Results 1 to 11 of 11
    XTR,New Bottom Bracket question
    Have a 2010 XTR M0970 Crank and BB.. Just bought the Wheels Mfg BB, for shimano..My question is the M970 left side arm has that adjustable knurled lock ring to press on the bearing. Do I leave that on for this BB or take it off? When I keep it on it is too tight.Wheels mfg says keep it on.... Any ideas
    Reputation: Bailey44's Avatar
    Dec 2010
    Are you talking about the pre-load cap? If so just lightly snug it up finger tight, make sure you get the slack out of the cranks and then tighten down the crank bolts. It only sets pre-load so you can back it off a little after you tighten the crank bolts or take it off if you want but there is no need to.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    are you talking about item #4 on this tech doc?
    http://techdocs.shimano.com/media/te...9830608898.pdf
    yes you do.. if it's binding you are probably missing item # 5 which is a spacer so the crank arm pinches up against the inner race on the bearings, if you miss placed the spacer/ring it'll press against the seals and bind like you are saying....
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    No, There is no pre load cap or pinch bolts on xtr like the ultra/da cranks.. xtr has an adjustable lock ring that pre loads the bearing.. This is the ring that is causing the problem and is not allowing me to tighten the crank arm bolt.
    Yes it is #4 that is the "knurled" ring that is pressing into the bearings.. I do have the spacers on also..
    Oct 2007
    Quote Originally Posted by eggdog View Post
    there's only one spacer.. #5 goes between that kurled piece and the bearing... not the spacers for the BB's cups that space them off the frame.
    Dec 2010
    Matters what XTR's you have. Mine have both of the things I mentioned...
    M970... that are with out the pre load or pinch bolts..I will try without the spacer on the adjustment ring to give me a little more room to play with
    bt
    bt is offline
    Nov 2007
    Wore out my XTR BB....Need a new one
    Should I go XTR or another brand altogether?
    Need it fast, online place to get them??
    Oct 2007
    Quote Originally Posted by bt View Post
    Hit up realworldcycling.com. Get ceramic bb's for much less than a regular shimmy one
    Feb 2006
    I bought the ceramics from Real World last time I rode on the east coast, they did not last too long in the wet conditions, luckily enough I ran into them at the Sea Otter Classic and they replaced my bearings for free, they need to be replaced again though. I have Race Face BBs on two bikes but forked over the dough for a Chris King BB on one of my bikes and have not had any problems with them at all, same for the Chris King headset, no problems ever. Cost is initially higher but they've outlasted any other bearing sets I've ever used.
