• 01-20-2013
    SCR818
    XTR M980 38/26: new chain rings and 38/24 combo
    My crank set is the 2 ring "trail" version with 38/26 rings.
    Are there any other chain ring companies out there who make a set to fit this crank set? If so, please provide a link.
    Also how is the shifting if I drop from a 26 tooth small ring to a 24 tooth small ring with a 38 tooth big ring?
    Last, I assume I should replace the mounting bolts and nuts every time when new chain rings are installed?
    Thanks! :thumbsup:
  • 01-21-2013
    AlexRandall
    I've not checked, but Blackspire often does shimano specific rings where no-one else does.
    Bolts and nuts are all reusable.
    You might have a slight bit of hesitation by comparison to the 2T smaller jump, but shimano FD's shift well enough to make this not an issue.
  • 01-21-2013
    PAULUNM
    Thanks! :thumbsup:
    I've been on the fence about going with the 980 38x26, coming from a 3x9 970 setup.
    Is climbing with your 2x10 painful?
  • 01-21-2013
    Leech73
    Here you go: Blackspire - SuperPro M980X Chainrings | Blackspire
    which says the gap between 38 and 24 is too large..max 12 tooth diff.
  • 01-21-2013
    Ted
    I am running an XT M785 crank at 38 and 22. It works fine with a shadow XT M780 rear der.
  • 01-21-2013
    bikecore
    There is a new fc-m785 with 38-24. The 38er has a special design for better shifting
    Gesendet von meinem HTC One S mit Tapatalk 2
  • 01-21-2013
    Leech73
    The OP has a FC-M980, I doubt he is willing to change it...
    Verstuurd van mijn GT-S7562 met Tapatalk
  • 01-21-2013
    bikecore
    OP???
  • 01-21-2013
    Rick Draper
  • 01-21-2013
    Leech73
    Originally Posted by bikecore View Post
    OP???
    Original poster
  • 01-21-2013
    dan0
    th 980 uses standard 4 hole size rings 64, 104 so just about any 4 hole 64mm granny will work. if you want langevity action tec has Ti .
    the key will be if the deraillier will work. you need something that will lift a 14tooth diference., check your front deraillier specs, it will list what it is capable of.
    if its less that 14t then you will either have to get a 24t granny or a 36t big ring
    edit
    just checked shimanos web site
    985, 985E not E2, 986, 986D, 980, 981 all will work, says the 980 series will throw an 18t diference
  • 01-21-2013
    jochribs
    I wish Shimano would make a 28t inner ring for the 980. I feel the 26 in my case could be a bit higher. I'll probably just get another brand 28, but it would be nice if Shimano made one in the same forging as the 26.
  • 01-21-2013
    SCR818
    I'm running an M985E2 up front so I guess that seals the deal for me. Gonna stick with 38/26. It's been fine for me anyway. Just that occasional +15% grade grind that hurts. But I'll live. :)
    Thanks for all your input guys! :thumbsup:
  • 01-21-2013
    menusk
    The m970 chain rings should fit because I'm running m980 chainrings on m970 crank it's a direct swap. I use it at as a double with a bash ring. But with that gearing I bought a large 39t rear cassette cog from action tec but I rarely use it It's just insurance for the extra long climb
  • 01-22-2013
    dan0
    the granny doesnt have any ramps or pins so any brand with a 4 hole 64 bhd will work, if you use it alot I would go with actiontec Ti
    Action Tec Home Page
  • 02-02-2013
    semmiho
    I have a stock FC-M980 with 3 chainrings (24-32-42) and I would like to convert it to 2 chainrings setup for my 29er. I will use chainrings 24 and 36.
    My only quesiton would be that, should I buy the XTR Gear Fixing Bolts (M8 x 10.65) & Nuts (4 sets) (code: Y1LR98120), or will it work perfectly with normal aftermarget M8x6.5mm bolts and nuts?
    XTR version:
    Attachment 767440
  • 02-03-2013
    semmiho
    I still haven't found the answer but found a cheap alternative to Shimano (** KCNC), maybe it can be useful for those people who are thinking on the same question like me. ;)
    Attachment 768100
    A possible source (Germany): Bike24 - KCNC Chainring Conversion Kit 3-speed to 2-speed for XTR 980
  • 07-23-2013
    cl.mustard
    XTRs (980/ 970 at least) will not take any old granny. They have a different offset. You can just about achieve this with careful use of washers and standard rings but Blackspire and possibly others make some XTR specific granny rings.
  • 07-23-2013
    chinadill
    Running the same thing here.
  • 07-23-2013
    Diesel~
    The correct spacing is ~2mm, for those who want to go the spacer route.
    -D
