Results 1 to 17 of 17
    O.C.C. Maniac!!!
    Reputation: Hawg's Avatar
    Nov 2008
    XTR M980 38/26: new chain rings and 38/24 combo
    My crank set is the 2 ring "trail" version with 38/26 rings.
    Are there any other chain ring companies out there who make a set to fit this crank set? If so, please provide a link.
    Also how is the shifting if I drop from a 26 tooth small ring to a 24 tooth small ring with a 38 tooth big ring?
    Last, I assume I should replace the mounting bolts and nuts every time when new chain rings are installed?
    Sent from the communicator that I stole from Captain Kirk
    I've not checked, but Blackspire often does shimano specific rings where no-one else does.
    Bolts and nuts are all reusable.
    You might have a slight bit of hesitation by comparison to the 2T smaller jump, but shimano FD's shift well enough to make this not an issue.
    Quote Originally Posted by ambassadorhawg View Post
    I've been on the fence about going with the 980 38x26, coming from a 3x9 970 setup.
    Is climbing with your 2x10 painful?
    May 2012
    Here you go: Blackspire - SuperPro M980X Chainrings | Blackspire
    which says the gap between 38 and 24 is too large..max 12 tooth diff.
    Ted
    Ted is offline
    Ted in real life
    Reputation: Ted's Avatar
    I am running an XT M785 crank at 38 and 22. It works fine with a shadow XT M780 rear der.
    Reputation: bikecore's Avatar
    Jan 2013
    There is a new fc-m785 with 38-24. The 38er has a special design for better shifting
    Gesendet von meinem HTC One S mit Tapatalk 2
    Linie - Rhythmus - Atmung
    May 2012
    The OP has a FC-M980, I doubt he is willing to change it...
    Verstuurd van mijn GT-S7562 met Tapatalk
    Jan 2013
    OP???
    May 2012
    Quote Originally Posted by bikecore View Post
    OP???
    Original poster
    Vaginatarian
    th 980 uses standard 4 hole size rings 64, 104 so just about any 4 hole 64mm granny will work. if you want langevity action tec has Ti .
    the key will be if the deraillier will work. you need something that will lift a 14tooth diference., check your front deraillier specs, it will list what it is capable of.
    if its less that 14t then you will either have to get a 24t granny or a 36t big ring
    edit
    just checked shimanos web site
    985, 985E not E2, 986, 986D, 980, 981 all will work, says the 980 series will throw an 18t diference
    I wish Shimano would make a 28t inner ring for the 980. I feel the 26 in my case could be a bit higher. I'll probably just get another brand 28, but it would be nice if Shimano made one in the same forging as the 26.
    Stay aware of those who hide in plain sight.
    O.C.C. Maniac!!!
    Nov 2008
    I'm running an M985E2 up front so I guess that seals the deal for me. Gonna stick with 38/26. It's been fine for me anyway. Just that occasional +15% grade grind that hurts. But I'll live.
    Thanks for all your input guys!
    The m970 chain rings should fit because I'm running m980 chainrings on m970 crank it's a direct swap. I use it at as a double with a bash ring. But with that gearing I bought a large 39t rear cassette cog from action tec but I rarely use it It's just insurance for the extra long climb
    Vaginatarian
    Quote Originally Posted by jochribs View Post
    the granny doesnt have any ramps or pins so any brand with a 4 hole 64 bhd will work, if you use it alot I would go with actiontec Ti
    Action Tec Home Page
    I have a stock FC-M980 with 3 chainrings (24-32-42) and I would like to convert it to 2 chainrings setup for my 29er. I will use chainrings 24 and 36.
    My only quesiton would be that, should I buy the XTR Gear Fixing Bolts (M8 x 10.65) & Nuts (4 sets) (code: Y1LR98120), or will it work perfectly with normal aftermarget M8x6.5mm bolts and nuts?
    XTR version:
    XTR M980 38/26: new chain rings and 38/24 combo-32403_1_shimano_kettenblattschrauben4-armxtrfc-m980.jpg
    ___
    2012 On-One Whippet XC, SS edition w/ 32-18
    2012 On-One Inbred 29er (custom ht w/2x9, trail, fun & race bike)
    I still haven't found the answer but found a cheap alternative to Shimano (** KCNC), maybe it can be useful for those people who are thinking on the same question like me.
    XTR M980 38/26: new chain rings and 38/24 combo-xtr-m980-conversionkit.jpg
    A possible source (Germany): Bike24 - KCNC Chainring Conversion Kit 3-speed to 2-speed for XTR 980
    ___
Hot Deals
Contests
Latest Mountain Bike Articles
