Results 1 to 11 of 11
Thread: Xtr m952 or x9
    Jun 2013
    Xtr m952 or x9
    Got my choice of rear derailleurs. X9 long cage or xtr m952 medium cage. Got a azonic ds2 I'm building into more of a trail bike. 1x9, fsa v drive crank, psylo 130mm forks. I've heard good things about both derailleurs, but not sure if a long cage would be ok with my setup.
    Nov 2006
    Quote Originally Posted by Borjawil View Post
    Either is fine but each necessitates their own proprietary shifter. Do you have a shifter set in mind already? Also, is the m952 a Rapid Rise version? The medium cage will be snappier shifting but the long cage will take up more chain slack, really depends on what is more important to you. There won't be the same amount of difference as in going from a short cage to a long cage so you might not even notice.
    Jun 2013
    Are you saying they have to have the shifter that goes with the derailleur? No idea if its the rapid rise. Would it say it on it? No idea on a set yet. Thinking ill go with the x9
    Nov 2006
    Yeah, rear derailleurs usually need matching rear shifters, brand wise, although I think that some people are running Sram rear derailleurs with some new 10 speed Shimano stuff because the pull ratio is the same or close to being the same.
    I'm not sure how to distinguish Rapid Rise from normal on the actual derailleur, RR will put the the rear derailleur on the largest cog with no tension, the reverse of a normal derailleur.
    That being said, I like Sram for rear derailleurs and Shimano for front. Mostly aesthetics at this point, Shimano rear derailleurs (other than m950-953) are butt ugly. Sram front derailleurs for any model are butt ugly.
    Maromero
    Reputation: doccoraje's Avatar
    XTR 952 is Rapid Rise
    Reputation: zahgurim's Avatar
    Aug 2005
    Quote Originally Posted by doccoraje View Post
    Nope.
    950 was 8 speed, 952 was the beginning of 9 speed.
    The 953 was the rapidrise version of the 9 speed 952 model.
    The 952 is an awesome derailleur. Run it with 9 speed XTR shifters for a great setup.
    Feb 2006
    After the 950 and 952 series, XTR went downhill. That is a killer derailleur you have - - especially it being a medium cage which became almost impossible to find towards the end.
    Nov 2006
    Quote Originally Posted by Pisgah View Post
    I run a m952 medium cage with an XT shifter on my wife's Trek 8900. My build of her bike is on here somewhere. She has no idea how good she has it.
    Nov 2006
    Reputation: eluv's Avatar
    Apr 2005
    ope.
    Quote Originally Posted by zahgurim View Post
    N
    If you get a hold of a set keep them they just work running them on my Intense 5.5
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    As much as I love the old XTR M952 gruppo - I say go X9. The M952 had an incredible amount of chain slap, out on the rough. If you want zero chain slap, and full RD serviceability - get the 9-speed SRAM X0. I put about 3200 trail miles on mine, since 2004 and it STILL begs for more! Since "retired" to my commuter:
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. Older XTR M952 vs new SLX 662
    By dhoffmanz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-22-2012, 01:19 AM
  2. M952 build ...... which frame??
    By abailcb in forum GT
    Last Post: 11-05-2011, 06:59 AM
  3. XTR M952 Rings Anybody?
    By OneEyeMan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2011, 10:18 PM
  4. XTR M952 RD Issue
    By Spinnyspinspin in forum All Mountain
    Last Post: 08-27-2011, 03:28 PM
  5. M952 XTR spider hack
    By pimpbot in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-26-2011, 01:52 PM
