problem" and "creating a better product." Low normal shifters are designed to offer certain functional advantages, not to solve a "problem." Whether or not it's functionally superior for each individual is another issue, but be careful not to assume that innovations are ONLY created to solve problems.
    We're not on the same page here. I'm talking about an actual physical limitation of derailleurs that applies to BOTH low normal and high normal -- it just applies in the "other direction" depending on which system you're using. Using the thumb (on either low or high normal) you literally CAN'T shift through more than about three gears at a time WITHOUT turning the cranks and shifting the chain to new gears. The reason for this is because you can only pull so much cable (i.e. MORE tension) before the system is completely taught and needs to be advanced before further shifts can be made. The same thing doesn't happen with the finger trigger since you're letting tension OUT, and you can let out as much as you want without anything binding. What this means is that if the cranks aren't moving (or aren't moving very fast), a low normal system will limit the number of gears you can shift UP, while a high normal system will limit the number of gears you can shift DOWN.
    Personally, I prefer to be limited on the UP shifting since I'm less likely to "need" to shift multiple gears in this direction without the cranks turning very fast. It's in the DOWN shifting direction that this issue becomes a problem, and low normal eliminates this issue in this direction.
    I understand that this may not effect certain people very much depending on the type and style of riding they do, but a low normal system will allow you to shift DOWN as far as you want without the cranks moving at all, which potentially "can" come into play in certain situations (i.e. a technical downhill followed by a sudden technical uphill that requires you to shift quickly without being able to turn the cranks fast enough.) You can argue about how "necessary" this might be for any given person, but that doesn't change the fact that it is one "potential" advantage of low normal, and it's a situation that I personally find myself in once in a while. It's not about "skill level," but rather it's about riding style.
    Larry
    He be a moose too.
    Most of what the two of us has said is mostly dependent on personal experience and opinion. When people ask me whether they should use grip shift or shimano under-the-bar shifters, I don't say "Go thumbshifters", they work for me and others, but are not a viable option in today's market (i.e. mostly unavailable).
    I am going to disagree with the way a market works. In a perfect world that may be true, but there are tons of examples of where things are done from a marketing perspective and not a technical perspective. I've been riding mtb's for 23 years now (and I don't mean to make myself sound like a know-it-all), but I've seen a lot of great stuff and a lot of crap over the years.
    I previously mentioned the first STI shifters. They sucked. I can't say that strongly enough, but I will say it again. They sucked. The only reason they were sold is that Shimano ceased to make thumbshifters and did it by fiat, not market demand. They were able to sell a more expensive part that broke more often (7 parts vs. 60 if I remember correctly). I'm a techie and I can provide a myriad of examples where marketing and market dominance (think microsoft :-) issues prevailed over technical issues. Yes, the market works, most of the time, but not always.
    That said, I don't use SRAM products and tend to go towards third party goodies (with the the exception of derailleurs/shifters, I don't use Shimano). The thumbies vs.STI example is some years old, but what is great about the emergence of SRAM is that Shimano can't pull that crap so easily anymore...Go Sram! The notion of market choice only works if there is a choice, which there now is. One other note, look at Shimano's attempt to supress SRAM some years ago. I don't mean this to turn into a sram vs. shimano post, just that I think we need to realize that marketing hype often drives the market and profit always does.
    There were times in the past where I did buy the hype. There were times where I didn't. I was suspicous at first when the move to the aheadset vs. the older expander bolt type of headset and thought it to b.s. One day, my mechanic explained it very clearly to me and what he was seeing on bikes everyday. Then, it made sense to me and I realized that it was a superior system and my initial opinions were wrong.
    By no means do I feel that there is a 'correct' answer to this issue. For Larry, it works for him and for good reason.
    'Guin
